[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #212
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/212/changes&gt;
Changes:
[ben] Upgrade git-commit-id-plugin to 2.2.0
[...truncated 287 lines...]
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml (953 B at 0.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml (571 B at 1.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml (571 B at 1.2 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml (572 B at 1.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml (2 KB at 2.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml (958 B at 2.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml (957 B at 2.0 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml (2 KB at 3.0 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml (2 KB at 4.3 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml (791 B at 2.9 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geoserver ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ geoserver ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[JENKINS] Archiving disabled
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 9 second
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [7.909s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21.294s
[INFO] Finished at: Sun Mar 20 00:50:01 CET 2016
[INFO] Final Memory: 39M/382M
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.2.0:revision (default) on project geoserver: The plugin pl.project13.maven:git-commit-id-plugin:2.2.0 requires Maven version [3.1.1,) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginIncompatibleException
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/213/changes&gt;
