See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-main/199/>
[...truncated 411 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.404 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.platform.GeoServerExtensionsHelperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.GeoServerCustomAuthTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.423 sec
Running org.geoserver.security.GeoServerCustomFilterTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.654 sec
Running org.geoserver.security.GeoServerCustomSecurityProviderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.31 sec
Running org.geoserver.security.GeoServerRoleFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.256 sec
Running org.geoserver.security.GeoServerSecurityManagerTest
This file was created at 2016/03/04 03:05:18
The current master password is: geoserver
Test the master password by logging in as user "root"
This file should be removed after reading !!!.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.295 sec
Running org.geoserver.security.GeoserverRequestMatcherTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.787 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.574 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.034 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.555 sec
Running org.geoserver.security.auth.GuavaAuthenticationCacheTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.084 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.642 sec
Running org.geoserver.security.decorators.DecoratingLayerGroupInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.515 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.174 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.938 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.201 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.418 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.739 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.233 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.841 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.71 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.155 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.303 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.48 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.003 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.421 sec
Running org.geoserver.util.DefaultCacheProviderTest
04 Mar 03:06:29 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.016 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.5 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.998 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.574 sec <<< FAILURE!
testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 15 sec <<< ERROR!
org.opengis.referencing.FactoryException: Database failure while creating a 'Ellipsoid' object for code "7019".
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.databaseFailure(DirectEpsgFactory.java:3061)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createEllipsoid(DirectEpsgFactory.java:1312)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createEllipsoid(BufferedAuthorityFactory.java:510)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createDatum(DirectEpsgFactory.java:1635)
at org.geotools.referencing.factory.AbstractAuthorityFactory.createGeodeticDatum(AbstractAuthorityFactory.java:276)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createGeodeticDatum(BufferedAuthorityFactory.java:489)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:1983)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:644)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:520)
at org.geotools.referencing.CRS.decode(CRS.java:448)
at org.vfny.geoserver.crs.OvverideTransformationsTest.testOverrideEPSGOperation(OvverideTransformationsTest.java:78)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.sql.SQLNonTransientConnectionException: connection exception: closed
at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source)
at org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(Unknown Source)
at org.hsqldb.jdbc.JDBCPreparedStatement.executeQuery(Unknown Source)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createProperties(DirectEpsgFactory.java:1011)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createEllipsoid(DirectEpsgFactory.java:1280)
... 51 more
Caused by: org.hsqldb.HsqlException: connection exception: closed
at org.hsqldb.error.Error.error(Unknown Source)
at org.hsqldb.Session.execute(Unknown Source)
... 55 more
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.389 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Results :
Tests in error:
testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'Ellipsoid' object for code "7019".
Tests run: 688, Failures: 0, Errors: 1, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
