See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/325/changes>
Changes:
[andrea.aime] [GEOS-7685] Concurrent WFS 2.0 load can cause shared WFS/GML schemas
[...truncated 179 lines...]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ geoserver ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.8-SNAPSHOT/geoserver-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/target/geoserver-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.8-SNAPSHOT/geoserver-2.8-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Core Platform Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-platform ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-platform ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-platform ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-platform ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Compiling 40 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-platform ---
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-platform ---
[INFO] Compiling 19 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-platform ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/target/surefire-reports>
T E S T S
Running org.geoserver.platform.AdvancedDispatchFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.058 sec
Running org.geoserver.platform.GeoServerExtensionsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.424 sec
Running org.geoserver.platform.GeoServerResourceLoaderTest
Aug 16, 2016 3:00:21 PM org.geoserver.platform.GeoServerResourceLoader lookupGeoServerDataDirectory
INFO: Falling back to embedded data directory: data
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.platform.exception.ExceptionLocalizeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.platform.exception.GeoServerExceptionsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.platform.resource.FileSystemResourceTheoryTest
Tests run: 36, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.621 sec <<< FAILURE!
directoryEvents(org.geoserver.platform.resource.FileSystemResourceTheoryTest) Time elapsed: 2049 sec <<< ERROR!
java.lang.NullPointerException
at org.geoserver.platform.resource.FileSystemResourceTheoryTest.directoryEvents(FileSystemResourceTheoryTest.java:138)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.junit.experimental.theories.Theories$TheoryAnchor$2.evaluate(Theories.java:175)
at org.junit.rules.ExternalResource$1.evaluate(ExternalResource.java:48)
at org.junit.rules.ExpectedException$ExpectedExceptionStatement.evaluate(ExpectedException.java:168)
at org.junit.experimental.theories.Theories$TheoryAnchor$1$1.evaluate(Theories.java:141)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithCompleteAssignment(Theories.java:127)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithAssignment(Theories.java:111)
at org.junit.experimental.theories.Theories$TheoryAnchor.evaluate(Theories.java:96)
Running org.geoserver.platform.resource.FileWrapperResourceTheoryTest
Aug 16, 2016 3:00:27 PM org.geoserver.platform.resource.FileSystemResourceStore$FileSystemResource$1 finalize
WARNING: There is code leaving resource input streams open, locks around them might not be cleared! Add -Dfalse=true to your JVM options to get a full stack trace of the code that acquired the input stream
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.251 sec
Running org.geoserver.platform.resource.PathsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.util.LoggerRuleTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.207 sec
Results :
Tests in error:
Tests run: 110, Failures: 0, Errors: 1, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 17.217 s]
[INFO] Core Platform Module ............................... FAILURE [ 12.457 s]
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demoes Module ...................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 39.337 s
[INFO] Finished at: 2016-08-16T15:00:27+00:00
[INFO] Final Memory: 94M/313M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-platform: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/platform/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
