See <https://build.geoserver.org/job/geoserver-java11/1052/display/redirect?page=changes>
Changes:
[daniele.romagnoli] [GEOS-9315]: Nodata transparency on channelSelect+constrastEnhancement
[...truncated 1.59 MB...]
[INFO] T E S T S
[INFO] -------------------------------------------------------
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.854 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.272 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [95/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar>
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 676.622 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.383 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.196 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.714 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.103 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.147 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.726 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 29.386 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.266 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.605 s]
[INFO] Main Module ........................................ SUCCESS [01:31 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.094 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:42 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.604 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.545 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.630 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.820 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.323 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:48 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:52 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:38 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.693 s]
[INFO] gs-rest ............................................ SUCCESS [ 13.163 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 55.311 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:49 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.618 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.603 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.112 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.236 s]
[INFO] Core UI Module ..................................... SUCCESS [01:33 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 24.156 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.660 s]
[INFO] Demos Module ....................................... SUCCESS [ 13.578 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.839 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.073 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [10:19 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.855 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.567 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 28.504 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Application Schema Integration Test ................ SUCCESS [05:18 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.785 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.399 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.591 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.825 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.168 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.964 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.273 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.219 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.289 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.911 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.572 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.677 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:50 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.139 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.129 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.407 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.686 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.822 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.560 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.456 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 17.790 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.817 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.585 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.543 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.388 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.169 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.419 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.436 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.432 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 58.638 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.294 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 10.318 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.934 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.085 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [03:56 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.955 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 29.038 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 30.445 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [04:30 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.414 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.687 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.675 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [04:27 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.104 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.411 s]
[INFO] REST SLD service ................................... SUCCESS [02:26 min]
[INFO] GeoFence security integration ...................... SUCCESS [04:18 min]
[INFO] GeoFence Server .................................... SUCCESS [11:37 min]
[INFO] Authentication by unique url key ................... SUCCESS [05:59 min]
[INFO] BUILD FAILURE
[INFO] Total time: 44:40 min (Wall Clock)
[INFO] Finished at: 2019-09-04T09:56:52Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
