[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x-nightly #234
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/234/&gt;
[...truncated 5030 lines...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ysld ---
[INFO] Copying 0 resource
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ysld ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ysld ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-ysld ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-ysld ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-ysld ---
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/dependency/gwc-core-1.9-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/dependency/gt-api-15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ysld ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.9-SNAPSHOT/gs-ysld-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.9-SNAPSHOT/gs-ysld-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.9-SNAPSHOT/gs-ysld-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.9-SNAPSHOT/gs-ysld-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/ysld/target/gs-ysld-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.9-SNAPSHOT/gs-ysld-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoGig GeoServer integration 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-geogig ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/geogig/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geogig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geogig ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geogig ---
[INFO] Copying 25 resources
[INFO] Copying 17 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geogig ---
[INFO] Compiling 58 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/geogig/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geogig ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geogig ---
[INFO] Compiling 24 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/geogig/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[59,7\] error: GeoServerFunctionalTestContext is not abstract and does not override abstract method callInternal(Method,String,String,String) in FunctionalTestContext
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.313 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.844 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.616 s]
[INFO] Main Module ........................................ SUCCESS [ 36.869 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.098 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.430 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.358 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.402 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 6.573 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.262 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 8.119 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 12.774 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 16.336 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.115 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 13.407 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.734 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.479 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.081 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.553 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.192 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.743 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.317 s]
[INFO] Demos Module ....................................... SUCCESS [ 6.149 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.846 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.105 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.555 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.824 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.656 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.878 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 14.832 s]
[INFO] Community Space .................................... SUCCESS [ 0.621 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 19.173 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 11.811 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 3.564 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.492 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.564 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.067 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.046 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 11.099 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.104 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 8.162 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.426 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.475 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 20.635 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.516 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.036 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.149 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.769 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.489 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.260 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.774 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.000 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.300 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.982 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.160 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.015 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.445 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.319 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.777 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 10.314 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.912 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 13.666 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.518 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.487 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.304 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.631 s]
[INFO] GeoFence Server .................................... SUCCESS [ 6.070 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.225 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 4.847 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 4.945 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.102 s]
[INFO] Importer Core Module ............................... SUCCESS [ 9.521 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.115 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.704 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.406 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.675 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.081 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.899 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.044 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 3.849 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.822 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.340 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 8.171 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:49 min
[INFO] Finished at: 2016-12-04T06:52:54+00:00
[INFO] Final Memory: 190M/495M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/235/changes&gt;
