See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/140/changes>
Changes:
[nuno.oliveira] Add params-extractor community module
[...truncated 10359 lines...]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sldservice ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1468 from nmco/community-params-extractor-2.8.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.02.2016 @ 16:34:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Feb-2016 11:06
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 11:15:35 UTC
[INFO] [GitCommitIdMojo] build.branch = dadb68472104744729ac9384fb7a2dc6d610504a
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = dadb684
[INFO] [GitCommitIdMojo] build.commit.id = dadb68472104744729ac9384fb7a2dc6d610504a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1468 from nmco/community-params-extractor-2.8.x
[GEOS-7399] Add extract-parameter community module (backport to 2.8.x)
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-sldservice ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/dependency/gt-api-14-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/dependency/gwc-core-1.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sldservice ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.8-SNAPSHOT/gs-sldservice-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Parameters Extractor 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-params-extractor ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/params-extractor/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-params-extractor ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-params-extractor ---
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 11:15:36 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-params-extractor ---
[INFO] Copying 5 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-params-extractor ---
[INFO] Compiling 13 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/params-extractor/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/params-extractor/src/main/java/org/geoserver/params/extractor/Rule.java>:\[10,16\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.524s]
[INFO] Core Platform Module .............................. SUCCESS [5.466s]
[INFO] Open Web Service Module ........................... SUCCESS [11.717s]
[INFO] Main Module ....................................... SUCCESS [33.372s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.362s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [6.423s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.491s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.266s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.921s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [7.423s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [9.033s]
[INFO] Web Feature Service Module ........................ SUCCESS [13.995s]
[INFO] Web Map Service Module ............................ SUCCESS [17.944s]
[INFO] KML support for GeoServer ......................... SUCCESS [8.327s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [17.239s]
[INFO] REST Support Module ............................... SUCCESS [5.672s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.033s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.227s]
[INFO] Core UI Module .................................... SUCCESS [13.833s]
[INFO] WMS UI Module ..................................... SUCCESS [6.626s]
[INFO] GWC UI Module ..................................... SUCCESS [8.410s]
[INFO] WFS UI Module ..................................... SUCCESS [4.805s]
[INFO] Demoes Module ..................................... SUCCESS [7.319s]
[INFO] WCS UI Module ..................................... SUCCESS [5.704s]
[INFO] Security UI Modules ............................... SUCCESS [0.299s]
[INFO] Security UI Core Module ........................... SUCCESS [9.736s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.711s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.400s]
[INFO] REST UI Module .................................... SUCCESS [4.929s]
[INFO] GeoServer Web Application ......................... SUCCESS [10.756s]
[INFO] Community Space ................................... SUCCESS [1.412s]
[INFO] Authentication by unique url key .................. SUCCESS [10.596s]
[INFO] WorldWind Format Module ........................... SUCCESS [5.922s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [4.475s]
[INFO] SpatiaLite Extension .............................. SUCCESS [8.411s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [7.021s]
[INFO] Simple Feature Service ............................ SUCCESS [4.808s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.704s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.510s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.220s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.155s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.358s]
[INFO] Core Scripting Extension .......................... SUCCESS [6.632s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [5.698s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [4.760s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [35.851s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.353s]
[INFO] Python Scripting Extension ........................ SUCCESS [6.987s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [6.301s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [4.650s]
[INFO] WMS-EO ............................................ SUCCESS [6.395s]
[INFO] ColorMap .......................................... SUCCESS [5.039s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.443s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.568s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.124s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [5.851s]
[INFO] REST plugin community module ...................... SUCCESS [5.100s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [4.932s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.021s]
[INFO] DownloadProcess ................................... SUCCESS [6.323s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [3.600s]
[INFO] ActiveMQ .......................................... SUCCESS [7.565s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [4.039s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [15.902s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [6.063s]
[INFO] Solr Module ....................................... SUCCESS [6.087s]
[INFO] Resumable REST Upload module ...................... SUCCESS [5.296s]
[INFO] GeoFence security integration ..................... SUCCESS [6.540s]
[INFO] GeoFence Server ................................... SUCCESS [13.288s]
[INFO] REST SLD service .................................. SUCCESS [5.991s]
[INFO] Parameters Extractor .............................. FAILURE [2.943s]
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoGig GeoServer integration ...................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:52.169s
[INFO] Finished at: Sat Feb 06 11:15:38 UTC 2016
[INFO] Final Memory: 119M/259M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-params-extractor: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-params-extractor
