[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x-nightly #29
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x-nightly/29/&gt;
[...truncated 169 lines...]
[INFO] GPX PPIO for WPS
[INFO] KML PPIO for WPS
[INFO] DownloadProcess
[INFO] GeoServer JMS based clustering modules
[INFO] ActiveMQ
[INFO] GeoServer JMS clustering Commons module
[INFO] GeoServer JMS clustering module
[INFO] GeoServer Hazelcast Clustering Module
[INFO] Solr Module
[INFO] Resumable REST Upload module
[INFO] GeoFence security integration
[INFO] GeoFence Server
[INFO] REST SLD service
[INFO] GWC Distributed Caching Plugin
[INFO] GeoWebCache S3
[INFO] OGR parent
[INFO] OGR CORE
[INFO] GDAL translate parent
[INFO] GDAL translate WCS
[INFO] GDAL translate WPS
[INFO] GeoServer Community Release Module
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] OGR WFS
[INFO] OGR WPS
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web process status sharing with Hazelcast
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Release Module
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/library-14-20151025.164540-14.pom
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geowebcache:gwc-core:1.8-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
[WARNING] Failure to transfer org.geowebcache:gwc-core:1.8-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geowebcache:gwc-core:1.8-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geowebcache/gwc\-core/1\.8\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 502, ReasonPhrase:Bad Gateway.
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geowebcache:geowebcache:1.8-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [5:00.884s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:09.504s
[INFO] Finished at: Sun Oct 25 18:21:40 UTC 2015
[INFO] Final Memory: 41M/241M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.8-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), junit:junit:jar:4.11 (test), org.geowebcache:gwc-core:jar:1.8-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:14-SNAPSHOT: Could not transfer artifact org.geotools:library:pom:14-20151025.164540-14 from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/library-14-20151025.164540-14.pom. Return code is: 502, ReasonPhrase:Bad Gateway. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x-nightly/30/&gt;
[...truncated 186 lines...]
[INFO] OGR WFS
[INFO] OGR WPS
[INFO] DXF WPS PPIO
[INFO]
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml. Return code is: 504, ReasonPhrase:Gateway Time-out.
[WARNING] Failure to transfer org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/gt\-api/14\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 504, ReasonPhrase:Gateway Time-out.
Downloading: http://www.hibernatespatial.org/repository/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml. Return code is: 504, ReasonPhrase:Gateway Time-out.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml. Return code is: 502, ReasonPhrase:Bad Gateway.
[WARNING] Failure to transfer org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:14-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/gt\-main/14\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 502, ReasonPhrase:Bad Gateway.
[INFO]
[INFO]
[INFO] GeoServer ......................................... FAILURE [12:01.178s]
[INFO] Total time: 12:11.754s
[INFO] Finished at: Mon Oct 26 09:00:49 UTC 2015
[INFO] Final Memory: 41M/252M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.8-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:14-SNAPSHOT (compile), org.geotools:gt-main:jar:14-SNAPSHOT (compile), junit:junit:jar:4.11 (test), org.geowebcache:gwc-core:jar:1.8-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:14-SNAPSHOT: Could not transfer artifact org.geotools:library:pom:14-20151025.164540-14 from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/library-14-20151025.164540-14.pom. Return code is: 504, ReasonPhrase:Gateway Time-out. -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x-nightly/31/changes&gt;
