See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/406/changes>
Changes:
[jd] Update geogig plugin to work with additional parameter options.
[...truncated 14841 lines...]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-geoserver ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-geoserver ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO] Compiling 10 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/test-classes>
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.360 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 14.517 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.774 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.906 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.442 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.967 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 6.207 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.594 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.031 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.930 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.692 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.033 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.695 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.648 s]
[INFO] WMS-EO ............................................. SUCCESS [ 9.168 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.450 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.410 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.560 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.686 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.556 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.882 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.054 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.903 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.671 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.560 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 6.498 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.965 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 17.210 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.730 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.971 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.966 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.569 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.383 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.522 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.932 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.330 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.359 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.171 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.670 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.777 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.047 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.523 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.415 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.960 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 19.884 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.444 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.143 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.076 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.815 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.047 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.481 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.146 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 21.381 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.768 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.088 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.146 s]
[INFO] gs-notification-common ............................. SUCCESS [ 2.930 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.104 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 4.429 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:53 min (Wall Clock)
[INFO] Finished at: 2017-03-23T23:16:03+00:00
[INFO] Final Memory: 135M/693M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[17,7\] error: constructor AbstractWebAPICommand in class AbstractWebAPICommand cannot be applied to given types;
[ERROR] actual and formal argument lists differ in length
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[19,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[32,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[34,45\] error: no suitable method found for runCommand(Variant,Request,MediaType)
[ERROR] method CommandResource.runCommand(Variant,Request) is not applicable
[ERROR] (actual and formal argument lists differ in length)
[ERROR] method InitCommandResource.runCommand(Variant,Request) is not applicable
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[15,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[21,4\] error: method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
