[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #8
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/8/&gt;
[...truncated 17738 lines...]
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/importer/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.DataFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.681 sec
Running org.geoserver.importer.DatesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.importer.DirectoryTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.653 sec
Running org.geoserver.importer.FeatureDataConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.importer.ImportContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.importer.ImportTransformTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.83 sec
Running org.geoserver.importer.ImporterDataTest
java.lang.ClassCastException: com.vividsolutions.jts.geom.Point cannot be cast to [B
  at org.geotools.data.h2.H2DialectBasic.encodeValue(H2DialectBasic.java:188)
  at org.geotools.jdbc.JDBCDataStore.insertSQL(JDBCDataStore.java:3859)
  at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1590)
  at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1545)
  at org.geotools.jdbc.JDBCInsertFeatureWriter.write(JDBCInsertFeatureWriter.java:76)
  at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:337)
  at org.geoserver.importer.Importer.loadIntoDataStore(Importer.java:1225)
  at org.geoserver.importer.Importer.doIndirectImport(Importer.java:963)
  at org.geoserver.importer.Importer.run(Importer.java:831)
  at org.geoserver.importer.Importer.run(Importer.java:781)
  at org.geoserver.importer.Importer.run(Importer.java:755)
  at org.geoserver.importer.Importer.run(Importer.java:751)
  at org.geoserver.importer.ImporterDataTest.testImportKMLIndirect(ImporterDataTest.java:812)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,int:int,string:string,double:double)
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,pop:pop)
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,type:type)
Tests run: 33, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 27.047 sec <<< FAILURE!
testImportKMLIndirect(org.geoserver.importer.ImporterDataTest) Time elapsed: 785 sec <<< FAILURE!
java.lang.AssertionError: com.vividsolutions.jts.geom.Point cannot be cast to [B
  at org.junit.Assert.fail(Assert.java:88)
  at org.geoserver.importer.ImporterDataTest.testImportKMLIndirect(ImporterDataTest.java:816)
Running org.geoserver.importer.MemoryImportStoreTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.importer.OracleImportTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.002 sec
Running org.geoserver.importer.SQLServerImportTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0 sec
Running org.geoserver.importer.format.GMLFileFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.223 sec
Running org.geoserver.importer.format.KMLFileFormatTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.geoserver.importer.mosaic.ImporterMosaicTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.715 sec
Running org.geoserver.importer.transform.GdalTransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 4, Time elapsed: 0.356 sec
Running org.geoserver.importer.transform.KMLPlacemarkTransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.transform.TransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Failed tests: testImportKMLIndirect(org.geoserver.importer.ImporterDataTest): com.vividsolutions.jts.geom.Point cannot be cast to [B
Tests run: 83, Failures: 1, Errors: 0, Skipped: 6
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.108s]
[INFO] Core Platform Module .............................. SUCCESS [18.086s]
[INFO] Open Web Service Module ........................... SUCCESS [18.851s]
[INFO] Main Module ....................................... SUCCESS [3:02.132s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.489s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [49.056s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:28.736s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.169s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [37.783s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [46.698s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:09.351s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:10.191s]
[INFO] Web Map Service Module ............................ SUCCESS [2:40.600s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.582s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:29.240s]
[INFO] REST Support Module ............................... SUCCESS [25.055s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:39.795s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.131s]
[INFO] Core UI Module .................................... SUCCESS [1:11.837s]
[INFO] WMS UI Module ..................................... SUCCESS [34.343s]
[INFO] GWC UI Module ..................................... SUCCESS [1:01.217s]
[INFO] WFS UI Module ..................................... SUCCESS [18.321s]
[INFO] Demoes Module ..................................... SUCCESS [34.024s]
[INFO] WCS UI Module ..................................... SUCCESS [23.706s]
[INFO] Security UI Modules ............................... SUCCESS [0.190s]
[INFO] Security UI Core Module ........................... SUCCESS [1:50.764s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:28.590s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.835s]
[INFO] REST UI Module .................................... SUCCESS [19.801s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.121s]
[INFO] Printing Module ................................... SUCCESS [22.357s]
[INFO] Community Space ................................... SUCCESS [0.139s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.640s]
[INFO] GeoServer Web Application ......................... SUCCESS [8.881s]
[INFO] Application Schema Support ........................ SUCCESS [0.121s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:57.295s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [21.278s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.285s]
[INFO] GeoSearch Index Module ............................ SUCCESS [19.964s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.491s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.381s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.101s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.440s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.393s]
[INFO] ImageMap Output Format ............................ SUCCESS [12.708s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.493s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.503s]
[INFO] OGR parent ........................................ SUCCESS [0.155s]
[INFO] OGR CORE .......................................... SUCCESS [5.238s]
[INFO] OGR WFS ........................................... SUCCESS [15.883s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.154s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:44.949s]
[INFO] OGR WPS ........................................... SUCCESS [18.626s]
[INFO] Excel Output Format ............................... SUCCESS [23.687s]
[INFO] Chart external graphics support ................... SUCCESS [0.471s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.986s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.468s]
[INFO] OWS request flow controller ....................... SUCCESS [18.064s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.661s]
[INFO] Web Processing Service GUI ........................ SUCCESS [48.383s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.748s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.219s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.187s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.274s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [12.152s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.213s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.147s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.189s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.535s]
[INFO] XLST based WFS output format ...................... SUCCESS [31.799s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [39.045s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [25.684s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.128s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.226s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [17.677s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [58.496s]
[INFO] CSW UI Module ..................................... SUCCESS [16.183s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.086s]
[INFO] DXF WFS output format ............................. SUCCESS [24.242s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [20.393s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.083s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [30.641s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [20.755s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [16.032s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.182s]
[INFO] Importer Core Module .............................. FAILURE [1:14.358s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 44:44.590s
[INFO] Finished at: Thu Oct 01 09:06:33 UTC 2015
[INFO] Final Memory: 92M/293M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/importer/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/9/&gt;
