[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x » Web Map Service Module #134
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wms/134/&gt;
[...truncated 215 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.048 sec
Running org.geoserver.wms.dimension.RasterCustomDimensionDefaultValueTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.201 sec
Running org.geoserver.wms.dimension.RasterElevationDimensionDefaultValueTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.616 sec
Running org.geoserver.wms.dimension.RasterTimeDimensionDefaultValueTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.172 sec
Running org.geoserver.wms.dimension.VectorCustomDimensionDefaultValueTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec
Running org.geoserver.wms.dimension.VectorElevationDimensionDefaultValueTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.658 sec
Running org.geoserver.wms.dimension.VectorTimeDimensionDefaultValueTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.993 sec
Running org.geoserver.wms.featureinfo.DynamicSizeStyleExtractorTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Running org.geoserver.wms.featureinfo.FeatureDescriptionTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.wms.featureinfo.FeatureTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.42 sec
Running org.geoserver.wms.featureinfo.GetFeatureInfoJSONTest
24 dic 17:53:46 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293897940763840'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293897944339015'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898113588947'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898116759183'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898320817101'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898323995717'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898436819484'
24 dic 17:53:46 ERROR [geotools.data] - Unclosed transaction handle is 'MosaicCreationTransaction293898443623840'
Results for FeatureType 'http://www.opengis.net/cite:Forests’:
NAME = Green Forest
FID = 109
Tests run: 38, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.384 sec
Running org.geoserver.wms.featureinfo.HTMLFeatureInfoOutputFormatTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.131 sec
Running org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest
Query:
   feature type: Bridges
   filter: [ the_geom intersects POLYGON ((0.00019952 0.0006988, 0.00020032 0.0006988, 0.00020032 0.0006996, 0.00019952 0.0006996, 0.00019952 0.0006988)) ]
   [properties: ALL ]
The response iTESTs: {"type":"FeatureCollection","totalFeatures":"unknown","features":[{"type":"Feature","id":"Forests.1107531798144","geometry":{"type":"MultiPolygon","coordinates":[[[[-0.0014,-0.0024],[-0.0014,2.0E-4],[2.0E-4,7.0E-4],[0.0014,0.001],[0.0028,0.0014],[0.0042,0.0018],[0.0042,-0.0024],[-0.0014,-0.0024]]]]},"geometry_name":"the_geom","properties":{"FID":"109","NAME":"Green Forest","bbox":[-0.0014,-0.0024,0.0042,0.0018]}}],"crs":{"type":"name","properties":{"name":"urn:ogc:def:crs:EPSG::4326"}},"bbox":[-0.0014,-0.0024,0.0042,0.0018]}
Query:
   filter: [ the_geom intersects POLYGON ((0.0001968 0.0006942, 0.0002032 0.0006942, 0.0002032 0.0007006, 0.0001968 0.0007006, 0.0001968 0.0006942)) ]
   [properties: ALL ]
Query:
   filter: [ the_geom intersects POLYGON ((0.00019872 0.0006976, 0.00020112 0.0006976, 0.00020112 0.0007, 0.00019872 0.0007, 0.00019872 0.0006976)) ]
   [properties: ALL ]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.636 sec
Running org.geoserver.wms.featureinfo.TextFeatureInfoOutputFormatTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.364 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.632 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.611 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.979 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.462 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default4024009024515321887data\multiband\multiband.tiff
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.968 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
[CoverageInfoImpl[usa], CoverageInfoImpl[indexed], CoverageInfoImpl[paletted], CoverageInfoImpl[mosaic], CoverageInfoImpl[fourbits]]
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.804 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 28, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.996 sec
Running org.geoserver.wms.map.GetMapXmlReaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.237 sec
Running org.geoserver.wms.map.OpenLayersMapOutputFormatTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.417 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.614 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.RasterSymbolizerVisitorTest
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.402 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.162 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatExtendedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.333 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Error occurred while removing files, assuming it's a transient lock, sleeping 100ms and re-trying. Error message: Unable to delete file: .\target\default6965294060038851358data\multiband\multiband.tiff
Tests run: 7, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.084 sec <<< FAILURE!
testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest) Time elapsed: 1509 sec <<< FAILURE!
java.lang.AssertionError: Timeout was not reached
  at org.junit.Assert.fail(Assert.java:88)
  at org.geoserver.wms.map.RenderedImageMapOutputFormatTest.testTimeoutOption(RenderedImageMapOutputFormatTest.java:258)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wms.map.png.GetMapIntegrationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.985 sec
Running org.geoserver.wms.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.752 sec
Running org.geoserver.wms.svg.SVGTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.984 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.829 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.852 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.768 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesModifyingTest
ERROR: 'Can't obtain Envelope of Layer-Groups: Error occurred trying to write out metadata for layer group: test'
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.046 sec
Running org.geoserver.wms.wms_1_1_1.CustomDimensionsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.121 sec
Running org.geoserver.wms.wms_1_1_1.DescribeLayerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.362 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.131 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.71 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.284 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.8 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.763 sec
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.453 sec
Running org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.384 sec
Running org.geoserver.wms.wms_1_1_1.GetCapabilitiesLegendURL_1_1_1Test
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.183 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoRestrictedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.402 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
NAME = Green Forest
FID = 109
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.499 sec
Running org.geoserver.wms.wms_1_1_1.GetLegendGraphicTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.016 sec
Running org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest
Tests run: 44, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.368 sec
Running org.geoserver.wms.wms_1_1_1.GetStylesIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.5 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.899 sec
Running org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.602 sec
Running org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.655 sec
Running org.geoserver.wms.wms_1_1_1.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.083 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.588 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.854 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.737 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesIntegrationTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.615 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.373 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.995 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.999 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.633 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.375 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.734 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.984 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.416 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.6 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.819 sec
Results :
Failed tests: testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest): Timeout was not reached
Tests run: 697, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-wms/135/&gt;
