[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x #170
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/170/changes&gt;
Changes:
[github] Backport 2.9.x - (GEOS-7623) - Backup&Restore community module GSIP 145
[...truncated 26778 lines...]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/target/gs-backup-restore-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/target/gs-backup-restore-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-backup-restore ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.112952-1.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.112952-1.pom (3 KB at 15.1 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/maven-metadata.xml (416 B at 7.5 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml (613 B at 7.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/maven-metadata.xml (372 B at 4.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.112952-1-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.112952-1-tests.jar (3 KB at 22.9 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml (823 B at 10.4 KB/sec)
[INFO]
[INFO] Building GeoServer Config Backup And Restore Core Module 2.9-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-core ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-core ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-core ---
[INFO] Compiling 23 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/target/classes&gt;
[WARNING] COMPILATION WARNING :
[WARNING] package org.geoserver.config
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/reader/CatalogFileReader.java&gt;:\[280,80\] TransformerFactoryImpl is internal proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[27,27\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java&gt;:\[84,24\] error: cannot find symbol
[ERROR] variable testGssm of type GeoServerSecurityManager
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java&gt;:\[126,24\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java&gt;:\[163,31\] error: cannot find symbol
[ERROR] variable securityContext of type GeoServerSecurityManager
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[181,32\] error: cannot find symbol
[ERROR] class CatalogBackupRestoreTasklet
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[180,17\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[360,17\] error: method reload in interface GeoServer cannot be applied to given types;
[ERROR] actual and formal argument lists differ in length
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[388,28\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[387,13\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[405,17\] error: cannot find symbol
[INFO] 10 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.185 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.374 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.452 s]
[INFO] Main Module ........................................ SUCCESS [ 12.687 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.946 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.379 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.458 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.187 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.023 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.874 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.113 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 8.711 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.662 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.832 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.728 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.353 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.078 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.676 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.683 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.806 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.787 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.260 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.828 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.683 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.683 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 3.353 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.863 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.575 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.321 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 32.577 s]
[INFO] Community Space .................................... SUCCESS [ 2.683 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.905 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.193 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.816 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.811 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.748 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.738 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.630 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.843 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.790 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.712 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.735 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.859 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 19.539 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.355 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 12.573 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.526 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.639 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.591 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.406 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.669 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.282 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.201 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.996 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.711 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.448 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.454 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.470 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.931 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 12.200 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.652 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.413 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.018 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.596 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.313 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 6.846 s]
[INFO] GeoFence Server .................................... SUCCESS [ 7.047 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.234 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.285 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.822 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.721 s]
[INFO] Importer Core Module ............................... SUCCESS [ 3.382 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.387 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 7.026 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.552 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.999 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.759 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.996 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.657 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.394 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.271 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.259 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 10.072 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.009 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.193 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 2.439 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.598 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 2.985 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:17 min
[INFO] Finished at: 2016-09-02T11:29:55+00:00
[INFO] Final Memory: 178M/421M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-backup-restore-core: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java&gt;:\[126,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java&gt;:\[163,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[181,32\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[180,17\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[360,17\] error: method reload in interface GeoServer cannot be applied to given types;
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[388,28\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[387,13\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java&gt;:\[405,17\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-core
On it
On Fri, Sep 2, 2016 at 1:29 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/170/changes>
Changes:
[…truncated 26778 lines…]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/target/gs-backup-restore-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-backup-restore —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/target/gs-backup-restore-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] — maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-backup-restore —
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-core —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-core —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-core —
[INFO] Compiling 23 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/target/classes>
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/reader/CatalogFileReader.java>:[280,80] TransformerFactoryImpl is internal proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[27,27] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java>:[84,24] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java>:[126,24] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java>:[163,31] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[181,32] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[180,17] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[360,17] error: method reload in interface GeoServer cannot be applied to given types;
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[388,28] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[387,13] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[405,17] error: cannot find symbol
[INFO] 10 errors
[INFO]
[INFO] GeoServer … SUCCESS [ 7.185 s]
[INFO] Core Platform Module … SUCCESS [ 2.374 s]
[INFO] Open Web Service Module … SUCCESS [ 4.452 s]
[INFO] Main Module … SUCCESS [ 12.687 s]
[INFO] GeoServer Security Modules … SUCCESS [ 0.946 s]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 1.379 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 1.458 s]
[INFO] Web Coverage Service Module … SUCCESS [ 1.187 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 2.023 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 1.874 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 2.113 s]
[INFO] Web Feature Service Module … SUCCESS [ 8.711 s]
[INFO] Web Map Service Module … SUCCESS [ 3.662 s]
[INFO] KML support for GeoServer … SUCCESS [ 1.832 s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [ 6.728 s]
[INFO] REST Support Module … SUCCESS [ 1.353 s]
[INFO] REST Configuration Service Module … SUCCESS [ 3.078 s]
[INFO] GeoServer Web Modules … SUCCESS [ 0.676 s]
[INFO] Core UI Module … SUCCESS [ 3.683 s]
[INFO] WMS UI Module … SUCCESS [ 1.806 s]
[INFO] GWC UI Module … SUCCESS [ 1.787 s]
[INFO] WFS UI Module … SUCCESS [ 1.260 s]
[INFO] Demos Module … SUCCESS [ 1.828 s]
[INFO] WCS UI Module … SUCCESS [ 1.683 s]
[INFO] Security UI Modules … SUCCESS [ 0.683 s]
[INFO] Security UI Core Module … SUCCESS [ 3.353 s]
[INFO] Security UI JDBC Module … SUCCESS [ 1.863 s]
[INFO] Security UI LDAP Module … SUCCESS [ 1.575 s]
[INFO] REST UI Module … SUCCESS [ 1.321 s]
[INFO] GeoServer Web Application … SUCCESS [ 32.577 s]
[INFO] Community Space … SUCCESS [ 2.683 s]
[INFO] Authentication by unique url key … SUCCESS [ 5.905 s]
[INFO] WorldWind Format Module … SUCCESS [ 6.193 s]
[INFO] SpatiaLite Extension … SUCCESS [ 4.816 s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [ 7.811 s]
[INFO] Aggregating Data Store … SUCCESS [ 3.748 s]
[INFO] GeoServer Extensions … SUCCESS [ 0.738 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.630 s]
[INFO] Web Processing Service Module … SUCCESS [ 4.843 s]
[INFO] GeoServer Scripting Extensions … SUCCESS [ 0.790 s]
[INFO] Core Scripting Extension … SUCCESS [ 6.712 s]
[INFO] Web UI Scripting Extension … SUCCESS [ 5.735 s]
[INFO] BeanShell Scripting Extension … SUCCESS [ 4.859 s]
[INFO] Groovy Scripting Extension … SUCCESS [ 19.539 s]
[INFO] H2 DataStore Extension … SUCCESS [ 1.355 s]
[INFO] Python Scripting Extension … SUCCESS [ 12.573 s]
[INFO] JavaScript Scripting Extension … SUCCESS [ 7.526 s]
[INFO] Ruby Scripting Extension … SUCCESS [ 4.639 s]
[INFO] WMS-EO … SUCCESS [ 6.591 s]
[INFO] ColorMap … SUCCESS [ 5.406 s]
[INFO] GeoServer mbtiles Extension … SUCCESS [ 6.669 s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [ 6.282 s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [ 5.996 s]
[INFO] REST plugin community module … SUCCESS [ 5.711 s]
[INFO] GPX PPIO for WPS … SUCCESS [ 5.448 s]
[INFO] KML PPIO for WPS … SUCCESS [ 5.454 s]
[INFO] DownloadProcess … SUCCESS [ 6.470 s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [ 1.931 s]
[INFO] ActiveMQ … SUCCESS [ 12.200 s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [ 3.652 s]
[INFO] GeoServer JMS clustering module … SUCCESS [ 12.413 s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [ 7.018 s]
[INFO] Solr Module … SUCCESS [ 5.596 s]
[INFO] Resumable REST Upload module … SUCCESS [ 5.313 s]
[INFO] GeoFence security integration … SUCCESS [ 6.846 s]
[INFO] GeoFence Server … SUCCESS [ 7.047 s]
[INFO] REST SLD service … SUCCESS [ 6.234 s]
[INFO] Parameters Extractor … SUCCESS [ 6.285 s]
[INFO] Vector Tiles … SUCCESS [ 9.822 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.721 s]
[INFO] Importer Core Module … SUCCESS [ 3.382 s]
[INFO] WPS cluster on jdbc datastores … SUCCESS [ 7.026 s]
[INFO] GWC Distributed Caching Plugin … SUCCESS [ 3.552 s]
[INFO] GeoWebCache S3 … SUCCESS [ 5.999 s]
[INFO] OGR parent … SUCCESS [ 0.759 s]
[INFO] OGR CORE … SUCCESS [ 0.996 s]
[INFO] GDAL translate parent … SUCCESS [ 0.657 s]
[INFO] GDAL translate WCS … SUCCESS [ 5.394 s]
[INFO] GDAL translate WPS … SUCCESS [ 5.271 s]
[INFO] Ysld GeoServer Plugin … SUCCESS [ 5.259 s]
[INFO] GeoGig GeoServer integration … SUCCESS [ 10.072 s]
[INFO] GeoServer JDBC Configuration Resource Store … SUCCESS [ 6.009 s]
[INFO] GeoWebCache SQLite … SUCCESS [ 6.193 s]
[INFO] GeoServer Community Release Module … SUCCESS [ 2.439 s]
[INFO] GeoServer Config Backup And Restore … SUCCESS [ 0.598 s]
[INFO] GeoServer Config Backup And Restore Core Module … FAILURE [ 2.985 s]
[INFO] GeoServer Config Backup And Restore REST Module … SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module … SKIPPED
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java>:[126,24] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogSecurityManagerTasklet.java>:[163,31] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[181,32] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[180,17] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[360,17] error: method reload in interface GeoServer cannot be applied to given types;
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[388,28] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[387,13] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/core/src/main/java/org/geoserver/backuprestore/tasklet/CatalogBackupRestoreTasklet.java>:[405,17] error: cannot find symbol
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-backup-restore-core
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/171/changes&gt;
Changes:
[andrea.aime] [GEOS-7711] Importer does not parse the JSON on creation if the json
[...truncated 26767 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml (802 B at 14.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.125706-2.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.125706-2.pom (3 KB at 24.5 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml (823 B at 10.2 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/maven-metadata.xml (372 B at 4.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.125706-2-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/gs-backup-restore-2.9-20160902.125706-2-tests.jar (3 KB at 24.8 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-backup-restore/2.9-SNAPSHOT/maven-metadata.xml (823 B at 10.3 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] 1 warning
[INFO] 10 errors
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.383 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.953 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.296 s]
[INFO] Main Module ........................................ SUCCESS [ 13.825 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.362 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.448 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.087 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.893 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.748 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.865 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.150 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.587 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.820 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.965 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.296 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 2.992 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.684 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.429 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 2.062 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.772 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.257 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.582 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.658 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.332 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.171 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.789 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.452 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 39.853 s]
[INFO] Community Space .................................... SUCCESS [ 0.764 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.900 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.194 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.897 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.596 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.631 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.636 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.631 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.494 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 1.024 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.573 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.940 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.094 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 19.432 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.343 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.600 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.276 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.995 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.496 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.013 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.412 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.244 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.209 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.834 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.487 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.307 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.123 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.273 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 2.188 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 11.745 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.838 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 13.753 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.028 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.508 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.416 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.095 s]
[INFO] GeoFence Server .................................... SUCCESS [ 6.898 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.360 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.254 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.846 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.725 s]
[INFO] Importer Core Module ............................... SUCCESS [ 3.555 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.605 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.609 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.492 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.381 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.684 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.010 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.583 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.374 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.287 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.154 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 9.494 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.340 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.490 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 1.459 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.557 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 2.832 s]
[INFO] Total time: 07:09 min
[INFO] Finished at: 2016-09-02T12:57:09+00:00
[INFO] Final Memory: 177M/455M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/172/changes&gt;
