[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x-nightly #185
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/185/changes&gt;
Changes:
[ben] Upgrade git-commit-id-plugin to 2.2.0
[...truncated 90 lines...]
[INFO] GeoServer GeoPackage Extension
[INFO] PGRaster DataStore Extension for automatic configuration
[INFO] Dynamic WMS dimension value defaults
[INFO] REST plugin community module
[INFO] GPX PPIO for WPS
[INFO] KML PPIO for WPS
[INFO] DownloadProcess
[INFO] GeoServer JMS based clustering modules
[INFO] ActiveMQ
[INFO] GeoServer JMS clustering Commons module
[INFO] GeoServer JMS clustering module
[INFO] GeoServer Hazelcast Clustering Module
[INFO] Solr Module
[INFO] Resumable REST Upload module
[INFO] GeoFence security integration
[INFO] GeoFence Server
[INFO] REST SLD service
[INFO] Parameters Extractor
[INFO] GWC Distributed Caching Plugin
[INFO] GeoWebCache S3
[INFO] OGR parent
[INFO] OGR CORE
[INFO] GDAL translate parent
[INFO] GDAL translate WCS
[INFO] GDAL translate WPS
[INFO] GeoGig GeoServer integration
[INFO] GeoServer Community Release Module
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] OGR WFS
[INFO] OGR WPS
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web process status sharing with Hazelcast
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Release Module
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geoserver ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ geoserver ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [0.764s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Parameters Extractor .............................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoGig GeoServer integration ...................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4.565s
[INFO] Finished at: Sat Mar 19 23:12:53 UTC 2016
[INFO] Final Memory: 46M/307M
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.2.0:revision (default) on project geoserver: The plugin pl.project13.maven:git-commit-id-plugin:2.2.0 requires Maven version [3.1.1,) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginIncompatibleException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/186/changes&gt;
Changes:
[ben] Downgrade git-commit-id-plugin to 2.1.13 to fix the build on Maven 3.0.4
[...truncated 5648 lines...]
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml (958 B at 4.8 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
958/958 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml (958 B at 3.2 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-xml/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-xml/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-xml/13-SNAPSHOT/maven-metadata.xml
949/949 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-xml/13-SNAPSHOT/maven-metadata.xml (949 B at 3.7 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/maven-metadata.xml (957 B at 5.2 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.wfs/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wfs/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wfs/13-SNAPSHOT/maven-metadata.xml
962/962 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wfs/13-SNAPSHOT/maven-metadata.xml (962 B at 3.4 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-render/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-render/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-render/13-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-render/13-SNAPSHOT/maven-metadata.xml (2 KB at 3.8 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-shapefile/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-shapefile/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/13-SNAPSHOT/maven-metadata.xml
955/955 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/13-SNAPSHOT/maven-metadata.xml (955 B at 3.5 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-geotiff/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geotiff/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geotiff/13-SNAPSHOT/maven-metadata.xml
953/953 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geotiff/13-SNAPSHOT/maven-metadata.xml (953 B at 5.2 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-transform/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-transform/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-transform/13-SNAPSHOT/maven-metadata.xml
955/955 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-transform/13-SNAPSHOT/maven-metadata.xml (955 B at 3.0 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-image/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-image/13-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-image/13-SNAPSHOT/maven-metadata.xml
951/951 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-image/13-SNAPSHOT/maven-metadata.xml (951 B at 4.6 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/org.w3.xlink/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-fes/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.fes/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.jar
Downloading: http://repo.maven.apache.org/maven2/javax/media/jai_core/1.1.3/jai_core-1.1.3.jar
Downloading: http://repo.maven.apache.org/maven2/javax/media/jai_codec/1.1.3/jai_codec-1.1.3.jar
Downloading: http://repo.maven.apache.org/maven2/javax/media/jai_imageio/1.1/jai_imageio-1.1.jar
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.520s]
[INFO] Core Platform Module .............................. SUCCESS [9.961s]
[INFO] Open Web Service Module ........................... SUCCESS [11.932s]
[INFO] Main Module ....................................... SUCCESS [27.756s]
[INFO] GeoServer Security Modules ........................ SUCCESS [5.008s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [11.161s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [9.930s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.772s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [11.698s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [12.314s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [14.361s]
[INFO] Web Feature Service Module ........................ SUCCESS [19.143s]
[INFO] Web Map Service Module ............................ SUCCESS [19.562s]
[INFO] KML support for GeoServer ......................... SUCCESS [13.252s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [13.935s]
[INFO] REST Support Module ............................... SUCCESS [10.416s]
[INFO] REST Configuration Service Module ................. SUCCESS [14.680s]
[INFO] GeoServer Web Modules ............................. SUCCESS [4.815s]
[INFO] Core UI Module .................................... SUCCESS [18.139s]
[INFO] WMS UI Module ..................................... SUCCESS [11.345s]
[INFO] GWC UI Module ..................................... SUCCESS [13.336s]
[INFO] WFS UI Module ..................................... SUCCESS [9.544s]
[INFO] Demoes Module ..................................... SUCCESS [11.669s]
[INFO] WCS UI Module ..................................... SUCCESS [10.355s]
[INFO] Security UI Modules ............................... SUCCESS [4.798s]
[INFO] Security UI Core Module ........................... SUCCESS [14.525s]
[INFO] Security UI JDBC Module ........................... SUCCESS [10.320s]
[INFO] Security UI LDAP Module ........................... SUCCESS [10.427s]
[INFO] REST UI Module .................................... SUCCESS [9.561s]
[INFO] GeoServer Web Application ......................... SUCCESS [12.976s]
[INFO] Community Space ................................... SUCCESS [8.577s]
[INFO] Authentication by unique url key .................. SUCCESS [28.204s]
[INFO] WorldWind Format Module ........................... SUCCESS [10.441s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [7.410s]
[INFO] SpatiaLite Extension .............................. SUCCESS [10.720s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [11.939s]
[INFO] Simple Feature Service ............................ SUCCESS [9.393s]
[INFO] Aggregating Data Store ............................ SUCCESS [7.953s]
[INFO] GeoServer Extensions .............................. SUCCESS [4.723s]
[INFO] Web Processing Service parent ..................... SUCCESS [4.683s]
[INFO] Web Processing Service Module ..................... SUCCESS [16.596s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [4.870s]
[INFO] Core Scripting Extension .......................... SUCCESS [11.896s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [10.234s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [9.521s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [34.678s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.145s]
[INFO] Python Scripting Extension ........................ SUCCESS [16.329s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [12.360s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [9.334s]
[INFO] WMS-EO ............................................ SUCCESS [11.104s]
[INFO] ColorMap .......................................... SUCCESS [9.502s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [10.726s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [10.520s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [7.426s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [10.378s]
[INFO] REST plugin community module ...................... SUCCESS [9.963s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [9.631s]
[INFO] KML PPIO for WPS .................................. SUCCESS [9.678s]
[INFO] DownloadProcess ................................... SUCCESS [10.673s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [8.033s]
[INFO] ActiveMQ .......................................... SUCCESS [13.319s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [7.024s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [25.894s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [11.222s]
[INFO] Solr Module ....................................... SUCCESS [10.152s]
[INFO] Resumable REST Upload module ...................... SUCCESS [9.545s]
[INFO] GeoFence security integration ..................... SUCCESS [12.764s]
[INFO] GeoFence Server ................................... SUCCESS [21.007s]
[INFO] REST SLD service .................................. SUCCESS [10.592s]
[INFO] Parameters Extractor .............................. FAILURE [8.054s]
[INFO] Total time: 14:11.218s
[INFO] Finished at: Sun Mar 20 08:02:58 UTC 2016
[INFO] Final Memory: 198M/491M
[ERROR] Failed to execute goal on project gs-params-extractor: Could not resolve dependencies for project org.geoserver.community:gs-params-extractor:jar:2.8-SNAPSHOT: The following artifacts could not be resolved: org.wicketstuff:htmlvalidator:jar:1.2, javax.media:jai_core:jar:1.1.3, javax.media:jai_codec:jar:1.1.3, javax.media:jai_imageio:jar:1.1: Could not find artifact org.wicketstuff:htmlvalidator:jar:1.2 in central (http://repo.maven.apache.org/maven2) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-params-extractor
Why is a 2.8.x build downloading GeoTools 13-SNAPSHOT artifacts? GeoServer 2.8.x should depend on GeoTools 14.x.
-------- Forwarded Message --------
Subject: [Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x-nightly #186
Date: Sun, 20 Mar 2016 08:02:59 +0000 (UTC)
Reply-To: Jenkins <monitor@anonymised.com>
To: geoserver-devel@lists.sourceforge.net
Changes:
958/958 B
949/949 B
957/957 B
962/962 B
2/2 KB
955/955 B
953/953 B
955/955 B
951/951 B
[INFO]
[INFO]
[ERROR]
[ERROR]
[ERROR]
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Ah, params-extractor, can anyone see anything wrong here? Yes, cross branch dependency:
     <parent>
         <groupId>org.geoserver</groupId>
         <artifactId>community</artifactId>
         <version>2.7-SNAPSHOT</version>
     </parent>
     <groupId>org.geoserver.community</groupId>
     <artifactId>gs-params-extractor</artifactId>
     <packaging>jar</packaging>
     <version>2.8-SNAPSHOT</version>
     <name>Parameters Extractor</name>
I will fix it.
See
Changes:
3.0.4
Downloaded:
Downloading:
Downloading:
Downloading:
958/958 B
Downloaded:
Downloading:
Downloading:
Downloading:
949/949 B
Downloaded:
Downloading:
Downloading:
Downloading:
957/957 B
Downloaded:
Downloading:
Downloading:
Downloading:
962/962 B
Downloaded:
Downloading:
Downloading:
Downloading:
2/2 KB
Downloaded:
Downloading:
Downloading:
Downloading:
955/955 B
Downloaded:
Downloading:
Downloading:
Downloading:
953/953 B
Downloaded:
Downloading:
Downloading:
Downloading:
955/955 B
Downloaded:
Downloading:
Downloading:
Downloading:
951/951 B
Downloaded:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[7.426s]
   SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
Director
New Zealand
Ben,
thanks for taking care of it.
Nuno, please be more careful with code ports across branches
On Sun, Mar 20, 2016 at 9:42 AM, Ben Caradoc-Davies <ben@anonymised.com1…> wrote:
branch dependency:
org.geoserver community 2.7-SNAPSHOT
gs-params-extractor
jar
2.8-SNAPSHOT
I will fix it.
See
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/186/changes>
Changes:
3.0.4
[…truncated 5648 lines…]
Downloaded:
Downloading:
Downloading:
Downloading:
958/958 B
Downloaded:
Downloading:
Downloading:
Downloading:
949/949 B
Downloaded:
Downloading:
Downloading:
Downloading:
957/957 B
Downloaded:
Downloading:
Downloading:
Downloading:
962/962 B
Downloaded:
Downloading:
Downloading:
Downloading:
2/2 KB
Downloaded:
Downloading:
Downloading:
Downloading:
955/955 B
Downloaded:
Downloading:
Downloading:
Downloading:
953/953 B
Downloaded:
Downloading:
Downloading:
Downloading:
955/955 B
Downloaded:
Downloading:
Downloading:
Downloading:
951/951 B
Downloaded:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
Downloading:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer … SUCCESS [12.520s]
[INFO] Core Platform Module … SUCCESS [9.961s]
[INFO] Open Web Service Module … SUCCESS [11.932s]
[INFO] Main Module … SUCCESS [27.756s]
[INFO] GeoServer Security Modules … SUCCESS [5.008s]
[INFO] GeoServer JDBC Security Module … SUCCESS [11.161s]
[INFO] GeoServer LDAP Security Module … SUCCESS [9.930s]
[INFO] Web Coverage Service Module … SUCCESS [7.772s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [11.698s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [12.314s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [14.361s]
[INFO] Web Feature Service Module … SUCCESS [19.143s]
[INFO] Web Map Service Module … SUCCESS [19.562s]
[INFO] KML support for GeoServer … SUCCESS [13.252s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [13.935s]
[INFO] REST Support Module … SUCCESS [10.416s]
[INFO] REST Configuration Service Module … SUCCESS [14.680s]
[INFO] GeoServer Web Modules … SUCCESS [4.815s]
[INFO] Core UI Module … SUCCESS [18.139s]
[INFO] WMS UI Module … SUCCESS [11.345s]
[INFO] GWC UI Module … SUCCESS [13.336s]
[INFO] WFS UI Module … SUCCESS [9.544s]
[INFO] Demoes Module … SUCCESS [11.669s]
[INFO] WCS UI Module … SUCCESS [10.355s]
[INFO] Security UI Modules … SUCCESS [4.798s]
[INFO] Security UI Core Module … SUCCESS [14.525s]
[INFO] Security UI JDBC Module … SUCCESS [10.320s]
[INFO] Security UI LDAP Module … SUCCESS [10.427s]
[INFO] REST UI Module … SUCCESS [9.561s]
[INFO] GeoServer Web Application … SUCCESS [12.976s]
[INFO] Community Space … SUCCESS [8.577s]
[INFO] Authentication by unique url key … SUCCESS [28.204s]
[INFO] WorldWind Format Module … SUCCESS [10.441s]
[INFO] GeoServer Embedded FTP server … SUCCESS [7.410s]
[INFO] SpatiaLite Extension … SUCCESS [10.720s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [11.939s]
[INFO] Simple Feature Service … SUCCESS [9.393s]
[INFO] Aggregating Data Store … SUCCESS [7.953s]
[INFO] GeoServer Extensions … SUCCESS [4.723s]
[INFO] Web Processing Service parent … SUCCESS [4.683s]
[INFO] Web Processing Service Module … SUCCESS [16.596s]
[INFO] GeoServer Scripting Extensions … SUCCESS [4.870s]
[INFO] Core Scripting Extension … SUCCESS [11.896s]
[INFO] Web UI Scripting Extension … SUCCESS [10.234s]
[INFO] BeanShell Scripting Extension … SUCCESS [9.521s]
[INFO] Groovy Scripting Extension … SUCCESS [34.678s]
[INFO] H2 DataStore Extension … SUCCESS [10.145s]
[INFO] Python Scripting Extension … SUCCESS [16.329s]
[INFO] JavaScript Scripting Extension … SUCCESS [12.360s]
[INFO] Ruby Scripting Extension … SUCCESS [9.334s]
[INFO] WMS-EO … SUCCESS [11.104s]
[INFO] ColorMap … SUCCESS [9.502s]
[INFO] GeoServer mbtiles Extension … SUCCESS [10.726s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [10.520s]
[7.426s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [10.378s]
[INFO] REST plugin community module … SUCCESS [9.963s]
[INFO] GPX PPIO for WPS … SUCCESS [9.631s]
[INFO] KML PPIO for WPS … SUCCESS [9.678s]
[INFO] DownloadProcess … SUCCESS [10.673s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [8.033s]
[INFO] ActiveMQ … SUCCESS [13.319s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [7.024s]
[INFO] GeoServer JMS clustering module … SUCCESS [25.894s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [11.222s]
[INFO] Solr Module … SUCCESS [10.152s]
[INFO] Resumable REST Upload module … SUCCESS [9.545s]
[INFO] GeoFence security integration … SUCCESS [12.764s]
[INFO] GeoFence Server … SUCCESS [21.007s]
[INFO] REST SLD service … SUCCESS [10.592s]
[INFO] Parameters Extractor … FAILURE [8.054s]
[INFO] GWC Distributed Caching Plugin … SKIPPED
[INFO] GeoWebCache S3 … SKIPPED
[INFO] OGR parent … SKIPPED
[INFO] OGR CORE … SKIPPED
[INFO] GDAL translate parent … SKIPPED
[INFO] GDAL translate WCS … SKIPPED
[INFO] GDAL translate WPS … SKIPPED
[INFO] GeoGig GeoServer integration … SKIPPED
[INFO] GeoServer Community Release Module … SKIPPED
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] GeoSearch Index Module … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] GeoServer Release Module … SKIPPED
[INFO]
[INFO]
[INFO]
(http://repo.maven.apache.org/maven2) → [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
[ERROR] mvn -rf :gs-params-extractor
Build step ‘Invoke top-level Maven targets’ marked build as failure
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/187/changes&gt;
