[Geoserver-devel] Build failed in Jenkins: GeoServer-2.9.x-OpenJDK8 #129
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/129/changes&gt;
Changes:
[alessio.fabiani] - Fix for JIRA GEOS-7738 Importer should preserve auth on async
[...truncated 10499 lines...]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.283 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 34.572 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:01 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:24 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.120 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 38.817 s]
[INFO] REST Support Module ................................ SUCCESS [ 9.613 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 41.174 s]
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:12 min
[INFO] Finished at: 2016-09-14T10:39:36+02:00
[INFO] Final Memory: 127M/755M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml&gt; to org.geoserver.csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf-out/pom.xml&gt; to org.geoserver.extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/arcsde/pom.xml&gt; to org.geoserver.extension/gs-arcsde/2.9-SNAPSHOT/gs-arcsde-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to org.geoserver.extension/gs-app-schema-test/2.9-SNAPSHOT/gs-app-schema-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/teradata/pom.xml&gt; to org.geoserver.extension/gs-teradata/2.9-SNAPSHOT/gs-teradata-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wfs/pom.xml&gt; to org.geoserver.web/gs-web-wfs/2.9-SNAPSHOT/gs-web-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml&gt; to org.geoserver.extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/gdal/pom.xml&gt; to org.geoserver.extension/gs-gdal/2.9-SNAPSHOT/gs-gdal-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/core/pom.xml&gt; to org.geoserver.extension/gs-dxf-core/2.9-SNAPSHOT/gs-dxf-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/pom.xml&gt; to org.geoserver.extension/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/pom.xml&gt; to org.geoserver.extension/gs-ogr/2.9-SNAPSHOT/gs-ogr-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/pom.xml&gt; to org.geoserver.extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/pom.xml&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/db2/pom.xml&gt; to org.geoserver.extension/gs-db2/2.9-SNAPSHOT/gs-db2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/pom.xml&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/charts/pom.xml&gt; to org.geoserver.extension/gs-charts/2.9-SNAPSHOT/gs-charts-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/pom.xml&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/core/pom.xml&gt; to org.geoserver.web/gs-web-core/2.9-SNAPSHOT/gs-web-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/pom.xml&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml&gt; to org.geoserver.extension/gs-monitor-hibernate/2.9-SNAPSHOT/gs-monitor-hibernate-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/pom.xml&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo-core/2.9-SNAPSHOT/gs-wcs2_0-eo-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/pom.xml&gt; to org.geoserver/web/2.9-SNAPSHOT/web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml&gt; to org.geoserver.extension/gs-libjpeg-turbo/2.9-SNAPSHOT/gs-libjpeg-turbo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/pom.xml&gt; to org.geoserver/extension/2.9-SNAPSHOT/extension-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/ldap/pom.xml&gt; to org.geoserver.web/gs-web-sec-ldap/2.9-SNAPSHOT/gs-web-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/pom.xml&gt; to org.geoserver.extension/gs-wps/2.9-SNAPSHOT/gs-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/pom.xml&gt; to org.geoserver.extension/gs-dxf/2.9-SNAPSHOT/gs-dxf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml&gt; to org.geoserver.csw/gs-csw-simple-store/2.9-SNAPSHOT/gs-csw-simple-store-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml&gt; to org.geoserver.extension/gs-sample-data-access-test/2.9-SNAPSHOT/gs-sample-data-access-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml&gt; to org.geoserver.extension/gs-feature-pregeneralized/2.9-SNAPSHOT/gs-feature-pregeneralized-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/core/pom.xml&gt; to org.geoserver.csw/gs-csw-core/2.9-SNAPSHOT/gs-csw-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/pom.xml&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/community/pom.xml&gt; to org.geoserver/community/2.9-SNAPSHOT/community-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/pom.xml&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/pom.xml&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to org.geoserver.extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/excel/pom.xml&gt; to org.geoserver.extension/gs-excel/2.9-SNAPSHOT/gs-excel-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wms/pom.xml&gt; to org.geoserver.web/gs-web-wms/2.9-SNAPSHOT/gs-web-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/inspire/pom.xml&gt; to org.geoserver.extension/gs-inspire/2.9-SNAPSHOT/gs-inspire-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml&gt; to org.geoserver.extension/gs-wps-core/2.9-SNAPSHOT/gs-wps-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/css/pom.xml&gt; to org.geoserver.extension/gs-css/2.9-SNAPSHOT/gs-css-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/pom.xml&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf/pom.xml&gt; to org.geoserver.extension/gs-netcdf/2.9-SNAPSHOT/gs-netcdf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/pom.xml&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/cas/pom.xml&gt; to org.geoserver.security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/pom.xml&gt; to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/rest/pom.xml&gt; to org.geoserver.web/gs-web-rest/2.9-SNAPSHOT/gs-web-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/pom.xml&gt; to org.geoserver.extension/gs-monitor/2.9-SNAPSHOT/gs-monitor-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/pom.xml&gt; to org.geoserver/gs-restconfig/2.9-SNAPSHOT/gs-restconfig-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/pom.xml&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/pom.xml&gt; to org.geoserver.web/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/pom.xml&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemap/pom.xml&gt; to org.geoserver.extension/gs-imagemap/2.9-SNAPSHOT/gs-imagemap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/xslt/pom.xml&gt; to org.geoserver/gs-xslt/2.9-SNAPSHOT/gs-xslt-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/mysql/pom.xml&gt; to org.geoserver.extension/gs-mysql/2.9-SNAPSHOT/gs-mysql-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/grib/pom.xml&gt; to org.geoserver.extension/gs-grib/2.9-SNAPSHOT/gs-grib-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/pom.xml&gt; to org.geoserver/gs-csw/2.9-SNAPSHOT/gs-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/oracle/pom.xml&gt; to org.geoserver.extension/gs-oracle/2.9-SNAPSHOT/gs-oracle-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/sqlserver/pom.xml&gt; to org.geoserver.extension/gs-sqlserver/2.9-SNAPSHOT/gs-sqlserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/bdb/pom.xml&gt; to org.geoserver.importer/gs-importer-bdb/2.9-SNAPSHOT/gs-importer-bdb-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/demo/pom.xml&gt; to org.geoserver.web/gs-web-demo/2.9-SNAPSHOT/gs-web-demo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/core/pom.xml&gt; to org.geoserver.extension/gs-monitor-core/2.9-SNAPSHOT/gs-monitor-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml&gt; to org.geoserver.extension/gs-ogr-core/2.9-SNAPSHOT/gs-ogr-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/core/pom.xml&gt; to org.geoserver.importer/gs-importer-core/2.9-SNAPSHOT/gs-importer-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/pom.xml&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml&gt; to org.geoserver.extension/gs-ogr-wfs/2.9-SNAPSHOT/gs-ogr-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/pom.xml&gt; to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/target/gs-security-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/h2/pom.xml&gt; to org.geoserver.extension/gs-h2/2.9-SNAPSHOT/gs-h2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wcs/pom.xml&gt; to org.geoserver.web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/jp2k/pom.xml&gt; to org.geoserver.extension/gs-jp2k/2.9-SNAPSHOT/gs-jp2k-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/pom.xml&gt; to org.geoserver/gs-importer/2.9-SNAPSHOT/gs-importer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/app/pom.xml&gt; to org.geoserver.web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/control-flow/pom.xml&gt; to org.geoserver.extension/gs-control-flow/2.9-SNAPSHOT/gs-control-flow-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml&gt; to org.geoserver.extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/pom.xml&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to org.geoserver.extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/gwc/pom.xml&gt; to org.geoserver.web/gs-web-gwc/2.9-SNAPSHOT/gs-web-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/core/pom.xml&gt; to org.geoserver.web/gs-web-sec-core/2.9-SNAPSHOT/gs-web-sec-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml&gt; to org.geoserver.security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/jdbc/pom.xml&gt; to org.geoserver.web/gs-web-sec-jdbc/2.9-SNAPSHOT/gs-web-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/printing/pom.xml&gt; to org.geoserver.extension/gs-printing/2.9-SNAPSHOT/gs-printing-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/web/pom.xml&gt; to org.geoserver.importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/rest/pom.xml&gt; to org.geoserver.importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/wps/pom.xml&gt; to org.geoserver.extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/querylayer/pom.xml&gt; to org.geoserver.extension/gs-querylayer/2.9-SNAPSHOT/gs-querylayer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/api/pom.xml&gt; to org.geoserver.csw/gs-csw-api/2.9-SNAPSHOT/gs-csw-api-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml&gt; to org.geoserver.extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/pom.xml&gt; to org.geoserver.extension/gs-app-schema/2.9-SNAPSHOT/gs-app-schema-2.9-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/130/changes&gt;
Changes:
[Daniele Romagnoli] Setting up ImageMosaic documentation for CoverageNameCollector
[...truncated 352 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.291 sec
Running org.geoserver.rest.GlobalSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Running org.geoserver.rest.LocalSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.318 sec
Running org.geoserver.rest.ModuleStatusTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.361 sec
Running org.geoserver.rest.resources.ResourceTest
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.381 sec <<< FAILURE!
testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest) Time elapsed: 10 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<...rce/po%C3%ABzie/caf%[C3%A9]> but was:<...rce/po%C3%ABzie/caf%[3F]>
  at junit.framework.Assert.assertEquals(Assert.java:100)
  at junit.framework.Assert.assertEquals(Assert.java:107)
  at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
  at org.geoserver.rest.resources.ResourceTest.testSpecialCharacterNames(ResourceTest.java:164)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.security.rest.AccessControlResourceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.817 sec
Running org.geoserver.security.rest.MasterPasswordResourceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.991 sec
Running org.geoserver.service.rest.LocalWCSSettingsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.336 sec
Running org.geoserver.service.rest.LocalWFSSettingsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.343 sec
Running org.geoserver.service.rest.LocalWMSSettingsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Running org.geoserver.service.rest.WCSSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.286 sec
Running org.geoserver.service.rest.WFSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.307 sec
Running org.geoserver.service.rest.WMSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.298 sec
Results :
Failed tests: testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest): expected:<...rce/po%C3%ABzie/caf%[C3%A9]> but was:<...rce/po%C3%ABzie/caf%[3F]>
Tests run: 378, Failures: 1, Errors: 0, Skipped: 3
[JENKINS] Recording test results
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] REST Configuration Service Module .................. FAILURE [ 49.474 s]
[INFO] Total time: 01:00 min
[INFO] Finished at: 2016-09-14T16:32:34+02:00
[INFO] Final Memory: 108M/506M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/131/changes&gt;
Changes:
[alessio.fabiani] - Fixes GEOS-7739 Importer tries to write features on closed
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.311 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.277 sec
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.382 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.584 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.992 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.29 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.295 sec
Results :
[INFO]
[INFO] REST Configuration Service Module .................. FAILURE [ 43.281 s]
[INFO] Total time: 53.379 s
[INFO] Finished at: 2016-09-14T17:32:13+02:00
[INFO] Final Memory: 108M/510M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/132/changes&gt;
Changes:
[groldan] Set geogig dependency to 1.0-SNAPSHOT and adapt as needed
[groldan] Update GeoGig plugin to implement RepositoryResolver interface
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.381 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.392 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.28 sec
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.384 sec <<< FAILURE!
testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest) Time elapsed: 11 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.698 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.995 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.345 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.342 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.427 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.393 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.387 sec
Results :
[INFO]
[INFO] REST Configuration Service Module .................. FAILURE [ 53.524 s]
[INFO] Total time: 01:03 min
[INFO] Finished at: 2016-09-15T00:32:21+02:00
[INFO] Final Memory: 108M/507M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/133/changes&gt;
Changes:
[ben] [GEOS-7717] Malformed WMS GetFeatureInfo XML response if raster sample
[ben] [GEOS-7734] Support coverage GetFeatureInfo wrapping and shifted native
[...truncated 10521 lines...]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 34.560 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 55.736 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.544 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 38.845 s]
[INFO] REST Support Module ................................ SUCCESS [ 8.840 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 39.739 s]
[INFO] Total time: 08:01 min
[INFO] Finished at: 2016-09-16T01:39:27+02:00
[INFO] Final Memory: 132M/744M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Waiting for Jenkins to finish collecting data
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/134/changes&gt;
Changes:
[Daniele Romagnoli] [GEOS-7718]: Netcdf: support ncml file extension (#1798)
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.317 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.428 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.353 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.301 sec
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.424 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.722 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.027 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.447 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.365 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.383 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.309 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.329 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Results :
[INFO]
[INFO] REST Configuration Service Module .................. FAILURE [01:00 min]
[INFO] Total time: 01:12 min
[INFO] Finished at: 2016-09-16T12:32:35+02:00
[INFO] Final Memory: 104M/554M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/135/changes&gt;
Changes:
[tbarsballe] [GEOS-7651] Use IOUtils rename method for FileSystemResource
[...truncated 10531 lines...]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.009 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.803 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.406 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 34.215 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.329 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.045 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 38.400 s]
[INFO] REST Support Module ................................ SUCCESS [ 8.939 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 38.742 s]
[INFO] Total time: 07:57 min
[INFO] Finished at: 2016-09-17T12:39:21+02:00
[INFO] Final Memory: 131M/774M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/136/changes&gt;
Changes:
[Andrea Aime] [GEOS-7745] CSW based on internal layers ignores security restrictions
[Andrea Aime] [GEOS-7745] Fix headers, formatting, commented out code
[...truncated 9802 lines...]
[INFO]
[INFO] Main Module ........................................ SUCCESS [01:39 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 2.294 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 15.393 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.208 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.226 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.901 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.967 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.229 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.892 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:27 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.003 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 39.601 s]
[INFO] REST Support Module ................................ SUCCESS [ 9.283 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 41.781 s]
[INFO] Total time: 07:54 min
[INFO] Finished at: 2016-09-18T12:39:13+02:00
[INFO] Final Memory: 132M/762M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/137/changes&gt;
Changes:
[tbarsballe] [GEOS-7740] Make ResourceNotification serializable
[tbarsballe] JdbcResourceStore: do not store logs in database
[tbarsballe] Updating the appbundler jar link
[...truncated 1249 lines...]
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Results :
Failed tests: testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest)
Tests run: 724, Failures: 1, Errors: 0, Skipped: 2
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.075 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.267 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.035 s]
[INFO] Main Module ........................................ FAILURE [01:32 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] Total time: 02:12 min
[INFO] Finished at: 2016-09-19T23:33:32+02:00
[INFO] Final Memory: 127M/694M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/138/changes&gt;
Changes:
[nuno.oliveira] [GEOS-7750] Get WMS and LegendSample beans only when needed
[...truncated 9789 lines...]
[INFO]
[INFO] Main Module ........................................ SUCCESS [01:50 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.477 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 15.420 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 12.900 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.247 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.691 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.328 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.189 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.586 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:21 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.661 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 39.297 s]
[INFO] REST Support Module ................................ SUCCESS [ 9.231 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 41.039 s]
[INFO] Total time: 07:58 min
[INFO] Finished at: 2016-09-20T15:39:27+02:00
[INFO] Final Memory: 127M/767M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/139/changes&gt;
Changes:
[tbarsballe] Add code-signing support for GeoServer.app bundle on OS X
[tbarsballe] Migrate OS X DMG generation to dmgbuild utility; no GUI login required
[...truncated 10491 lines...]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 34.972 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.644 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:22 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.778 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 38.361 s]
[INFO] REST Support Module ................................ SUCCESS [ 8.948 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 39.568 s]
[INFO] Total time: 08:09 min
[INFO] Finished at: 2016-09-21T01:39:30+02:00
[INFO] Final Memory: 130M/739M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/140/changes&gt;
Changes:
[nuno.oliveira] [GEOS-7746] Use the computed width and height instead of the default
[...truncated 839 lines...]
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.466 sec <<< FAILURE!
testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest) Time elapsed: 9 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.625 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.994 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.333 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.425 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.285 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.382 sec
Results :
[INFO]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 47.238 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 43.104 s]
[INFO] Total time: 01:38 min
[INFO] Finished at: 2016-09-21T11:32:58+02:00
[INFO] Final Memory: 125M/754M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/141/changes&gt;
Changes:
[emerkle] Fix URI building/parsing of PostgreSQL URIs for GeoGig
[emerkle] Fix GeoGig tests so temp files are cleaned up after tests finish.
[...truncated 353 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.312 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.338 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.567 sec
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.455 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.936 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.315 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.324 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.28 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.367 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.37 sec
Results :
[INFO]
[INFO] REST Configuration Service Module .................. FAILURE [01:03 min]
[INFO] Total time: 01:17 min
[INFO] Finished at: 2016-09-21T20:32:45+02:00
[INFO] Final Memory: 104M/547M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/142/changes&gt;
Changes:
[alessio.fabiani] [GEOS-7753] Cannot update existing store configuration, GeoServer
[...truncated 9832 lines...]
[INFO]
[INFO] Main Module ........................................ SUCCESS [01:48 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.713 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 16.036 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 14.653 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.117 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.259 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.348 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.474 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 57.037 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:44 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.066 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 39.956 s]
[INFO] REST Support Module ................................ SUCCESS [ 9.330 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 42.238 s]
[INFO] Total time: 08:25 min
[INFO] Finished at: 2016-09-22T14:39:50+02:00
[INFO] Final Memory: 137M/722M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/143/changes&gt;
Changes:
[alessio.fabiani] [GEOS-7754] GeoServer Environment Allow Parametrization should set to
[...truncated 10670 lines...]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 17.028 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.771 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:00 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.878 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 42.687 s]
[INFO] REST Support Module ................................ SUCCESS [ 10.051 s]
[INFO] REST Configuration Service Module .................. FAILURE [ 44.648 s]
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:35 min
[INFO] Finished at: 2016-09-22T15:39:49+02:00
[INFO] Final Memory: 133M/770M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml&gt; to org.geoserver.csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf-out/pom.xml&gt; to org.geoserver.extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/arcsde/pom.xml&gt; to org.geoserver.extension/gs-arcsde/2.9-SNAPSHOT/gs-arcsde-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to org.geoserver.extension/gs-app-schema-test/2.9-SNAPSHOT/gs-app-schema-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/teradata/pom.xml&gt; to org.geoserver.extension/gs-teradata/2.9-SNAPSHOT/gs-teradata-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wfs/pom.xml&gt; to org.geoserver.web/gs-web-wfs/2.9-SNAPSHOT/gs-web-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml&gt; to org.geoserver.extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/gdal/pom.xml&gt; to org.geoserver.extension/gs-gdal/2.9-SNAPSHOT/gs-gdal-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/core/pom.xml&gt; to org.geoserver.extension/gs-dxf-core/2.9-SNAPSHOT/gs-dxf-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/pom.xml&gt; to org.geoserver.extension/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/pom.xml&gt; to org.geoserver.extension/gs-ogr/2.9-SNAPSHOT/gs-ogr-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/pom.xml&gt; to org.geoserver.extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/pom.xml&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/db2/pom.xml&gt; to org.geoserver.extension/gs-db2/2.9-SNAPSHOT/gs-db2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/pom.xml&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/charts/pom.xml&gt; to org.geoserver.extension/gs-charts/2.9-SNAPSHOT/gs-charts-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/pom.xml&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/core/pom.xml&gt; to org.geoserver.web/gs-web-core/2.9-SNAPSHOT/gs-web-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/pom.xml&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml&gt; to org.geoserver.extension/gs-monitor-hibernate/2.9-SNAPSHOT/gs-monitor-hibernate-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/pom.xml&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo-core/2.9-SNAPSHOT/gs-wcs2_0-eo-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/pom.xml&gt; to org.geoserver/web/2.9-SNAPSHOT/web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml&gt; to org.geoserver.extension/gs-libjpeg-turbo/2.9-SNAPSHOT/gs-libjpeg-turbo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/pom.xml&gt; to org.geoserver/extension/2.9-SNAPSHOT/extension-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/ldap/pom.xml&gt; to org.geoserver.web/gs-web-sec-ldap/2.9-SNAPSHOT/gs-web-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/pom.xml&gt; to org.geoserver.extension/gs-wps/2.9-SNAPSHOT/gs-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/pom.xml&gt; to org.geoserver.extension/gs-dxf/2.9-SNAPSHOT/gs-dxf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml&gt; to org.geoserver.csw/gs-csw-simple-store/2.9-SNAPSHOT/gs-csw-simple-store-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml&gt; to org.geoserver.extension/gs-sample-data-access-test/2.9-SNAPSHOT/gs-sample-data-access-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml&gt; to org.geoserver.extension/gs-feature-pregeneralized/2.9-SNAPSHOT/gs-feature-pregeneralized-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/core/pom.xml&gt; to org.geoserver.csw/gs-csw-core/2.9-SNAPSHOT/gs-csw-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/pom.xml&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/community/pom.xml&gt; to org.geoserver/community/2.9-SNAPSHOT/community-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/pom.xml&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/pom.xml&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to org.geoserver.extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/excel/pom.xml&gt; to org.geoserver.extension/gs-excel/2.9-SNAPSHOT/gs-excel-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wms/pom.xml&gt; to org.geoserver.web/gs-web-wms/2.9-SNAPSHOT/gs-web-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/inspire/pom.xml&gt; to org.geoserver.extension/gs-inspire/2.9-SNAPSHOT/gs-inspire-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml&gt; to org.geoserver.extension/gs-wps-core/2.9-SNAPSHOT/gs-wps-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/css/pom.xml&gt; to org.geoserver.extension/gs-css/2.9-SNAPSHOT/gs-css-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/pom.xml&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf/pom.xml&gt; to org.geoserver.extension/gs-netcdf/2.9-SNAPSHOT/gs-netcdf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/pom.xml&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/cas/pom.xml&gt; to org.geoserver.security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml&gt; to org.geoserver.extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/pom.xml&gt; to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/rest/pom.xml&gt; to org.geoserver.web/gs-web-rest/2.9-SNAPSHOT/gs-web-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/pom.xml&gt; to org.geoserver.extension/gs-monitor/2.9-SNAPSHOT/gs-monitor-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/pom.xml&gt; to org.geoserver/gs-restconfig/2.9-SNAPSHOT/gs-restconfig-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/pom.xml&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/pom.xml&gt; to org.geoserver.web/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/pom.xml&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemap/pom.xml&gt; to org.geoserver.extension/gs-imagemap/2.9-SNAPSHOT/gs-imagemap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/xslt/pom.xml&gt; to org.geoserver/gs-xslt/2.9-SNAPSHOT/gs-xslt-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/mysql/pom.xml&gt; to org.geoserver.extension/gs-mysql/2.9-SNAPSHOT/gs-mysql-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/grib/pom.xml&gt; to org.geoserver.extension/gs-grib/2.9-SNAPSHOT/gs-grib-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/pom.xml&gt; to org.geoserver/gs-csw/2.9-SNAPSHOT/gs-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/oracle/pom.xml&gt; to org.geoserver.extension/gs-oracle/2.9-SNAPSHOT/gs-oracle-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/sqlserver/pom.xml&gt; to org.geoserver.extension/gs-sqlserver/2.9-SNAPSHOT/gs-sqlserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/bdb/pom.xml&gt; to org.geoserver.importer/gs-importer-bdb/2.9-SNAPSHOT/gs-importer-bdb-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/demo/pom.xml&gt; to org.geoserver.web/gs-web-demo/2.9-SNAPSHOT/gs-web-demo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/core/pom.xml&gt; to org.geoserver.extension/gs-monitor-core/2.9-SNAPSHOT/gs-monitor-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml&gt; to org.geoserver.extension/gs-ogr-core/2.9-SNAPSHOT/gs-ogr-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/core/pom.xml&gt; to org.geoserver.importer/gs-importer-core/2.9-SNAPSHOT/gs-importer-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/pom.xml&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml&gt; to org.geoserver.extension/gs-ogr-wfs/2.9-SNAPSHOT/gs-ogr-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/pom.xml&gt; to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/target/gs-security-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/h2/pom.xml&gt; to org.geoserver.extension/gs-h2/2.9-SNAPSHOT/gs-h2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wcs/pom.xml&gt; to org.geoserver.web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/jp2k/pom.xml&gt; to org.geoserver.extension/gs-jp2k/2.9-SNAPSHOT/gs-jp2k-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/pom.xml&gt; to org.geoserver/gs-importer/2.9-SNAPSHOT/gs-importer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/app/pom.xml&gt; to org.geoserver.web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/control-flow/pom.xml&gt; to org.geoserver.extension/gs-control-flow/2.9-SNAPSHOT/gs-control-flow-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml&gt; to org.geoserver.extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/pom.xml&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-tests.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-sources.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-test-sources.jar&gt; to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to org.geoserver.extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/gwc/pom.xml&gt; to org.geoserver.web/gs-web-gwc/2.9-SNAPSHOT/gs-web-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/core/pom.xml&gt; to org.geoserver.web/gs-web-sec-core/2.9-SNAPSHOT/gs-web-sec-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml&gt; to org.geoserver.security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/jdbc/pom.xml&gt; to org.geoserver.web/gs-web-sec-jdbc/2.9-SNAPSHOT/gs-web-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/printing/pom.xml&gt; to org.geoserver.extension/gs-printing/2.9-SNAPSHOT/gs-printing-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/web/pom.xml&gt; to org.geoserver.importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/rest/pom.xml&gt; to org.geoserver.importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/wps/pom.xml&gt; to org.geoserver.extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/querylayer/pom.xml&gt; to org.geoserver.extension/gs-querylayer/2.9-SNAPSHOT/gs-querylayer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/api/pom.xml&gt; to org.geoserver.csw/gs-csw-api/2.9-SNAPSHOT/gs-csw-api-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml&gt; to org.geoserver.extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/pom.xml&gt; to org.geoserver.extension/gs-app-schema/2.9-SNAPSHOT/gs-app-schema-2.9-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/144/changes&gt;
Changes:
[tbarsballe] Update Mac Jenkins URL
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.289 sec
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.513 sec <<< FAILURE!
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.824 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.009 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.361 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.368 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.435 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.388 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.341 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.309 sec
Results :
[INFO]
[INFO] Finished at: 2016-09-22T18:32:41+02:00
[INFO] Final Memory: 104M/503M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/145/changes&gt;
Changes:
[Andrea Aime] Follow up on GEOT-5514. No known usable attack vectors as the WMS
[Andrea Aime] GEOT-5514 follow up, adding missing file
[...truncated 127 lines...]
[INFO] DXF WPS PPIO
[INFO]
[INFO] Building Main Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-main ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-main ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-main ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-main ---
[INFO] Copying 34 resources
[INFO] Copying 169 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-main ---
[INFO] Compiling 617 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/catalog/ResourcePool.java&gt;:\[1713,30\] error: no suitable constructor found for WebMapServer(URL,HTTPClient,Map<String,Object>)
[INFO] 1 error
[INFO]
[INFO] Main Module ........................................ FAILURE [ 10.711 s]
[INFO] Total time: 21.437 s
[INFO] Finished at: 2016-09-23T10:31:46+02:00
[INFO] Final Memory: 102M/504M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/146/changes&gt;
Changes:
[emerkle] Remove GeoGig OSM dependencies
[INFO] DXF WPS PPIO
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] 1 error
[INFO]
[INFO] Main Module ........................................ FAILURE [ 11.824 s]
[INFO] Total time: 22.888 s
[INFO] Finished at: 2016-09-24T08:31:44+02:00
[INFO] Final Memory: 103M/488M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/148/changes&gt;
Changes:
[jody.garnett] Inject entity resolver in stores that are exposing it
[jody.garnett] Tap other points where SLDParser was used without a corresponding
[...truncated 848 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Compiling 618 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/classes&gt;
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/util/EntityResolverProvider.java&gt;:\[9,23\] error: cannot find symbol
[ERROR] package org.geotools.xml
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/util/NoExternalEntityResolver.java&gt;:\[17,62\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/util/EntityResolverProvider.java&gt;:\[44,39\] error: cannot find symbol
[INFO] 3 errors
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.722 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.453 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.594 s]
[INFO] Main Module ........................................ FAILURE [ 9.194 s]
[INFO] Total time: 48.802 s
[INFO] Finished at: 2016-09-28T02:32:06+02:00
[INFO] Final Memory: 126M/337M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/util/NoExternalEntityResolver.java&gt;:\[17,62\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/src/main/java/org/geoserver/util/EntityResolverProvider.java&gt;:\[44,39\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/149/&gt;
