[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x » XLST based WFS output format #208
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-xslt/208/&gt;
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building XLST based WFS output format 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-xslt ---
[INFO] Deleting C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\target
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-xslt ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-xslt ---
[INFO] [GitCommitIdMojo] Running on 'c:\.jenkins\jobs\GeoServer-2.8.x\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1532 from ridethepenguin/secureddatastoreinfo-bug-2.8.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 15.03.2016 @ 20:34:05 CET
[INFO] [GitCommitIdMojo] build.timestamp = 15-mar-2016 21:09
[INFO] [GitCommitIdMojo] build.build.time = 15.03.2016 @ 21:58:38 CET
[INFO] [GitCommitIdMojo] build.branch = 8dae366ad0836e4b6f425c2b86a2603971b0930d
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8dae366
[INFO] [GitCommitIdMojo] build.commit.id = 8dae366ad0836e4b6f425c2b86a2603971b0930d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1532 from ridethepenguin/secureddatastoreinfo-bug-2.8.x
[GEOS-7459] Securing an app-schema data store may result in ClassCastException being thrown
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-xslt ---
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\src\main\resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-xslt ---
[INFO] Compiling 12 source files to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\target\classes
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-xslt ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-xslt ---
[INFO] Compiling 4 source files to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\target\test-classes
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-xslt ---
[INFO] Surefire report directory: C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\target\surefire-reports
T E S T S
Running org.geoserver.wfs.xslt.GetFeatureXSLTTest
Formats are: {HTML=HTML, text/html; subtype=xslt=text/html; subtype=xslt}
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 17.706 sec <<< FAILURE!
testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest) Time elapsed: 94 sec <<< ERROR!
java.lang.IllegalStateException: Cannot create wfs/transform
  at org.geoserver.platform.resource.FileSystemResourceStore$FileSystemResource.dir(FileSystemResourceStore.java:340)
  at org.geoserver.config.GeoServerDataDirectory.findOrCreateDir(GeoServerDataDirectory.java:139)
  at org.geoserver.wfs.xslt.config.TransformRepository.getAllTransforms(TransformRepository.java:173)
  at org.geoserver.wfs.xslt.XSLTOutputFormatUpdater.run(XSLTOutputFormatUpdater.java:43)
  at org.geoserver.wfs.xslt.GetFeatureXSLTTest.testNoOutputFormats(GetFeatureXSLTTest.java:180)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.io.FileNotFoundException: Unable to create C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\xslt\.\target\default7809591383106635364data\wfs\transform
  at org.geoserver.platform.resource.FileSystemResourceStore$FileSystemResource.dir(FileSystemResourceStore.java:332)
  ... 38 more
Running org.geoserver.wfs.xslt.config.TransformRepositoryTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.418 sec
Running org.geoserver.wfs.xslt.rest.TransformRestTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.761 sec
Results :
Tests in error:
  testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest): Cannot create wfs/transform
Tests run: 29, Failures: 0, Errors: 1, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$gs-xslt/209/&gt;
