[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #1085
See <https://build.geoserver.org/job/geoserver-java11/1085/display/redirect&gt;
[...truncated 1.58 MB...]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.pom (1.1 kB at 368 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom (4.1 kB at 276 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar (43 kB at 6.1 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar (788 kB at 28 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sec-jdbc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-jdbc ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sec-jdbc ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-sec-jdbc ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-jdbc ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sec-jdbc ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-jdbc ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sec-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sec-jdbc ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-jdbc ---
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 26.333 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.588 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.025 s]
[INFO] Main Module ........................................ SUCCESS [01:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.055 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:25 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 1.736 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.039 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.926 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.364 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.069 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 0.833 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:16 min]
[INFO] Web Map Service Module ............................. FAILURE [ 17.024 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 8.250 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... FAILURE [01:05 min]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.102 s]
[INFO] Core UI Module ..................................... SUCCESS [01:04 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... FAILURE [ 0.037 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ FAILURE [ 0.222 s]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.025 s]
[INFO] Printing Module .................................... SUCCESS [ 37.567 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 0.255 s]
[INFO] ArcSDE DataStore Extension ......................... FAILURE [ 12.117 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.140 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.655 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.904 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.695 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.394 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.017 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.397 s]
[INFO] OGR WFS ............................................ FAILURE [ 0.235 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.015 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ FAILURE [ 3.017 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.742 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.573 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.689 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.275 s]
[INFO] GeoServer Layer Querying filter functions .......... FAILURE [ 0.061 s]
[INFO] Teradata DataStore Extension ....................... FAILURE [ 9.374 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 0.661 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 3.049 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. FAILURE [ 0.037 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... FAILURE [ 17.215 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:21 min (Wall Clock)
[INFO] Finished at: 2019-09-06T22:51:45Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-teradata: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/teradata/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal on project gs-arcsde: Could not resolve dependencies for project org.geoserver.extension:gs-arcsde:jar:2.17-SNAPSHOT: Could not find artifact org.geotools:gt-arcsde-common:jar:23-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wms: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wfs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-grib: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/grib/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sample-data-access-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/sample-data-access-test/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ogr-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/ogr-wfs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-querylayer: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/querylayer/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-dxf-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/core/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-excel: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/excel/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-api: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wcs2_0/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-monitor: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/core/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <https://build.geoserver.org/job/geoserver-java11/1086/display/redirect&gt;
