See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/23/changes>
Changes:
[jody.garnett] Update memory settings/defaults for Java 8 (#1641)
[...truncated 11190 lines...]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 22.683 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.631 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:21 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:49 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.522 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 52.398 s]
[INFO] REST Support Module ................................ SUCCESS [ 12.942 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:00 min]
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:54 min
[INFO] Finished at: 2016-06-24T01:42:11+02:00
[INFO] Final Memory: 112M/560M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/web-csw/pom.xml> to org.geoserver.csw/gs-web-csw/2.9-SNAPSHOT/gs-web-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf-out/pom.xml> to org.geoserver.extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/arcsde/pom.xml> to org.geoserver.extension/gs-arcsde/2.9-SNAPSHOT/gs-arcsde-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml> to org.geoserver.extension/gs-app-schema-test/2.9-SNAPSHOT/gs-app-schema-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/teradata/pom.xml> to org.geoserver.extension/gs-teradata/2.9-SNAPSHOT/gs-teradata-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wfs/pom.xml> to org.geoserver.web/gs-web-wfs/2.9-SNAPSHOT/gs-web-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wps/pom.xml> to org.geoserver.extension/gs-ogr-wps/2.9-SNAPSHOT/gs-ogr-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/gdal/pom.xml> to org.geoserver.extension/gs-gdal/2.9-SNAPSHOT/gs-gdal-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/core/pom.xml> to org.geoserver.extension/gs-dxf-core/2.9-SNAPSHOT/gs-dxf-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/pom.xml> to org.geoserver.extension/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/pom.xml> to org.geoserver.extension/gs-ogr/2.9-SNAPSHOT/gs-ogr-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/pom.xml> to org.geoserver.extension/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/pom.xml> to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT.jar> to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs/target/gs-wcs-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs/2.9-SNAPSHOT/gs-wcs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/db2/pom.xml> to org.geoserver.extension/gs-db2/2.9-SNAPSHOT/gs-db2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/pom.xml> to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT.jar> to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_1/target/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_1/2.9-SNAPSHOT/gs-wcs1_1-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/charts/pom.xml> to org.geoserver.extension/gs-charts/2.9-SNAPSHOT/gs-charts-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/pom.xml> to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT.jar> to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs1_0/target/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs1_0/2.9-SNAPSHOT/gs-wcs1_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/core/pom.xml> to org.geoserver.web/gs-web-core/2.9-SNAPSHOT/gs-web-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/pom.xml> to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT.jar> to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wcs2_0/target/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wcs2_0/2.9-SNAPSHOT/gs-wcs2_0-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/hibernate/pom.xml> to org.geoserver.extension/gs-monitor-hibernate/2.9-SNAPSHOT/gs-monitor-hibernate-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/pom.xml> to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT.jar> to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/jdbc/target/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-jdbc/2.9-SNAPSHOT/gs-sec-jdbc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/core/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo-core/2.9-SNAPSHOT/gs-wcs2_0-eo-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/pom.xml> to org.geoserver/web/2.9-SNAPSHOT/web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/libjpeg-turbo/pom.xml> to org.geoserver.extension/gs-libjpeg-turbo/2.9-SNAPSHOT/gs-libjpeg-turbo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/pom.xml> to org.geoserver/extension/2.9-SNAPSHOT/extension-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/ldap/pom.xml> to org.geoserver.web/gs-web-sec-ldap/2.9-SNAPSHOT/gs-web-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/pom.xml> to org.geoserver.extension/gs-wps/2.9-SNAPSHOT/gs-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/pom.xml> to org.geoserver.extension/gs-dxf/2.9-SNAPSHOT/gs-dxf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/simple-store/pom.xml> to org.geoserver.csw/gs-csw-simple-store/2.9-SNAPSHOT/gs-csw-simple-store-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/sample-data-access-test/pom.xml> to org.geoserver.extension/gs-sample-data-access-test/2.9-SNAPSHOT/gs-sample-data-access-test-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/feature-pregeneralized/pom.xml> to org.geoserver.extension/gs-feature-pregeneralized/2.9-SNAPSHOT/gs-feature-pregeneralized-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/core/pom.xml> to org.geoserver.csw/gs-csw-core/2.9-SNAPSHOT/gs-csw-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/pom.xml> to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT.jar> to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/ows/target/gs-ows-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-ows/2.9-SNAPSHOT/gs-ows-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/community/pom.xml> to org.geoserver/community/2.9-SNAPSHOT/community-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/pom.xml> to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT.jar> to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wfs/target/gs-wfs-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wfs/2.9-SNAPSHOT/gs-wfs-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/pom.xml> to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT.jar> to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-tests.jar> to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-sources.jar> to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/ldap/target/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar> to org.geoserver.security/gs-sec-ldap/2.9-SNAPSHOT/gs-sec-ldap-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to org.geoserver.extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/excel/pom.xml> to org.geoserver.extension/gs-excel/2.9-SNAPSHOT/gs-excel-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wms/pom.xml> to org.geoserver.web/gs-web-wms/2.9-SNAPSHOT/gs-web-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/inspire/pom.xml> to org.geoserver.extension/gs-inspire/2.9-SNAPSHOT/gs-inspire-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/wps-core/pom.xml> to org.geoserver.extension/gs-wps-core/2.9-SNAPSHOT/gs-wps-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/css/pom.xml> to org.geoserver.extension/gs-css/2.9-SNAPSHOT/gs-css-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/pom.xml> to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT.jar> to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/main/target/gs-main-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-main/2.9-SNAPSHOT/gs-main-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/netcdf/pom.xml> to org.geoserver.extension/gs-netcdf/2.9-SNAPSHOT/gs-netcdf-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/pom.xml> to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT.jar> to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/rest/target/gs-rest-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-rest/2.9-SNAPSHOT/gs-rest-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/cas/pom.xml> to org.geoserver.security/gs-sec-cas/2.9-SNAPSHOT/gs-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/pom.xml> to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar> to org.geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/rest/pom.xml> to org.geoserver.web/gs-web-rest/2.9-SNAPSHOT/gs-web-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/pom.xml> to org.geoserver.extension/gs-monitor/2.9-SNAPSHOT/gs-monitor-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/restconfig/pom.xml> to org.geoserver/gs-restconfig/2.9-SNAPSHOT/gs-restconfig-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/pom.xml> to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT.jar> to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/platform/target/gs-platform-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-platform/2.9-SNAPSHOT/gs-platform-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/pom.xml> to org.geoserver.web/gs-web-sec/2.9-SNAPSHOT/gs-web-sec-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/pom.xml> to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT.jar> to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/wms/target/gs-wms-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-wms/2.9-SNAPSHOT/gs-wms-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemap/pom.xml> to org.geoserver.extension/gs-imagemap/2.9-SNAPSHOT/gs-imagemap-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/xslt/pom.xml> to org.geoserver/gs-xslt/2.9-SNAPSHOT/gs-xslt-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/mysql/pom.xml> to org.geoserver.extension/gs-mysql/2.9-SNAPSHOT/gs-mysql-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/grib/pom.xml> to org.geoserver.extension/gs-grib/2.9-SNAPSHOT/gs-grib-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/pom.xml> to org.geoserver/gs-csw/2.9-SNAPSHOT/gs-csw-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/oracle/pom.xml> to org.geoserver.extension/gs-oracle/2.9-SNAPSHOT/gs-oracle-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/sqlserver/pom.xml> to org.geoserver.extension/gs-sqlserver/2.9-SNAPSHOT/gs-sqlserver-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/bdb/pom.xml> to org.geoserver.importer/gs-importer-bdb/2.9-SNAPSHOT/gs-importer-bdb-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/demo/pom.xml> to org.geoserver.web/gs-web-demo/2.9-SNAPSHOT/gs-web-demo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/monitor/core/pom.xml> to org.geoserver.extension/gs-monitor-core/2.9-SNAPSHOT/gs-monitor-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-core/pom.xml> to org.geoserver.extension/gs-ogr-core/2.9-SNAPSHOT/gs-ogr-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/core/pom.xml> to org.geoserver.importer/gs-importer-core/2.9-SNAPSHOT/gs-importer-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/pom.xml> to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT.jar> to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/gwc/target/gs-gwc-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-gwc/2.9-SNAPSHOT/gs-gwc-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/ogr/ogr-wfs/pom.xml> to org.geoserver.extension/gs-ogr-wfs/2.9-SNAPSHOT/gs-ogr-wfs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/pom.xml> to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/security/target/gs-security-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-security/2.9-SNAPSHOT/gs-security-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/h2/pom.xml> to org.geoserver.extension/gs-h2/2.9-SNAPSHOT/gs-h2-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/wcs/pom.xml> to org.geoserver.web/gs-web-wcs/2.9-SNAPSHOT/gs-web-wcs-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/jp2k/pom.xml> to org.geoserver.extension/gs-jp2k/2.9-SNAPSHOT/gs-jp2k-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/pom.xml> to org.geoserver/gs-importer/2.9-SNAPSHOT/gs-importer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/app/pom.xml> to org.geoserver.web/gs-web-app/2.9-SNAPSHOT/gs-web-app-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/control-flow/pom.xml> to org.geoserver.extension/gs-control-flow/2.9-SNAPSHOT/gs-control-flow-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/imagemosaic-jdbc/pom.xml> to org.geoserver.extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/pom.xml> to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT.jar> to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-tests.jar> to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-tests.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-sources.jar> to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/kml/target/gs-kml-2.9-SNAPSHOT-test-sources.jar> to org.geoserver/gs-kml/2.9-SNAPSHOT/gs-kml-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wcs2_0-eo/web/pom.xml> to org.geoserver.extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/gwc/pom.xml> to org.geoserver.web/gs-web-gwc/2.9-SNAPSHOT/gs-web-gwc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/core/pom.xml> to org.geoserver.web/gs-web-sec-core/2.9-SNAPSHOT/gs-web-sec-core-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/security/web/web-cas/pom.xml> to org.geoserver.security/gs-web-sec-cas/2.9-SNAPSHOT/gs-web-sec-cas-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/web/security/jdbc/pom.xml> to org.geoserver.web/gs-web-sec-jdbc/2.9-SNAPSHOT/gs-web-sec-jdbc-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/printing/pom.xml> to org.geoserver.extension/gs-printing/2.9-SNAPSHOT/gs-printing-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/web/pom.xml> to org.geoserver.importer/gs-importer-web/2.9-SNAPSHOT/gs-importer-web-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/importer/rest/pom.xml> to org.geoserver.importer/gs-importer-rest/2.9-SNAPSHOT/gs-importer-rest-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/dxf/wps/pom.xml> to org.geoserver.extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/querylayer/pom.xml> to org.geoserver.extension/gs-querylayer/2.9-SNAPSHOT/gs-querylayer-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/csw/api/pom.xml> to org.geoserver.csw/gs-csw-api/2.9-SNAPSHOT/gs-csw-api-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/wps/web-wps/pom.xml> to org.geoserver.extension/gs-web-wps/2.9-SNAPSHOT/gs-web-wps-2.9-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.9.x-OpenJDK8/ws/src/extension/app-schema/pom.xml> to org.geoserver.extension/gs-app-schema/2.9-SNAPSHOT/gs-app-schema-2.9-SNAPSHOT.pom
channel stopped
