[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x #324
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/324/changes&gt;
Changes:
[nuno.oliveira] [GEOS-7662] Updates styling documentation about the underline text
[github] Revert "[GEOS-7662] Updates styling documentation about the underline
[...truncated 14497 lines...]
[INFO] Downloading: https://repository.apache.org/content/repositories/snapshots/org/geotools/gt-image/15-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-jms-geoserver ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-jms-geoserver ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-jms-geoserver ---
[INFO] Copying 6 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-jms-geoserver ---
[INFO] Compiling 48 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-geoserver ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-geoserver ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 11.572 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 26.924 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.768 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.334 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.563 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.311 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.709 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.866 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.987 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.183 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 19.570 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.441 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.946 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.224 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.402 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.480 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.354 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.793 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.208 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.282 s]
[INFO] REST plugin community module ....................... SUCCESS [ 7.175 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.769 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.308 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.054 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.689 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.045 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.178 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 17.111 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.578 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.323 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.773 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.825 s]
[INFO] GeoFence Server .................................... SUCCESS [ 6.600 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.688 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.570 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.728 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.941 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.805 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.663 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.215 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 7.285 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.846 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.121 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 11.632 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.245 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.361 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.113 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.478 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 4.560 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.487 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 2.985 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 38.252 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.254 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.061 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.165 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:23 min (Wall Clock)
[INFO] Finished at: 2016-12-04T19:11:45+00:00
[INFO] Final Memory: 130M/411M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[59,7\] error: GeoServerFunctionalTestContext is not abstract and does not override abstract method callInternal(Method,String,String,String) in FunctionalTestContext
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/325/changes&gt;
