[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x » Web Map Service Module #117
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wms/117/changes&gt;
Changes:
[tbarsballe] [GEOS-7270]
[...truncated 529 lines...]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.543 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.792 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.963 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.385 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.073 sec
Running org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.121 sec
Running org.geoserver.wms.wms_1_1_1.GetCapabilitiesLegendURL_1_1_1Test
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.06 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoRestrictedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.31 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
Results for FeatureType 'http://www.opengis.net/cite:Forests’:
NAME = Green Forest
FID = 109
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.26 sec
Running org.geoserver.wms.wms_1_1_1.GetLegendGraphicTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.638 sec
Running org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest
Tests run: 44, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.537 sec
Running org.geoserver.wms.wms_1_1_1.GetStylesIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.341 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.229 sec
Running org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.467 sec
Running org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.451 sec
Running org.geoserver.wms.wms_1_1_1.WMSCascadeTest
Tests run: 3, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 1.03 sec <<< FAILURE!
testCascadeGetMapOnto110(org.geoserver.wms.wms_1_1_1.WMSCascadeTest) Time elapsed: 16 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[image/png]> but was:<[text/xml]>
  at org.junit.Assert.assertEquals(Assert.java:115)
  at org.junit.Assert.assertEquals(Assert.java:144)
  at org.geoserver.wms.WMSTestSupport.checkImage(WMSTestSupport.java:465)
  at org.geoserver.wms.wms_1_1_1.WMSCascadeTest.testCascadeGetMapOnto110(WMSCascadeTest.java:31)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
testCascadeGetMapOnto130(org.geoserver.wms.wms_1_1_1.WMSCascadeTest) Time elapsed: 16 sec <<< FAILURE!
  at org.geoserver.wms.wms_1_1_1.WMSCascadeTest.testCascadeGetMapOnto130(WMSCascadeTest.java:22)
Running org.geoserver.wms.wms_1_3.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.685 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.716 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.56 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesIntegrationTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.134 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.339 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.856 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.746 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.416 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.511 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.777 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.964 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.009 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.42 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 0.655 sec <<< FAILURE!
testCascadeGetMapOnto11(org.geoserver.wms.wms_1_3.WMSCascadeTest) Time elapsed: 483 sec <<< FAILURE!
  at org.geoserver.wms.wms_1_3.WMSCascadeTest.testCascadeGetMapOnto11(WMSCascadeTest.java:57)
testCascadeGetMapOnto13(org.geoserver.wms.wms_1_3.WMSCascadeTest) Time elapsed: 0 sec <<< FAILURE!
  at org.geoserver.wms.wms_1_3.WMSCascadeTest.testCascadeGetMapOnto13(WMSCascadeTest.java:48)
Results :
Failed tests: testIndexedTransparency(org.geoserver.wms.map.GetMapIntegrationTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  testFourBits(org.geoserver.wms.map.GetMapIntegrationTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  testCascadeGetMapOnto110(org.geoserver.wms.wms_1_1_1.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
  testCascadeGetMapOnto130(org.geoserver.wms.wms_1_1_1.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
  testCascadeGetMapOnto11(org.geoserver.wms.wms_1_3.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
  testCascadeGetMapOnto13(org.geoserver.wms.wms_1_3.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
Tests run: 695, Failures: 6, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wms/118/&gt;
