[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x #394
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/394/changes&gt;
Changes:
[emerkle] Update compress-lzf library version
[emerkle] Import Existing GeoGig repo via web API
[...truncated 14878 lines...]
[INFO] Copying 6 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-jms-geoserver ---
[INFO] Compiling 48 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-geoserver ---
[INFO] Copying 0 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-geoserver ---
[INFO] Compiling 10 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] Building GeoServer notification event system 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-notification ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.9-SNAPSHOT/gs-notification-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.9-SNAPSHOT/gs-notification-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.9-SNAPSHOT/gs-notification-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.9-SNAPSHOT/gs-notification-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/notification/target/gs-notification-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.9-SNAPSHOT/gs-notification-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.338 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.082 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.398 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.458 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.314 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.378 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 3.169 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.637 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.667 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.073 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.546 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.786 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.983 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.102 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.947 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.813 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.622 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.016 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.582 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.327 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.718 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.551 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.940 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.594 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.534 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 7.714 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.719 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 17.841 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.142 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.369 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.079 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 10.202 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.685 s]
[INFO] REST SLD service ................................... SUCCESS [ 7.250 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.152 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.028 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.405 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.225 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.499 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.362 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.035 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 9.424 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.243 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.744 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 30.454 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.398 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.065 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.053 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.148 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.108 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.307 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.065 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.191 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.345 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.017 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.148 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.362 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.062 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 4.959 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:55 min (Wall Clock)
[INFO] Finished at: 2017-03-14T01:59:52+00:00
[INFO] Final Memory: 135M/404M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[285,76\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
