See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/233/>
[...truncated 8434 lines...]
Running org.geoserver.wps.ppio.RawDataPPIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.814 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.67 sec
Running org.geoserver.wps.resource.CoverageResourceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.183 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.532 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.753 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.185 sec
Results :
Failed tests: testAllSinglePass(org.geoserver.wps.gs.AggregateProcessTest): expected:<[5]> but was:<[8]>
testMax(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testMin(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testSum(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testAverage(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testNonRawOutput(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
testAllOneByOne(org.geoserver.wps.gs.AggregateProcessTest): expected:<[5]> but was:<[8]>
testStdDev(org.geoserver.wps.gs.AggregateProcessTest): expected:<[1]> but was:<[4]>
Tests run: 233, Failures: 8, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [43.004s]
[INFO] Core Platform Module .............................. SUCCESS [20.168s]
[INFO] Open Web Service Module ........................... SUCCESS [34.571s]
[INFO] Main Module ....................................... SUCCESS [4:27.928s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.700s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [31.754s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.815s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.248s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.515s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.644s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:58.680s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:10.424s]
[INFO] Web Map Service Module ............................ SUCCESS [4:22.671s]
[INFO] KML support for GeoServer ......................... SUCCESS [47.412s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:56.114s]
[INFO] REST Support Module ............................... SUCCESS [22.315s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:15.123s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.269s]
[INFO] Core UI Module .................................... SUCCESS [1:51.658s]
[INFO] WMS UI Module ..................................... SUCCESS [32.902s]
[INFO] GWC UI Module ..................................... SUCCESS [1:05.698s]
[INFO] WFS UI Module ..................................... SUCCESS [16.147s]
[INFO] Demoes Module ..................................... SUCCESS [34.296s]
[INFO] WCS UI Module ..................................... SUCCESS [23.103s]
[INFO] Security UI Modules ............................... SUCCESS [0.648s]
[INFO] Security UI Core Module ........................... SUCCESS [2:26.479s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:42.912s]
[INFO] Security UI LDAP Module ........................... SUCCESS [21.988s]
[INFO] REST UI Module .................................... SUCCESS [17.468s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.769s]
[INFO] Community Space ................................... SUCCESS [0.256s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.291s]
[INFO] Application Schema Support ........................ SUCCESS [0.283s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:51.272s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [17.332s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.334s]
[INFO] GeoSearch Index Module ............................ SUCCESS [18.648s]
[INFO] H2 DataStore Extension ............................ SUCCESS [12.822s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.314s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.206s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.916s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [2.153s]
[INFO] ImageMap Output Format ............................ SUCCESS [11.898s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.816s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [2.661s]
[INFO] OGR parent ........................................ SUCCESS [0.252s]
[INFO] OGR CORE .......................................... SUCCESS [3.180s]
[INFO] OGR WFS ........................................... SUCCESS [14.538s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.262s]
[INFO] Web Processing Service Module ..................... FAILURE [3:58.740s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 44:05.195s
[INFO] Finished at: Tue Apr 12 01:59:59 CEST 2016
[INFO] Final Memory: 103M/459M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Finished Calculation of disk usage of workspace in 1 second
