See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/258/changes>
Changes:
[daniele.romagnoli] [GEOS-7465]: Updating GDAL documentation with notes on Vector Footprint
[andrea.aime] [GEOS-7549] XSS: Reflected Cross Site Script Vulnerability
[andrea.aime] Fixing build, 2.8.x is still stuck on mockrunner
[...truncated 2973 lines...]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-script-bsh >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-script-bsh ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-script-bsh <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-script-bsh >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-script-bsh <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-script-bsh ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/dependency/gt-api-14-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/dependency/gwc-core-1.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-script-bsh ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.8-SNAPSHOT/gs-script-bsh-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.8-SNAPSHOT/gs-script-bsh-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.8-SNAPSHOT/gs-script-bsh-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.8-SNAPSHOT/gs-script-bsh-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.8-SNAPSHOT/gs-script-bsh-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Groovy Scripting Extension 2.8-SNAPSHOT
Downloading: http://maven.geo-solutions.it/org/geoscript/geoscript-groovy/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoscript/geoscript-groovy/1.7-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geoscript/geoscript-groovy/1.7-SNAPSHOT/maven-metadata.xml
927/927 B
Downloaded: https://repo.boundlessgeo.com/main/org/geoscript/geoscript-groovy/1.7-SNAPSHOT/maven-metadata.xml (927 B at 3.1 KB/sec)
[WARNING] Could not transfer metadata org.geoscript:geoscript-groovy:1.7-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geoscript:geoscript-groovy:1.7-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geoscript:geoscript-groovy:1.7-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: https://repo.boundlessgeo.com/main/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
Downloading: http://download.osgeo.org/webdav/geotools/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
Downloading: http://maven.restlet.org/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
Downloading: http://www.hibernatespatial.org/repository/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
May 24, 2016 4:32:49 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http://www.hibernatespatial.org:80: Connection reset
INFO: Retrying request to {}->http://www.hibernatespatial.org:80
Downloading: http://maven.geo-solutions.it/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
Downloading: https://repo.maven.apache.org/maven2/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
Downloading: https://repo.boundlessgeo.com/main/org/geotools/extension/15-SNAPSHOT/extension-15-20160524.145634-70.pom
3/3 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/extension/15-SNAPSHOT/extension-15-20160524.145634-70.pom (3 KB at 5.9 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/unsupported/15-SNAPSHOT/unsupported-15-20160524.145827-66.pom
4/7 KB
7/7 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/unsupported/15-SNAPSHOT/unsupported-15-20160524.145827-66.pom (7 KB at 38.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-swing/15-SNAPSHOT/gt-swing-15-20160524.145834-66.pom
4/5 KB
5/5 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-swing/15-SNAPSHOT/gt-swing-15-20160524.145834-66.pom (5 KB at 30.9 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-grassraster/15-SNAPSHOT/gt-grassraster-15-20160524.145731-67.pom
4/4 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-grassraster/15-SNAPSHOT/gt-grassraster-15-20160524.145731-67.pom (4 KB at 12.9 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/ogc/15-SNAPSHOT/ogc-15-20160524.145705-70.pom
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/ogc/15-SNAPSHOT/ogc-15-20160524.145705-70.pom (2 KB at 11.8 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/gt-ogr-15-20160524.145753-66.pom
4/4 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/gt-ogr-15-20160524.145753-66.pom (4 KB at 14.4 KB/sec)
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.516 s]
[INFO] Core Platform Module ............................... SUCCESS [ 4.942 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.904 s]
[INFO] Main Module ........................................ SUCCESS [ 22.287 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.115 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.709 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.072 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.003 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 6.578 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 7.543 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 9.067 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 13.301 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 15.457 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.785 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.032 s]
[INFO] REST Support Module ................................ SUCCESS [ 5.575 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.113 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.038 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.685 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.634 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 8.207 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.704 s]
[INFO] Demoes Module ...................................... SUCCESS [ 6.291 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.511 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.069 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.668 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 5.293 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 5.111 s]
[INFO] REST UI Module ..................................... SUCCESS [ 4.580 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 9.800 s]
[INFO] Community Space .................................... SUCCESS [ 0.048 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 20.411 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 10.718 s]
[INFO] GeoServer Embedded FTP server ...................... SUCCESS [ 2.363 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.272 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.883 s]
[INFO] Simple Feature Service ............................. SUCCESS [ 4.754 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.025 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.033 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.917 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.233 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.862 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.639 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.642 s]
[INFO] Groovy Scripting Extension ......................... FAILURE [07:03 min]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:15 min
[INFO] Finished at: 2016-05-24T16:33:55+00:00
[INFO] Final Memory: 146M/381M
[ERROR] Failed to execute goal on project gs-script-groovy: Could not resolve dependencies for project org.geoserver.script:gs-script-groovy:jar:2.8-SNAPSHOT: Failed to collect dependencies at org.geoscript:geoscript-groovy:jar:1.7-SNAPSHOT -> no.ecc.vectortile:java-vector-tile:jar:1.0.9: Failed to read artifact descriptor for no.ecc.vectortile:java-vector-tile:jar:1.0.9: Could not transfer artifact no.ecc.vectortile:java-vector-tile:pom:1.0.9 from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-script-groovy
