See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/93/changes>
Changes:
[daniele.romagnoli] netcdfpanel oversight fix
[...truncated 3394 lines...]
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.335 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.525 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.715 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.326 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.669 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.808 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.299 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.527 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.365 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.33 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.668 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.372 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.011 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.086 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
Running org.geoserver.util.DefaultCacheProviderTest
30 nov 18:25:08 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.015 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.563 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.421 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.573 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Results :
Tests in error:
testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest): Error persisting CoverageInfoImpl[DEM] to workspaces/wcs/DEM/DEM/coverage.xml
testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSingleBandedCoverage_GEOS7311(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testGenericStyle(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No se ha encontrado ningún código "EPSG:4326" de autoridad "European Petroleum Survey Group" para el objeto de tipo "IdentifiedObject".
Tests run: 686, Failures: 0, Errors: 20, Skipped: 2
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.029s]
[INFO] Core Platform Module .............................. SUCCESS [16.328s]
[INFO] Open Web Service Module ........................... SUCCESS [19.791s]
[INFO] Main Module ....................................... FAILURE [2:25.214s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:13.378s
[INFO] Finished at: Mon Nov 30 18:25:10 UTC 2015
[INFO] Final Memory: 38M/256M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/main/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
