See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/285/>
[...truncated 1612 lines...]
at org.hsqldb.jdbc.JDBCDataSource.getConnection(Unknown Source)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3262)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:779)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:1940)
... 46 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
at org.hsqldb.error.Error.error(Unknown Source)
at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
at org.hsqldb.DatabaseManager.newSession(Unknown Source)
... 53 more
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.232 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Results :
Tests in error:
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'CoordinateReferenceSystem' object for code "EPSG:4326".
Tests run: 706, Failures: 0, Errors: 1, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [33.633s]
[INFO] Core Platform Module .............................. SUCCESS [17.955s]
[INFO] Open Web Service Module ........................... SUCCESS [17.378s]
[INFO] Main Module ....................................... FAILURE [3:42.364s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:05.886s
[INFO] Finished at: Thu Jun 16 05:24:38 CEST 2016
[INFO] Final Memory: 78M/578M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\main\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
channel stopped
Finished Calculation of disk usage of workspace in 2 second
