[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x-nightly #88
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/88/changes&gt;
Changes:
[andrea.aime] [GEOS-7215] Geoserver WFS GetFeature with multiple featureid/resourceid
[andrea.aime] [GEOS-7258] CQL filter documentation wrongly reports ability to do a
[andrea.aime] [GEOS-7543] REST Putting a WFS Settings xml results into an
[andrea.aime] [GEOS-7547] Expiry of GetFeatureWithLock wrongly expected to be minutes
[mike] Auth page no longer has anonymous auth checkbox
[dblasby] Status implementation for LibTurboJpeg
[dblasby] GDALStatus implementation
[dblasby] GDAL status info
[dblasby] GSIP-143 archtype test for status page HTML via rest
[dblasby] GSIP-143 GEOS-7567 Module status for netcdf and netcdf-out
[dblasby] GEOS-7608 GEOS-7567 GSIP-143 bug fix and improved module status page
[dblasby] GEOS-7567 GSIP-143 netcdf-out status page - add native lib version (if
[dblasby] GSIP-143 minor typos noticed in module names
[dblasby] GSIP-143 make html version more readable - newline to html br
[dblasby] GSIP-143 add status page for system properties and environment
[dblasby] GEOS-7567 GSIP-143 Module Status for GRIB
[dblasby] list max memory on status page (next to used memory)
[tbarsballe] [GEOS-5090] Show styles to be deleted in GUI notification
[jody.garnett] [GEOS-7650] Can't delete Default Cached Gridsets (#1698)
[ben] [GEOT-5308] Support predefined app-schema interpolation properties for
[...truncated 886 lines...]
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-kml ---
[INFO] Compiling 58 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-kml ---
[INFO] Copying 27 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-kml ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-kml ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-kml ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-kml ---
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/dependency/gwc-core-1.9-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/dependency/gt-api-15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-kml ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-gwc ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 47 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerMetaTile.java&gt;:\[38,29\] error: cannot find symbol
[ERROR] package it.geosolutions.jaiext
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1285,23\] error: cannot find symbol
[ERROR] class GeoServerTileLayer
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1284,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1290,20\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1295,12\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1295,43\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerMetaTile.java&gt;:\[207,23\] error: cannot find symbol
[INFO] 7 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.005 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.683 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.081 s]
[INFO] Main Module ........................................ SUCCESS [ 21.233 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 4.661 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.523 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.489 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.422 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 5.961 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.715 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 11.787 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 14.820 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 8.410 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 3.667 s]
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:54 min
[INFO] Finished at: 2016-07-23T12:17:35+00:00
[INFO] Final Memory: 128M/396M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1285,23\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1284,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1295,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[1295,43\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerMetaTile.java&gt;:\[207,23\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/89/&gt;
Started by user Hudson
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/2.9.x^{commit} # timeout=10
Checking out Revision 50558f3159aa236fbbd1f566c5e29b52f1c51f34 (origin/2.9.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 50558f3159aa236fbbd1f566c5e29b52f1c51f34
java.io.IOException: Could not checkout 50558f3159aa236fbbd1f566c5e29b52f1c51f34
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:964)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
  at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
  at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
  at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
  at hudson.model.Run.execute(Run.java:1689)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:231)
Caused by: hudson.plugins.git.GitLockFailedException: Could not lock repository. Please try again
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:1987)
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:961)
  ... 8 more
Caused by: hudson.plugins.git.GitException: Command "git checkout -f 50558f3159aa236fbbd1f566c5e29b52f1c51f34" returned status code 128:
stdout:
stderr: fatal: Unable to create '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/.git/index.lock’>: File exists.
If no other git process is currently running, this probably means a
git process crashed in this repository earlier. Make sure no other git
process is running and remove the file manually to continue.
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1719)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:63)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:1984)
  ... 9 more
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/90/&gt;
[...truncated 754 lines...]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wcs ---
[INFO] Compiling 18 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wcs ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wcs ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wcs ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wcs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wcs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wcs ---
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-wcs ---
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/dependency/gwc-core-1.9-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-15-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/dependency/gt-api-15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] Building Web Coverage Service 1.0 Module 2.9-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wcs/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.wcs/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wcs/15-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wcs/15-SNAPSHOT/maven-metadata.xml (966 B at 2.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wcs/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-wcs/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wcs/15-SNAPSHOT/maven-metadata.xml
961/961 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wcs/15-SNAPSHOT/maven-metadata.xml (961 B at 2.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-wcs1_0 ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs1_0/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wcs1_0 ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-wcs1_0 ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wcs1_0 ---
[INFO] Copying 8 resources
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wcs1_0 ---
[INFO] Compiling 22 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs1_0/target/classes&gt;
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs1_0/src/main/java/org/geoserver/wcs/WCS10WorkspaceQualifier.java&gt;:\[20,7\] error: WCS10WorkspaceQualifier is not abstract and does not override abstract method qualifyRequest(WorkspaceInfo,LayerInfo,Operation,Request) in WorkspaceQualifyingCallback
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs1_0/src/main/java/org/geoserver/wcs/WCS10WorkspaceQualifier.java&gt;:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/ws/src/wcs1_0/src/main/java/org/geoserver/wcs/WCS10WorkspaceQualifier.java&gt;:\[30,4\] error: method does not override or implement a method from a supertype
[INFO] 3 errors
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.537 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.878 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.636 s]
[INFO] Main Module ........................................ SUCCESS [ 34.816 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.108 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.633 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 7.285 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.685 s]
[INFO] Web Coverage Service 1.0 Module .................... FAILURE [ 14.652 s]
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] Total time: 01:39 min
[INFO] Finished at: 2016-07-24T01:21:04+00:00
[INFO] Final Memory: 126M/403M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wcs1_0: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs1_0
I set geoserver-2.9.x-nightly to build in workspace/geoserver-2.9.x rather than workspace/geoserver-master. I hope this makes it happier.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x-nightly/91/&gt;
Great success!
https://www.youtube.com/watch?v=r13riaRKGo0
Director
New Zealand
