[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #17
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/17/changes&gt;
Changes:
[etj] [GEOS-7219] geofence-server: add missing libs in plugin package
[...truncated 6309 lines...]
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.10.2015 @ 18:57:32 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 05-Oct-2015 20:21
[INFO] [GitCommitIdMojo] build.build.time = 05.10.2015 @ 20:39:39 UTC
[INFO] [GitCommitIdMojo] build.branch = 14199aca067bb70f5d24188d381efa216d907396
[INFO] [GitCommitIdMojo] build.commit.user.email = etj@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = etj
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 14199ac
[INFO] [GitCommitIdMojo] build.commit.id = 14199aca067bb70f5d24188d381efa216d907396
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7219] geofence-server: add missing libs in plugin package
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-restconfig <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-restconfig ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/gs-restconfig-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-restconfig ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/gs-restconfig-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/gs-restconfig-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/gs-restconfig-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/gs-restconfig-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Web Modules 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ web ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ web ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7219] geofence-server: add missing libs in plugin package
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.build.time = 05.10.2015 @ 20:39:40 UTC
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/web/target/web-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.8-SNAPSHOT/web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/web/target/web-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.8-SNAPSHOT/web-2.8-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Core UI Module 2.8-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://maven.restlet.org/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://www.hibernatespatial.org/repository/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://repo.maven.apache.org/maven2/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.359s]
[INFO] Core Platform Module .............................. SUCCESS [19.371s]
[INFO] Open Web Service Module ........................... SUCCESS [19.550s]
[INFO] Main Module ....................................... SUCCESS [2:41.980s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.639s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [49.042s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:24.018s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.031s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [38.192s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [47.546s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:09.894s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:11.002s]
[INFO] Web Map Service Module ............................ SUCCESS [2:38.187s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.298s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:30.197s]
[INFO] REST Support Module ............................... SUCCESS [23.827s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:42.495s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.118s]
[INFO] Core UI Module .................................... FAILURE [2.439s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:49.940s
[INFO] Finished at: Mon Oct 05 20:39:43 UTC 2015
[INFO] Final Memory: 49M/262M
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.8-SNAPSHOT: Failed to collect dependencies for [org.apache.wicket:wicket:jar:1.4.12 (compile), org.apache.wicket:wicket-extensions:jar:1.4.12 (compile), org.apache.wicket:wicket-spring:jar:1.4.12 (compile), org.wicketstuff:htmlvalidator:jar:1.2 (compile), org.slf4j:slf4j-log4j12:jar:1.7.10 (compile), log4j:log4j:jar:1.2.14 (compile), org.geoserver:gs-main:jar:2.8-SNAPSHOT (compile), org.geoserver:gs-platform:jar:2.8-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.8-SNAPSHOT (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.mortbay.jetty:jetty:jar:6.1.8 (test), org.geotools:gt-coverage:jar:14-SNAPSHOT (compile), org.geotools:gt-data:jar:14-SNAPSHOT (compile), org.geotools:gt-shapefile:jar:14-SNAPSHOT (compile), org.geotools.jdbc:gt-jdbc-postgis:jar:14-SNAPSHOT (compile), org.geotools:gt-wfs-ng:jar:14-SNAPSHOT (compile), org.geotools:gt-jdbc:jar:14-SNAPSHOT (compile), org.geotools:gt-metadata:jar:14-SNAPSHOT (compile), org.geotools:gt-arcgrid:jar:14-SNAPSHOT (compile), org.geotools:gt-geotiff:jar:14-SNAPSHOT (compile), org.geotools:gt-gtopo30:jar:14-SNAPSHOT (compile), org.geotools:gt-image:jar:14-SNAPSHOT (compile), org.springframework.security:spring-security-web:jar:3.1.0.RELEASE (compile), org.bouncycastle:bcprov-jdk14:jar:1.46 (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer artifact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/18/&gt;
[...truncated 6245 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 13:12
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 13:30:11 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.503s]
[INFO] Core Platform Module .............................. SUCCESS [16.105s]
[INFO] Open Web Service Module ........................... SUCCESS [17.450s]
[INFO] Main Module ....................................... SUCCESS [2:34.270s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.312s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [48.417s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:21.201s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.460s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [38.353s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [47.917s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:07.034s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:08.472s]
[INFO] Web Map Service Module ............................ SUCCESS [2:36.063s]
[INFO] KML support for GeoServer ......................... SUCCESS [51.816s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:32.684s]
[INFO] REST Support Module ............................... SUCCESS [24.043s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:35.984s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.137s]
[INFO] Core UI Module .................................... FAILURE [2.548s]
[INFO] Total time: 17:22.408s
[INFO] Finished at: Tue Oct 06 13:30:14 UTC 2015
[INFO] Final Memory: 49M/263M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/19/changes&gt;
Changes:
[ridethepenguin] [GEOS-7230] gs:DownloadEstimator should check size is less than Integer.MAX_VALUE
[...truncated 21 lines...]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-web-wps:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/wps/web-wps/pom.xml,&gt; line 21, column 14
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Main Module
[INFO] OGR parent
[INFO] OGR CORE
[INFO] OGR WFS
[INFO] OGR WPS
[INFO] DXF WPS PPIO
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://www.hibernatespatial.org/repository/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/geotools-14-20151006.130030-253.pom
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
[INFO]
[INFO] GeoServer ......................................... FAILURE [2.402s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Total time: 5.962s
[INFO] Finished at: Tue Oct 06 17:42:20 UTC 2015
[INFO] Final Memory: 27M/230M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.8-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:14-SNAPSHOT: Could not transfer artifact org.geotools:geotools:pom:14-20151006.130030-253 from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/20/&gt;
[WARNING]
[WARNING]
[WARNING]
[INFO]
[INFO] GeoServer
[INFO] Main Module
[INFO] OGR parent
[INFO] OGR CORE
[INFO] OGR WFS
[INFO] OGR WPS
[INFO] DXF WPS PPIO
[INFO]
[INFO]
[INFO] GeoServer ......................................... FAILURE [2.424s]
[INFO] Total time: 6.686s
[INFO] Finished at: Wed Oct 07 07:14:59 UTC 2015
[INFO] Final Memory: 26M/191M
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/21/changes&gt;
