[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #356
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/356/changes&gt;
Changes:
[ridethepenguin] Fix postgis search_path leak in test fixture setup
[ridethepenguin] [GEOT-5526] SQL Encoding of Filters on Nested Attributes
[...truncated 5827 lines...]
[INFO] 31 errors
[INFO] -------------------------------------------------------------
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [43.821s]
[INFO] Core Platform Module .............................. SUCCESS [17.160s]
[INFO] Open Web Service Module ........................... SUCCESS [17.628s]
[INFO] Main Module ....................................... SUCCESS [2:50.962s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.936s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [19.702s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [10.920s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.823s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [49.015s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [52.245s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:19.310s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:46.864s]
[INFO] Web Map Service Module ............................ SUCCESS [2:55.469s]
[INFO] KML support for GeoServer ......................... SUCCESS [29.916s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:05.060s]
[INFO] REST Support Module ............................... SUCCESS [15.148s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:03.230s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.219s]
[INFO] Core UI Module .................................... SUCCESS [1:09.763s]
[INFO] WMS UI Module ..................................... SUCCESS [18.159s]
[INFO] GWC UI Module ..................................... SUCCESS [39.223s]
[INFO] WFS UI Module ..................................... SUCCESS [8.923s]
[INFO] Demoes Module ..................................... SUCCESS [21.294s]
[INFO] WCS UI Module ..................................... SUCCESS [12.589s]
[INFO] Security UI Modules ............................... SUCCESS [0.375s]
[INFO] Security UI Core Module ........................... SUCCESS [1:33.039s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:02.313s]
[INFO] Security UI LDAP Module ........................... SUCCESS [12.277s]
[INFO] REST UI Module .................................... SUCCESS [9.906s]
[INFO] GeoServer Web Application ......................... SUCCESS [25.350s]
[INFO] Community Space ................................... SUCCESS [0.358s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.966s]
[INFO] Application Schema Support ........................ SUCCESS [0.780s]
[INFO] Application Schema Integration Test ............... FAILURE [33.494s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:40.124s
[INFO] Finished at: Tue Oct 25 19:18:38 CEST 2016
[INFO] Final Memory: 117M/454M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure: Compilation failure:
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\AbstractAppSchemaTestSupport.java:[51,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\AbstractAppSchemaTestSupport.java:[695,14] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[34,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\NestedIdSupportTest.java:[23,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SRSReprojectionTest.java:[27,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[24,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\PolymorphismWfsTest.java:[23,24] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\AbstractAppSchemaTestSupport.java:[679,44] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\AbstractAppSchemaTestSupport.java:[713,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\AbstractAppSchemaTestSupport.java:[713,50] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1407,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1436,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1462,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1480,47] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1482,55] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1493,12] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1517,23] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\FeatureChainingWfsTest.java:[1523,51] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\NestedIdSupportTest.java:[118,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\NestedIdSupportTest.java:[145,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SRSReprojectionTest.java:[258,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[419,8] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[444,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[477,20] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[504,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[531,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\SimpleAttributeFeatureChainWfsTest.java:[565,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\PolymorphismWfsTest.java:[759,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\PolymorphismWfsTest.java:[784,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\PolymorphismWfsTest.java:[809,19] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\app-schema\app-schema-test\src\test\java\org\geoserver\test\PolymorphismWfsTest.java:[811,8] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/357/&gt;
