[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #210
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/210/changes&gt;
Changes:
[andrea.aime] [GEOS-6106] WMS GetCapabilities fails with cryptic exception on layers with dangling references to styles (JDK8)
[...truncated 1458 lines...]
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.507 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.361 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.632 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.757 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Running org.geoserver.util.DefaultCacheProviderTest
03 Apr 10:18:27 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
  Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.01 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.167 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.343 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.522 sec <<< FAILURE!
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 373 sec <<< ERROR!
org.opengis.referencing.FactoryException: Database failure while creating a 'OperationMethod' object for code "8801".
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.databaseFailure(DirectEpsgFactory.java:3061)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createParameterDescriptor(DirectEpsgFactory.java:2174)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createParameterDescriptor(BufferedAuthorityFactory.java:995)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createParameterDescriptors(DirectEpsgFactory.java:2203)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createOperationMethod(DirectEpsgFactory.java:2335)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createOperationMethod(BufferedAuthorityFactory.java:1018)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateOperation(DirectEpsgFactory.java:2648)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateOperation(BufferedAuthorityFactory.java:1041)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:2008)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:644)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:520)
  at org.geotools.referencing.CRS.decode(CRS.java:448)
  at org.vfny.geoserver.crs.OvverideTransformationsTest.testFallbackOnEPSGDatabaseStd(OvverideTransformationsTest.java:97)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source)
  at org.hsqldb.jdbc.JDBCConnection.<init>(Unknown Source)
  at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
  at org.hsqldb.jdbc.JDBCDataSource.getConnection(Unknown Source)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3262)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:779)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createProperties(DirectEpsgFactory.java:1005)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createParameterDescriptor(DirectEpsgFactory.java:2168)
  ... 53 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.error.Error.error(Unknown Source)
  at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
  at org.hsqldb.DatabaseManager.newSession(Unknown Source)
  ... 61 more
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.369 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Results :
Tests in error:
  testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'OperationMethod' object for code "8801".
Tests run: 695, Failures: 0, Errors: 1, Skipped: 2
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.128 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.111 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.830 s]
[INFO] Main Module ........................................ FAILURE [02:17 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demoes Module ...................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:05 min
[INFO] Finished at: 2016-04-03T10:18:29+00:00
[INFO] Final Memory: 97M/348M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/211/changes&gt;
