[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #208
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/208/changes&gt;
Changes:
[ridethepenguin] [GEOS-7459] Securing an app-schema data store may result in ClassCastException being thrown
[...truncated 14750 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.io.FileNotFoundException: Unable to create C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\.\target\default7809591383106635364data\wfs\transform
  at org.geoserver.platform.resource.FileSystemResourceStore$FileSystemResource.dir(FileSystemResourceStore.java:332)
  ... 38 more
Running org.geoserver.wfs.xslt.config.TransformRepositoryTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.418 sec
Running org.geoserver.wfs.xslt.rest.TransformRestTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.761 sec
Results :
Tests in error:
  testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest): Cannot create wfs/transform
Tests run: 29, Failures: 0, Errors: 1, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [15.741s]
[INFO] Core Platform Module .............................. SUCCESS [21.231s]
[INFO] Open Web Service Module ........................... SUCCESS [19.484s]
[INFO] Main Module ....................................... SUCCESS [4:09.680s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.609s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.218s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.165s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.259s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.921s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.287s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.735s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:20.990s]
[INFO] Web Map Service Module ............................ SUCCESS [5:08.880s]
[INFO] KML support for GeoServer ......................... SUCCESS [55.397s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:08.570s]
[INFO] REST Support Module ............................... SUCCESS [25.693s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:24.781s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.265s]
[INFO] Core UI Module .................................... SUCCESS [2:00.932s]
[INFO] WMS UI Module ..................................... SUCCESS [37.441s]
[INFO] GWC UI Module ..................................... SUCCESS [1:13.620s]
[INFO] WFS UI Module ..................................... SUCCESS [18.533s]
[INFO] Demoes Module ..................................... SUCCESS [36.800s]
[INFO] WCS UI Module ..................................... SUCCESS [25.802s]
[INFO] Security UI Modules ............................... SUCCESS [0.639s]
[INFO] Security UI Core Module ........................... SUCCESS [2:21.477s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:35.322s]
[INFO] Security UI LDAP Module ........................... SUCCESS [25.725s]
[INFO] REST UI Module .................................... SUCCESS [20.592s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.367s]
[INFO] Community Space ................................... SUCCESS [0.296s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.437s]
[INFO] Application Schema Support ........................ SUCCESS [0.281s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:45.516s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [18.377s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.436s]
[INFO] GeoSearch Index Module ............................ SUCCESS [21.794s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.850s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.702s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.374s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.639s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.687s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.087s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.905s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.734s]
[INFO] OGR parent ........................................ SUCCESS [0.265s]
[INFO] OGR CORE .......................................... SUCCESS [3.682s]
[INFO] OGR WFS ........................................... SUCCESS [16.599s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.281s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:35.889s]
[INFO] OGR WPS ........................................... SUCCESS [20.233s]
[INFO] Excel Output Format ............................... SUCCESS [23.104s]
[INFO] Chart external graphics support ................... SUCCESS [1.248s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.385s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.014s]
[INFO] OWS request flow controller ....................... SUCCESS [19.707s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [32.635s]
[INFO] Web Processing Service GUI ........................ SUCCESS [45.365s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [29.047s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.853s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.577s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.995s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.354s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.702s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.686s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.702s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.650s]
[INFO] XLST based WFS output format ...................... FAILURE [30.701s]
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 49:24.301s
[INFO] Finished at: Tue Mar 15 21:59:09 CET 2016
[INFO] Final Memory: 101M/424M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/209/&gt;
