See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wfs/128/changes>
Changes:
[andrea.aime] [GEOS-7297] Fix issue where Stored Queries fail under load.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building Web Feature Service Module 2.8-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml (966 B at 0.3 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wfs ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wfs/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wfs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wfs ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-2.8.x\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7297] Fix issue where Stored Queries fail under load.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.12.2015 @ 11:35:58 CET
[INFO] [GitCommitIdMojo] build.timestamp = 20-dic-2015 11:38
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2015 @ 11:49:47 CET
[INFO] [GitCommitIdMojo] build.branch = b00ca479330fa16d5836b64db1b273c209b9ff03
[INFO] [GitCommitIdMojo] build.commit.user.email = dean.povey@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Dean Povey
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b00ca47
[INFO] [GitCommitIdMojo] build.commit.id = b00ca479330fa16d5836b64db1b273c209b9ff03
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7297] Fix issue where Stored Queries fail under load.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wfs ---
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wfs ---
[INFO] Compiling 249 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wfs/ws/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wfs ---
[INFO] Copying 32 resources
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wfs/ws/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wfs ---
[INFO] Compiling 90 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wfs/ws/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[87,78] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[97,78] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[115,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[129,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[141,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[177,66] error: cannot find symbol
[INFO] 6 errors
[JENKINS] Archiving disabled
