See <https://build.geoserver.org/job/geoserver-java11/1146/display/redirect>
[...truncated 2.31 MB...]
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-notification ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-notification ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[debug] Using AOSP style
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] ----------------< org.geoserver.community:gs-metadata >-----------------
[INFO] Building GeoServer Metadata Customizer 2.17-SNAPSHOT [81/82]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom (14 kB at 4.8 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom (498 B at 124 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom (1.3 kB at 318 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom (44 kB at 6.2 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom (4.6 kB at 764 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/oss-parent/11/oss-parent-11.pom (23 kB at 2.3 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar (12 kB at 2.0 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar (354 kB at 27 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar (27 kB at 1.5 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-metadata ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-metadata ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-metadata ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-metadata ---
[INFO] Copying 5 resources
[INFO] Copying 22 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-metadata ---
[INFO] Compiling 89 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-metadata ---
[INFO] Copying 12 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-metadata ---
[INFO] Compiling 17 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-metadata ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-metadata ---
[INFO] Processed 100 files (0 non-complying).
[INFO] Processed 106 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-metadata ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for Community Space 2.17-SNAPSHOT:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 3.041 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.764 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 4.926 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.173 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 1.938 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 1.551 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 1.351 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.759 s]
[INFO] WMS-EO ............................................. SUCCESS [ 1.649 s]
[INFO] ColorMap ........................................... SUCCESS [ 1.332 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 1.572 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 1.486 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.536 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 1.149 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 1.454 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 1.088 s]
[INFO] DownloadProcess .................................... SUCCESS [ 4.661 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.322 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 11.041 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 5.404 s]
[INFO] GeoServer JMS clustering module .................... FAILURE [ 8.998 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.806 s]
[INFO] Solr Module ........................................ SUCCESS [ 9.280 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 2.090 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 21.710 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.403 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 1.324 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.879 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.057 s]
[INFO] GeoWebCache Azure blob ............................. SUCCESS [ 16.669 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.035 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 1.087 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 1.020 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 1.710 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 1.510 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.559 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 12.074 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 1.145 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 0.724 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 1.454 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 1.469 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 1.638 s]
[INFO] WMTS Style editing extension ....................... SUCCESS [ 1.251 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.019 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 5.437 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 1.618 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 1.211 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 1.131 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 1.297 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 9.268 s]
[INFO] GeoServer SAMLv2 SSO Module ........................ SUCCESS [ 8.940 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.715 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.536 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 1.262 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.565 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.014 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 2.730 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 1.395 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.783 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.023 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.800 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 1.585 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 1.736 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 17.078 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 4.901 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 5.992 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 2.030 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 4.252 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 17.269 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 1.254 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 3.150 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 1.138 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 0.018 s]
[INFO] gs-ogcapi-core ..................................... SUCCESS [ 1.461 s]
[INFO] gs-ogcapi-features ................................. SUCCESS [ 1.362 s]
[INFO] gs-ogcapi-styles ................................... SUCCESS [ 1.460 s]
[INFO] gs-ogcapi-tiles .................................... SUCCESS [ 1.678 s]
[INFO] Catalog Services for the Web ISO metadata profile module SUCCESS [ 1.337 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoStyler community module ......................... SUCCESS [ 1.500 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 26.235 s]
[INFO] GeoServer Metadata Customizer ...................... SUCCESS [ 6.489 s]
[INFO] BUILD FAILURE
[INFO] Total time: 05:01 min
[INFO] Finished at: 2019-09-10T18:25:34Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-jms-geoserver: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/jms-cluster/jms-geoserver/src/test/java/org/geoserver/cluster/integration/GeoServerInstance.java>:\[89,42\] cannot access org.geoserver.platform.resource.ResourceStore
[ERROR] bad class file: <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar(/org/geoserver/platform/resource/ResourceStore.class)>
[ERROR] unable to access file: java.util.zip.ZipException: invalid distance too far back
[ERROR] Please remove or make sure it appears in the correct subdirectory of the classpath.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-jms-geoserver
