Jody,
is this a Boundless repo problem?
Kind regards,
Ben.
On 17/03/16 12:14, monitor@anonymised.com wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/180/changes>
Changes:
[ridethepenguin] [GEOS-7459] Securing an app-schema data store may result in ClassCastException being thrown
[...truncated 9595 lines...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-rest-upload ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-rest-upload ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-rest-upload ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest-upload >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-rest-upload ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1532 from ridethepenguin/secureddatastoreinfo-bug-2.8.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 15.03.2016 @ 19:34:05 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Mar-2016 23:05
[INFO] [GitCommitIdMojo] build.build.time = 16.03.2016 @ 23:14:30 UTC
[INFO] [GitCommitIdMojo] build.branch = 8dae366ad0836e4b6f425c2b86a2603971b0930d
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8dae366
[INFO] [GitCommitIdMojo] build.commit.id = 8dae366ad0836e4b6f425c2b86a2603971b0930d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1532 from ridethepenguin/secureddatastoreinfo-bug-2.8.x
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest-upload <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest-upload ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest-upload >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest-upload <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest-upload ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-rest-upload ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/dependency/gt-api-14-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/dependency/gwc-core-1.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-rest-upload ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoFence security integration 2.8-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/geofence/geofence/3.1-SNAPSHOT/geofence-3.1-20160316.213329-32.pom
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.386s]
[INFO] Core Platform Module .............................. SUCCESS [7.707s]
[INFO] Open Web Service Module ........................... SUCCESS [17.022s]
[INFO] Main Module ....................................... SUCCESS [32.866s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.353s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [6.176s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.279s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.055s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [7.911s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [7.440s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [9.033s]
[INFO] Web Feature Service Module ........................ SUCCESS [13.977s]
[INFO] Web Map Service Module ............................ SUCCESS [17.474s]
[INFO] KML support for GeoServer ......................... SUCCESS [7.973s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [9.490s]
[INFO] REST Support Module ............................... SUCCESS [5.685s]
[INFO] REST Configuration Service Module ................. SUCCESS [10.703s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.159s]
[INFO] Core UI Module .................................... SUCCESS [13.579s]
[INFO] WMS UI Module ..................................... SUCCESS [6.413s]
[INFO] GWC UI Module ..................................... SUCCESS [9.164s]
[INFO] WFS UI Module ..................................... SUCCESS [4.970s]
[INFO] Demoes Module ..................................... SUCCESS [6.968s]
[INFO] WCS UI Module ..................................... SUCCESS [5.551s]
[INFO] Security UI Modules ............................... SUCCESS [0.194s]
[INFO] Security UI Core Module ........................... SUCCESS [9.732s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.702s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.270s]
[INFO] REST UI Module .................................... SUCCESS [4.876s]
[INFO] GeoServer Web Application ......................... SUCCESS [19.602s]
[INFO] Community Space ................................... SUCCESS [0.112s]
[INFO] Authentication by unique url key .................. SUCCESS [14.480s]
[INFO] WorldWind Format Module ........................... SUCCESS [7.907s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.882s]
[INFO] SpatiaLite Extension .............................. SUCCESS [5.404s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [7.171s]
[INFO] Simple Feature Service ............................ SUCCESS [4.974s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.566s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.698s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.368s]
[INFO] Web Processing Service Module ..................... SUCCESS [13.380s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.618s]
[INFO] Core Scripting Extension .......................... SUCCESS [6.624s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [6.163s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [5.205s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [26.865s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.757s]
[INFO] Python Scripting Extension ........................ SUCCESS [6.755s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [8.185s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [5.003s]
[INFO] WMS-EO ............................................ SUCCESS [7.392s]
[INFO] ColorMap .......................................... SUCCESS [5.482s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.230s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [6.534s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [4.279s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [5.842s]
[INFO] REST plugin community module ...................... SUCCESS [5.183s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [5.253s]
[INFO] KML PPIO for WPS .................................. SUCCESS [5.960s]
[INFO] DownloadProcess ................................... SUCCESS [7.515s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.239s]
[INFO] ActiveMQ .......................................... SUCCESS [11.809s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [2.486s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [21.030s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [6.377s]
[INFO] Solr Module ....................................... SUCCESS [6.098s]
[INFO] Resumable REST Upload module ...................... SUCCESS [5.266s]
[INFO] GeoFence security integration ..................... FAILURE [1.201s]
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Parameters Extractor .............................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoGig GeoServer integration ...................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:38.821s
[INFO] Finished at: Wed Mar 16 23:14:31 UTC 2016
[INFO] Final Memory: 566M/683M
[ERROR] Failed to execute goal on project gs-geofence: Could not resolve dependencies for project org.geoserver.community:gs-geofence:jar:2.8-SNAPSHOT: Failed to collect dependencies for [org.geoserver:gs-main:jar:2.8-SNAPSHOT (compile), org.geoserver.web:gs-web-core:jar:2.8-SNAPSHOT (compile), org.geoserver.web:gs-web-sec-core:jar:2.8-SNAPSHOT (compile), org.geoserver:gs-wms:jar:2.8-SNAPSHOT (compile), org.geoserver.geofence:geofence-services-api:jar:3.1-SNAPSHOT (compile), org.geoserver.geofence:geofence-model:jar:3.1-SNAPSHOT (compile), org.geoserver:gs-rest:jar:2.8-SNAPSHOT (compile), com.google.guava:guava:jar:17.0 (compile), org.geoserver:gs-main:jar:tests:2.8-SNAPSHOT (test), org.geoserver.web:gs-web-core:jar:tests:2.8-SNAPSHOT (test), org.springframework:spring-expression:jar:3.1.4.RELEASE (compile), org.springframework:spring-web:jar:3.1.4.RELEASE (compile), com.mockrunner:mockrunner:jar:0.3.6 (test), junit:junit:jar:4.11 (test), xmlunit:xmlunit:jar:1.3 (test), org.geoserve
r:gs-wfs:jar:2.8-SNAPSHOT (test), org.geoserver:gs-platform:jar:2.8-SNAPSHOT (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), org.geowebcache:gwc-core:jar:1.8-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.geoserver.geofence:geofence-services-api:jar:3.1-SNAPSHOT: Could not find artifact org.geoserver.geofence:geofence:pom:3.1-20160316.213329-32 in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
