See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/230/changes>
Changes:
[andrea.aime] [GEOS-7438] The first few requests after startup might NPE in monitoring
[...truncated 4452 lines...]
testGeoServerReload(org.geoserver.catalog.ResourcePoolTest): No reader for C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\main\target\default3401994134509785470data\DEM\tazdem.tiff with format GeoTIFF
testPreserveStructuredReader(org.geoserver.catalog.ResourcePoolTest)
testSEStyleWithRelativePathProtocol(org.geoserver.catalog.ResourcePoolTest)
testAttributeCache(org.geoserver.catalog.ResourcePoolTest)
testDispose(org.geoserver.catalog.ResourcePoolTest)
testDropCoverageStore(org.geoserver.catalog.ResourcePoolTest)
testSEStyleWithRelativePath(org.geoserver.catalog.ResourcePoolTest)
testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest)
testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No reader for C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\main\target\default6459685634736898911data\DEM\tazdem.tiff with format GeoTIFF
testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSingleBandedCoverage_GEOS7311(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): No se ha encontrado ningún código "EPSG:32632" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testGenericStyle(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
Tests run: 695, Failures: 0, Errors: 45, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [40.716s]
[INFO] Core Platform Module .............................. SUCCESS [22.448s]
[INFO] Open Web Service Module ........................... SUCCESS [30.295s]
[INFO] Main Module ....................................... FAILURE [3:36.200s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:25.993s
[INFO] Finished at: Mon Apr 11 11:48:14 CEST 2016
[INFO] Final Memory: 89M/621M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\main\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
channel stopped
Finished Calculation of disk usage of workspace in 1 second
