[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x-nightly #321
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/321/changes&gt;
Changes:
[emerkle] Align plugin for GeoGig REST implementation with GeoGig Web API
[...truncated 5028 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/rest-upload/target/gs-rest-upload-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-rest-upload/2.8-SNAPSHOT/gs-rest-upload-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoFence security integration 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-geofence ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geofence ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-geofence ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geofence ---
[INFO] Copying 2 resources
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geofence ---
[INFO] Compiling 21 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geofence ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geofence ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-geofence ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-geofence >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-geofence <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-geofence ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-geofence >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-geofence <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-geofence ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-geofence ---
[INFO] Copying gt-api-14-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/dependency/gt-api-14-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.8-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/dependency/gwc-core-1.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-geofence/2.8-SNAPSHOT/gs-geofence-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-geofence/2.8-SNAPSHOT/gs-geofence-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-geofence/2.8-SNAPSHOT/gs-geofence-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-geofence/2.8-SNAPSHOT/gs-geofence-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/ws/src/community/geofence/target/gs-geofence-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-geofence/2.8-SNAPSHOT/gs-geofence-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoFence Server 2.8-SNAPSHOT
Downloading: http://wicket-dnd.googlecode.com/svn/repo/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: https://repo.boundlessgeo.com/main/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: http://maven.restlet.org/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: http://maven.geo-solutions.it/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: https://repo.maven.apache.org/maven2/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: http://wicketstuff.org/maven/repository/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
Downloading: http://download.java.net/maven/2/org/wicketstuff/prototype/1.4.1/prototype-1.4.1.pom
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.280 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.384 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.852 s]
[INFO] Main Module ........................................ SUCCESS [ 29.269 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.270 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 6.954 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.238 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.015 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 7.646 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 7.821 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 10.104 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 15.732 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 15.906 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 8.212 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 10.915 s]
[INFO] REST Support Module ................................ SUCCESS [ 5.648 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 10.118 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.109 s]
[INFO] Core UI Module ..................................... SUCCESS [ 14.304 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.511 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 8.879 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.268 s]
[INFO] Demoes Module ...................................... SUCCESS [ 10.200 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.810 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.113 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 11.024 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 5.762 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 9.206 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.748 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 15.540 s]
[INFO] Community Space .................................... SUCCESS [ 6.080 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 39.695 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 9.932 s]
[INFO] GeoServer Embedded FTP server ...................... SUCCESS [ 5.510 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [01:07 min]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.315 s]
[INFO] Simple Feature Service ............................. SUCCESS [ 5.194 s]
[INFO] Aggregating Data Store ............................. SUCCESS [01:06 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.072 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.125 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 11.956 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.127 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.757 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.157 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.859 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [01:40 min]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 4.418 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.919 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [02:12 min]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.838 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.436 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.900 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [01:08 min]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.837 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.662 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.420 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.310 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.926 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.999 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.271 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.417 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 5.628 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 5.026 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 17.768 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.999 s]
[INFO] Solr Module ........................................ SUCCESS [01:07 min]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.915 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 6.392 s]
[INFO] GeoFence Server .................................... FAILURE [01:07 min]
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:47 min
[INFO] Finished at: 2016-07-26T16:51:14+00:00
[INFO] Final Memory: 168M/361M
[ERROR] Failed to execute goal on project gs-geofence-server: Could not resolve dependencies for project org.geoserver.community:gs-geofence-server:jar:2.8-SNAPSHOT: Failed to collect dependencies at wicket-dnd:wicket-dnd:jar:0.4.2 -> org.wicketstuff:prototype:jar:1.4.1: Failed to read artifact descriptor for org.wicketstuff:prototype:jar:1.4.1: Could not transfer artifact org.wicketstuff:prototype:pom:1.4.1 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x-nightly/322/&gt;
