[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #1179
See <https://build.geoserver.org/job/geoserver-java11/1179/display/redirect&gt;
Started by an SCM change
Running as SYSTEM
Building remotely on FleetCloud i-09e0377aecc45d8fc (linux-fleet)Unpacking https://github.com/AdoptOpenJDK/openjdk11-binaries/releases/download/jdk-11.0.3%2B7/OpenJDK11U-jdk_x64_linux_hotspot_11.0.3_7.tar.gz to /tmp/jenkins-8c788eb0/tools/hudson.model.JDK/OpenJDK_11.0.3 on FleetCloud i-09e0377aecc45d8fc
in workspace <https://build.geoserver.org/job/geoserver-java11/ws/&gt;
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-java11/ws/geoserver&gt; # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision a7b6baee5f98cfb3015d4b4021bd9b8a03ccc18d (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f a7b6baee5f98cfb3015d4b4021bd9b8a03ccc18d
Commit message: "Merge pull request #3766 from dromagnoli/GEOS-9330"
> git rev-list --no-walk a7b6baee5f98cfb3015d4b4021bd9b8a03ccc18d # timeout=10
[java11] $ /bin/sh -xe /tmp/jenkins4954308888747468827.sh
+ mkdir ./m2
+ chmod 777 ./m2
[java11] $ mvn -f geoserver/src/pom.xml -B -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2 -fae -Dmaven.repo.local=m2
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.google.inject.internal.cglib.core.$ReflectUtils$1 (file:/usr/share/maven/lib/guice.jar) to method java.lang.ClassLoader.defineClass(java.lang.String,byte,int,int,java.security.ProtectionDomain)
WARNING: Please consider reporting this to the maintainers of com.google.inject.internal.cglib.core.$ReflectUtils$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-readable POM <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml&gt; (No such file or directory) @
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project (<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml)> has 1 error
[ERROR] Non-readable POM <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml&gt; (No such file or directory)
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
See <https://build.geoserver.org/job/geoserver-java11/1180/display/redirect&gt;
