[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #292
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/292/changes&gt;
Changes:
[andrea.aime] [GEOS-7543] REST Putting a WFS Settings xml results into an
[andrea.aime] [GEOS-7547] Expiry of GetFeatureWithLock wrongly expected to be minutes
[...truncated 4538 lines...]
[INFO] Compiling 28 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-rest ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-rest ---
[INFO] Compiling 15 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-rest ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/surefire-reports&gt;
T E S T S
Running org.geoserver.rest.EnviromentInjectionCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.924 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.rest.RESTDispatcherCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.998 sec
Running org.geoserver.rest.RESTDispatcherTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.433 sec
Running org.geoserver.rest.RESTSecurityRulesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.419 sec
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.117 sec
Running org.geoserver.rest.format.FormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.407 sec
Running org.geoserver.rest.format.MapJSONFormatTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
  <body>
    This is a generic template for Foo.
  <br>
  Properties:
  <ul>
        <li>prop2: 2
        <li>prop1: one
        <li>prop3: 3.0
  </ul>
  </body>
</html>Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Results :
Tests run: 28, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-rest ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/rest/target/gs-rest-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building REST Configuration Service Module 2.8-SNAPSHOT
Downloading: http://maven.geo-solutions.it/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geojson/14-SNAPSHOT/maven-metadata.xml (957 B at 2.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-app-schema/14-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/14-SNAPSHOT/maven-metadata.xml (2 KB at 23.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-restconfig ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-restconfig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-restconfig ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-restconfig ---
[INFO] Copying 38 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-restconfig ---
[INFO] Compiling 84 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-restconfig ---
[INFO] Copying 12 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-restconfig ---
[INFO] Compiling 37 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/test/java/org/geoserver/service/rest/LocalWMSSettingsTest.java&gt;:\[148,34\] error: cannot find symbol
[ERROR] variable response of type MockHttpServletResponse
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/test/java/org/geoserver/service/rest/LocalWCSSettingsTest.java&gt;:\[140,34\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/test/java/org/geoserver/service/rest/LocalWFSSettingsTest.java&gt;:\[142,34\] error: cannot find symbol
[INFO] 3 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.765 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.164 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.789 s]
[INFO] Main Module ........................................ SUCCESS [02:09 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.125 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.238 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:15 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.007 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 21.354 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 26.241 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 43.150 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.665 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:01 min]
[INFO] REST Support Module ................................ SUCCESS [ 13.176 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 8.658 s]
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demoes Module ...................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:42 min
[INFO] Finished at: 2016-07-22T14:25:47+00:00
[INFO] Final Memory: 108M/339M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-restconfig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/test/java/org/geoserver/service/rest/LocalWCSSettingsTest.java&gt;:\[140,34\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/restconfig/src/test/java/org/geoserver/service/rest/LocalWFSSettingsTest.java&gt;:\[142,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/293/changes&gt;
