[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x » GRIB Coverage Format #160
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver.extension$gs-grib/160/&gt;
[...truncated 202 lines...]
testFormatSupported(org.geoserver.grib.GribDataTest) Time elapsed: 0 sec <<< ERROR!
java.lang.NoClassDefFoundError: Could not initialize class org.geotools.imageio.netcdf.utilities.NetCDFUtilities
  at org.geoserver.grib.GribDataTest.testFormatSupported(GribDataTest.java:34)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at junit.framework.TestCase.runTest(TestCase.java:176)
  at junit.framework.TestCase.runBare(TestCase.java:141)
  at junit.framework.TestResult$1.protect(TestResult.java:122)
  at junit.framework.TestResult.runProtected(TestResult.java:142)
  at junit.framework.TestResult.run(TestResult.java:125)
  at junit.framework.TestCase.run(TestCase.java:129)
  at junit.framework.TestSuite.runTest(TestSuite.java:255)
  at junit.framework.TestSuite.run(TestSuite.java:250)
  at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
Running org.geoserver.web.data.store.raster.GribRasterEditPanelTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 1.077 sec <<< FAILURE!
testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest) Time elapsed: 999 sec <<< ERROR!
java.lang.NoClassDefFoundError: Could not initialize class javax.imageio.ImageIO
  at it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageReaderSpi.canDecodeInput(AsciiGridsImageReaderSpi.java:152)
  at org.geotools.gce.arcgrid.ArcGridFormat.accepts(ArcGridFormat.java:155)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormats(GridFormatFinder.java:188)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:236)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:216)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:751)
  at org.geoserver.data.test.SystemTestData.setUpRasterLayer(SystemTestData.java:275)
  at org.geoserver.web.data.store.raster.GribRasterEditPanelTest.setUpTestData(GribRasterEditPanelTest.java:34)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:203)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:154)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:151)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
java.lang.IllegalStateException: you can only locate or create sessions in the context of a request cycle
  at org.apache.wicket.Session.findOrCreate(Session.java:208)
  at org.apache.wicket.Session.get(Session.java:252)
  at org.geoserver.web.GeoServerWicketTestSupport.clearErrorMessages(GeoServerWicketTestSupport.java:54)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest) Time elapsed: 47 sec <<< ERROR!
org.apache.wicket.WicketRuntimeException: There is no application attached to current thread main
  at org.apache.wicket.Application.get(Application.java:179)
  at org.apache.wicket.Component.getApplication(Component.java:1386)
  at org.apache.wicket.Component.<init>(Component.java:928)
  at org.apache.wicket.MarkupContainer.<init>(MarkupContainer.java:113)
  at org.apache.wicket.MarkupContainer.<init>(MarkupContainer.java:105)
  at org.apache.wicket.Page.<init>(Page.java:237)
  at org.apache.wicket.markup.html.WebPage.<init>(WebPage.java:185)
  at org.geoserver.web.GeoServerBasePage.<init>(GeoServerBasePage.java:93)
  at org.geoserver.web.GeoServerSecuredPage.<init>(GeoServerSecuredPage.java:33)
  at org.geoserver.web.data.store.AbstractCoverageStorePage.<init>(AbstractCoverageStorePage.java:34)
  at org.geoserver.web.data.store.CoverageStoreNewPage.<init>(CoverageStoreNewPage.java:34)
  at org.geoserver.web.data.store.raster.GribRasterEditPanelTest.testGribCreate(GribRasterEditPanelTest.java:39)
org.geoserver.web.data.store.raster.GribRasterEditPanelTest Time elapsed: 47 sec <<< ERROR!
java.lang.NullPointerException
  at org.geoserver.web.GeoServerWicketTestSupport.onTearDown(GeoServerWicketTestSupport.java:60)
  at org.geoserver.test.GeoServerSystemTestSupport.tearDown(GeoServerSystemTestSupport.java:246)
  at org.geoserver.test.GeoServerSystemTestSupport.tearDown(GeoServerSystemTestSupport.java:154)
  at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:205)
Results :
Tests in error:
  testCoverageView(org.geoserver.catalog.CoverageViewReaderTest): javax.imageio.spi.ImageReaderSpi: Provider org.geotools.imageio.netcdf.NetCDFImageReaderSpi could not be instantiated
  testImage(org.geoserver.grib.GribDataTest): Could not initialize class ucar.nc2.dataset.NetcdfDataset
  testFormatSupported(org.geoserver.grib.GribDataTest): Could not initialize class org.geotools.imageio.netcdf.utilities.NetCDFUtilities
  testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): Could not initialize class javax.imageio.ImageIO
  testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
  testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): There is no application attached to current thread main
  testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver.extension$gs-grib/161/&gt;
