[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #297
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/297/changes&gt;
Changes:
[andrea.aime] [GEOS-6878] WFS editing fails for geometries in full 3d crs
[andrea.aime] [GEOS-7604] CatalogBuilder fails to compute wgs84 bbox if data has a compound 3d CRS
[andrea.aime] [GEOS-7605] GWC transaction listener fails if the layer has a 3d compound CRS
[...truncated 2622 lines...]
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml (962 B at 1.9 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wfs ---
[INFO] Deleting C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\target
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wfs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-wfs ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wfs ---
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wfs ---
[INFO] Compiling 249 source files to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\target\classes
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wfs ---
[INFO] Copying 41 resources
[INFO] skip non existing resourceDirectory C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wfs ---
[INFO] Compiling 92 source files to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\target\test-classes
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\v1_1\Transaction3DTest.java:[57,21] error: no suitable method found for addVectorLayer(QName,Map<Object,Object>,Class<CAP#1>,Catalog)
[INFO] 1 error
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [38.220s]
[INFO] Core Platform Module .............................. SUCCESS [18.814s]
[INFO] Open Web Service Module ........................... SUCCESS [18.064s]
[INFO] Main Module ....................................... SUCCESS [3:57.917s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.686s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [31.412s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.290s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.399s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:02.587s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.457s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:55.892s]
[INFO] Web Feature Service Module ........................ FAILURE [16.442s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:40.844s
[INFO] Finished at: Mon Jun 27 18:24:17 CEST 2016
[INFO] Final Memory: 96M/602M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
channel stopped
Finished Calculation of disk usage of workspace in 2 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/298/changes&gt;
