See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/218/>
[...truncated 8096 lines...]
testStdDev(org.geoserver.wps.gs.AggregateProcessTest) Time elapsed: 55 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[1]> but was:<[4]>
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
at org.geoserver.wps.gs.AggregateProcessTest.testStdDev(AggregateProcessTest.java:66)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wps.gs.BinaryProcessingsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.018 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.093 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.278 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.146 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.39 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.237 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.496 sec
Running org.geoserver.wps.gs.CropCoverageTest
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.493 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.782 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.079 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.054 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.552 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.466 sec
Running org.geoserver.wps.gs.RangeLookupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.254 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.609 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.138 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.613 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.122 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.264 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.027 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.427 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.062 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.417 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.056 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.199 sec
Running org.geoserver.wps.other.NoArgWPSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.123 sec
Running org.geoserver.wps.ppio.GeotiffPPIOTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.145 sec
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.469 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.882 sec
Running org.geoserver.wps.resource.CoverageResourceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.054 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.311 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.328 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.247 sec
Results :
Failed tests: testAllSinglePass(org.geoserver.wps.gs.AggregateProcessTest): expected:<[5]> but was:<[8]>
testMax(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testMin(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testSum(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testAverage(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testNonRawOutput(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testAllOneByOne(org.geoserver.wps.gs.AggregateProcessTest): expected:<[5]> but was:<[8]>
testStdDev(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
Tests run: 233, Failures: 8, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 22.112 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.127 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.943 s]
[INFO] Main Module ........................................ SUCCESS [02:25 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.162 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.586 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:14 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.219 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.223 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 25.610 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.055 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:28 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.170 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:01 min]
[INFO] REST Support Module ................................ SUCCESS [ 13.285 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:06 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [ 48.401 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 18.491 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.956 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.815 s]
[INFO] Demoes Module ...................................... SUCCESS [ 19.190 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.907 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.080 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:48 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:23 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.136 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.930 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] Printing Module .................................... SUCCESS [ 12.395 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.068 s]
[INFO] Community Space .................................... SUCCESS [ 0.080 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.049 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:01 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.239 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 15.804 s]
[INFO] GeoSearch Index Module ............................. SUCCESS [ 12.316 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.845 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.329 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.048 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.332 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.424 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.622 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 0.503 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.137 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.319 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.035 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.043 s]
[INFO] Web Processing Service Module ...................... FAILURE [02:23 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 25:13 min
[INFO] Finished at: 2016-04-11T23:28:44+00:00
[INFO] Final Memory: 108M/222M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
