See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/198/>
[...truncated 15 lines...]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-wps-core:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-core:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/wps/wps-core/pom.xml,> line 21, column 14
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-wps-cluster-hazelcast:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-cluster-hazelcast:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml,> line 19, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-web-wps:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/wps/web-wps/pom.xml,> line 21, column 14
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] REST UI Module
[INFO] GeoServer Extensions
[INFO] Printing Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] OGR parent
[INFO] OGR CORE
[INFO] OGR WFS
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] OGR WPS
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web process status sharing with Hazelcast
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
[WARNING] Failure to transfer org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt\-api/14\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 502, ReasonPhrase:Bad Gateway.
Downloading: http://www.hibernatespatial.org/repository/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/geotools-14-20160320.143849-14.pom
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
[WARNING] Failure to transfer org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt\-main/14\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 502, ReasonPhrase:Bad Gateway.
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [1.998s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6.112s
[INFO] Finished at: Sun Mar 20 14:40:51 UTC 2016
[INFO] Final Memory: 30M/229M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.8-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:14-SNAPSHOT: Could not transfer artifact org.geotools:geotools:pom:14-20160320.143849-14 from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/geotools-14-20160320.143849-14.pom. Return code is: 502, ReasonPhrase:Bad Gateway. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
