[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #203
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/203/&gt;
[...truncated 4782 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.598 sec
Running org.geoserver.catalog.rest.JDBCTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 1.264 sec
Running org.geoserver.catalog.rest.LayerGroupTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.847 sec
Running org.geoserver.catalog.rest.LayerTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.091 sec
Running org.geoserver.catalog.rest.NamespaceTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.714 sec
Running org.geoserver.catalog.rest.RESTMapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.852 sec
Running org.geoserver.catalog.rest.RestConcurrencyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.278 sec
Running org.geoserver.catalog.rest.StructuredCoverageStoresTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.186 sec
Running org.geoserver.catalog.rest.StyleTest
Tests run: 37, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.319 sec
Running org.geoserver.catalog.rest.WMSLayerTest
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.684 sec
Running org.geoserver.catalog.rest.WMSStoreTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.669 sec
Running org.geoserver.catalog.rest.WorkspaceTest
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.96 sec
Running org.geoserver.rest.AboutTest
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<html xmlns="http://www.w3.org/1999/xhtml&quot; lang="en" xml:lang="en">
<head>
    <title>GeoServer Configuration</title>
    <meta content="NOINDEX, NOFOLLOW" name="ROBOTS"/>
</head>
<body>
<h2>About:</h2>
<ul>
  <li>
        <h3>Resource name: GeoServer</h3>
      <ul>
        <li>
            <b>Build-Timestamp</b> : 24-Mar-2016 10:27</li>
        <li>
            <b>Git-Revision</b> : 1d9e9d1bc0206c862ccb8cd40212643d1a059d00</li>
        <li>
            <b>Version</b> : 2.8-SNAPSHOT</li>
    </ul>
  </li>
  <li>
        <h3>Resource name: GeoTools</h3>
      <ul>
        <li>
            <b>Build-Timestamp</b> : 24-Mar-2016 09:00</li>
        <li>
            <b>Git-Revision</b> : 7c2585e1500ac1cb7e4ead1d66d903b2e6af6aa5</li>
        <li>
            <b>Version</b> : 14-SNAPSHOT</li>
    </ul>
  </li>
</ul>
</body>
</html>
<head>
</head>
<body>
<h2>About:</h2>
<ul>
  <li>
        <h3>Resource name: freemarker-2.3.18</h3>
      <ul>
        <li>
            <b>Manifest-Version</b> : 1.0</li>
        <li>
            <b>Specification-Title</b> : FreeMarker</li>
        <li>
            <b>Main-Class</b> : freemarker.core.CommandLine</li>
        <li>
            <b>Specification-Version</b> : 2.3.18</li>
        <li>
            <b>Ant-Version</b> : Apache Ant 1.8.1</li>
        <li>
            <b>Specification-Vendor</b> : Visigoth Software Society</li>
        <li>
            <b>Extension-name</b> : FreeMarker</li>
        <li>
            <b>Implementation-Version</b> : 2.3.18</li>
        <li>
            <b>Implementation-Vendor</b> : Visigoth Software Society</li>
        <li>
            <b>Implementation-Title</b> : VSS Java FreeMarker</li>
        <li>
            <b>Created-By</b> : 1.6.0_22-b04 (Sun Microsystems Inc.)</li>
    </ul>
  </li>
</ul>
</body>
</html>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.219 sec
Running org.geoserver.rest.FontListTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.672 sec
Running org.geoserver.rest.GlobalContactTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.552 sec
Running org.geoserver.rest.GlobalSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
Running org.geoserver.rest.LocalSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.63 sec
Running org.geoserver.security.rest.AccessControlResourceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.646 sec
Running org.geoserver.security.rest.MasterPasswordResourceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.349 sec
Running org.geoserver.service.rest.LocalWCSSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.572 sec
Running org.geoserver.service.rest.LocalWFSSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.627 sec
Running org.geoserver.service.rest.LocalWMSSettingsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
Running org.geoserver.service.rest.WCSSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.551 sec
Running org.geoserver.service.rest.WFSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.63 sec
Running org.geoserver.service.rest.WMSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.517 sec
Results :
Tests in error:
  org.geoserver.catalog.rest.CoverageStoreTest: Unable to delete directory ./target/default2831166732012165774data.
Tests run: 357, Failures: 0, Errors: 1, Skipped: 3
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [14.840s]
[INFO] Core Platform Module .............................. SUCCESS [18.296s]
[INFO] Open Web Service Module ........................... SUCCESS [21.500s]
[INFO] Main Module ....................................... SUCCESS [2:18.846s]
[INFO] GeoServer Security Modules ........................ SUCCESS [5.336s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [46.912s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:19.337s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.126s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [34.949s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [39.600s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [57.402s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:42.098s]
[INFO] Web Map Service Module ............................ SUCCESS [2:12.119s]
[INFO] KML support for GeoServer ......................... SUCCESS [43.034s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:17.019s]
[INFO] REST Support Module ............................... SUCCESS [23.163s]
[INFO] REST Configuration Service Module ................. FAILURE [1:18.090s]
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:23.250s
[INFO] Finished at: Thu Mar 24 10:43:21 UTC 2016
[INFO] Final Memory: 88M/318M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/204/&gt;
[...truncated 12295 lines...]
  at java.lang.reflect.Method.invoke(Method.java:606)
testInputMemoryCorrect(org.geoserver.wcs2_0.WCSNetCDFTest) Time elapsed: 1 sec <<< ERROR!
java.lang.NoClassDefFoundError: Could not initialize class org.geoserver.wcs2_0.WCSNetCDFTest
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
  at org.junit.runners.BlockJUnit4ClassRunner.createTest(BlockJUnit4ClassRunner.java:195)
  at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:244)
  at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:241)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
testOutputMemoryNotExceeded(org.geoserver.wcs2_0.WCSNetCDFTest) Time elapsed: 1 sec <<< ERROR!
testOutputMemoryExceeded(org.geoserver.wcs2_0.WCSNetCDFTest) Time elapsed: 1 sec <<< ERROR!
Running org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.725 sec
Running org.geoserver.web.netcdf.layer.NetCDFOutTabPanelTest
NetCDF-4 C library not present (jna_path='null', libname='netcdf').
Unable to load library 'netcdf': Native library (linux-x86-64/libnetcdf.so) not found in resource path ([<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf-out/target/surefire/surefirebooter5850484802477644569.jar\])>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.501 sec
Results :
Tests in error:
  org.geoserver.wcs2_0.WCSMultiDimSubsetTest
  testRequestNetCDFUomConversion(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFBaseTest
  testRequestNetCDF4(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestNetCDFCompression(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestCoverageView(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestNetCDFCFDataPacking(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestNetCDFDataPacking(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestCoverage(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testRequestCoverageLatLon(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  org.geoserver.wcs2_0.WCSNetCDFMosaicTest: Could not initialize class org.geoserver.wcs2_0.WCSNetCDFMosaicTest
  testInputMemoryExceeded(org.geoserver.wcs2_0.WCSNetCDFTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFBaseTest
  testInputMemoryCorrect(org.geoserver.wcs2_0.WCSNetCDFTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFTest
  testOutputMemoryNotExceeded(org.geoserver.wcs2_0.WCSNetCDFTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFTest
  testOutputMemoryExceeded(org.geoserver.wcs2_0.WCSNetCDFTest): Could not initialize class org.geoserver.wcs2_0.WCSNetCDFTest
Tests run: 16, Failures: 0, Errors: 14, Skipped: 0
[INFO]
[INFO] GeoServer ......................................... SUCCESS [14.670s]
[INFO] Core Platform Module .............................. SUCCESS [18.885s]
[INFO] Open Web Service Module ........................... SUCCESS [20.448s]
[INFO] Main Module ....................................... SUCCESS [2:21.042s]
[INFO] GeoServer Security Modules ........................ SUCCESS [5.481s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [46.374s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:22.670s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.061s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [34.767s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [39.831s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [57.466s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:44.635s]
[INFO] Web Map Service Module ............................ SUCCESS [2:09.277s]
[INFO] KML support for GeoServer ......................... SUCCESS [42.577s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:15.158s]
[INFO] REST Support Module ............................... SUCCESS [22.914s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:22.240s]
[INFO] GeoServer Web Modules ............................. SUCCESS [5.097s]
[INFO] Core UI Module .................................... SUCCESS [1:03.222s]
[INFO] WMS UI Module ..................................... SUCCESS [30.068s]
[INFO] GWC UI Module ..................................... SUCCESS [48.590s]
[INFO] WFS UI Module ..................................... SUCCESS [18.847s]
[INFO] Demoes Module ..................................... SUCCESS [30.192s]
[INFO] WCS UI Module ..................................... SUCCESS [23.222s]
[INFO] Security UI Modules ............................... SUCCESS [5.259s]
[INFO] Security UI Core Module ........................... SUCCESS [1:40.928s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:20.181s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.262s]
[INFO] REST UI Module .................................... SUCCESS [20.562s]
[INFO] GeoServer Extensions .............................. SUCCESS [5.104s]
[INFO] Printing Module ................................... SUCCESS [21.404s]
[INFO] GeoServer Web Application ......................... SUCCESS [12.685s]
[INFO] Community Space ................................... SUCCESS [5.238s]
[INFO] Application Schema Support ........................ SUCCESS [7.426s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:33.983s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [19.925s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.765s]
[INFO] GeoSearch Index Module ............................ SUCCESS [20.145s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.799s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [5.481s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [5.133s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [5.568s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [5.742s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.907s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [5.763s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [5.571s]
[INFO] OGR parent ........................................ SUCCESS [5.156s]
[INFO] OGR CORE .......................................... SUCCESS [7.400s]
[INFO] OGR WFS ........................................... SUCCESS [16.940s]
[INFO] Web Processing Service parent ..................... SUCCESS [5.067s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:18.587s]
[INFO] OGR WPS ........................................... SUCCESS [18.850s]
[INFO] Excel Output Format ............................... SUCCESS [23.222s]
[INFO] Chart external graphics support ................... SUCCESS [5.847s]
[INFO] Feature Generalization Extension .................. SUCCESS [7.771s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [5.361s]
[INFO] OWS request flow controller ....................... SUCCESS [19.888s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [38.983s]
[INFO] Web Processing Service GUI ........................ SUCCESS [40.277s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [27.640s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [7.716s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [5.094s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.737s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [15.502s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [5.165s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.548s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [5.213s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [7.701s]
[INFO] XLST based WFS output format ...................... SUCCESS [29.148s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [34.419s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [23.554s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [5.317s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.235s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [18.740s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [49.286s]
[INFO] CSW UI Module ..................................... SUCCESS [18.345s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [5.085s]
[INFO] DXF WFS output format ............................. SUCCESS [23.277s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [18.348s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [5.066s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [29.115s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [21.718s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [17.421s]
[INFO] GeoServer Data Importer ........................... SUCCESS [5.302s]
[INFO] Importer Core Module .............................. SUCCESS [1:00.147s]
[INFO] Importer REST Api Module .......................... SUCCESS [53.419s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [32.479s]
[INFO] Importer Web UI Module ............................ SUCCESS [23.238s]
[INFO] GRIB Coverage Format .............................. SUCCESS [26.541s]
[INFO] NetCDF Coverage format ............................ SUCCESS [22.099s]
[INFO] WCS NetCDF output Module .......................... FAILURE [10:55.208s]
[INFO] Total time: 55:55.676s
[INFO] Finished at: Fri Mar 25 20:54:45 UTC 2016
[INFO] Final Memory: 122M/505M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf-out: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf-out/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/205/&gt;
