[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #1190
See <https://build.geoserver.org/job/geoserver-java11/1190/display/redirect&gt;
[...truncated 2.33 MB...]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.666 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.082 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 57.779 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:27 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.308 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.579 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 29.636 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.266 s]
[INFO] Core UI Module ..................................... SUCCESS [01:04 min]
[INFO] WMS UI Module ...................................... SUCCESS [04:35 min]
[INFO] GWC UI Module ...................................... SUCCESS [ 32.878 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.093 s]
[INFO] Demos Module ....................................... SUCCESS [03:50 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.420 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [04:56 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.445 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.194 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.024 s]
[INFO] Printing Module .................................... SUCCESS [ 27.585 s]
[INFO] GeoServer Web Application .......................... FAILURE [ 12.571 s]
[INFO] Community Space .................................... SUCCESS [ 0.021 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Application Schema Integration Test ................ FAILURE [01:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.924 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.508 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.185 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.214 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.409 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.916 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.252 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.801 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.928 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.323 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.404 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.493 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ FAILURE [ 14.227 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.185 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.902 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.645 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.836 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.371 s]
[INFO] Web process status sharing with Hazelcast .......... FAILURE [ 1.535 s]
[INFO] Web Processing Service GUI ......................... FAILURE [ 4.796 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.607 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.586 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.031 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.933 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.736 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. FAILURE [ 0.691 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.384 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 22.610 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.466 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.036 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.705 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.212 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.876 s]
[INFO] CSW UI Module ...................................... FAILURE [ 1.734 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.300 s]
[INFO] DXF WPS PPIO ....................................... FAILURE [ 0.710 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.740 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension FAILURE [ 15.529 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.885 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 5.259 s]
[INFO] Importer Core Module ............................... SUCCESS [ 34.230 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 2.147 s]
[INFO] Importer Berkley DB Persistence Module ............. FAILURE [ 0.896 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 1.327 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.954 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [04:59 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 26.090 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.092 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.082 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.836 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.614 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.922 s]
[INFO] GeoFence Server .................................... FAILURE [ 18.841 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 46.131 s]
[INFO] BUILD FAILURE
[INFO] Total time: 25:50 min (Wall Clock)
[INFO] Finished at: 2019-09-13T14:09:19Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[10,41\] package org.geoserver.geofence.core.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[11,47\] package org.geoserver.geofence.core.model.enums does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[13,39\] package org.geoserver.geofence.services does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[14,39\] package org.geoserver.geofence.services does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[15,43\] package org.geoserver.geofence.services.dto does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[16,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[17,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[24,15\] cannot find symbol
[ERROR] symbol: class RuleAdminService
[ERROR] location: class org.geoserver.geofence.internal.InternalServicesTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[9,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[10,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[11,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[12,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[16,39\] package org.geoserver.geofence.core.dao does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[17,41\] package org.geoserver.geofence.core.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[18,47\] package org.geoserver.geofence.core.model.enums does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[22,39\] package org.geoserver.geofence.services does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[23,49\] package org.geoserver.geofence.services.exception does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[24,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[26,32\] package org.springframework.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[27,32\] package org.springframework.http does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[33,15\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] location: class org.geoserver.geofence.rest.AdminRulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[257,13\] cannot find symbol
[ERROR] symbol: class ResponseEntity
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[257,55\] cannot find symbol
[ERROR] symbol: class HttpStatus
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[9,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[10,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[11,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[12,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[13,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[13,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[14,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[14,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[15,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[15,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[18,19\] package net.sf.json does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[19,19\] package net.sf.json does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[21,39\] package org.geoserver.geofence.core.dao does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[22,41\] package org.geoserver.geofence.core.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[23,41\] package org.geoserver.geofence.core.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[24,47\] package org.geoserver.geofence.core.model.enums does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[29,43\] package org.geoserver.geofence.services.dto does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[32,34\] package org.geotools.gml3.bindings does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[35,31\] package org.locationtech.jts.io does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[36,31\] package org.locationtech.jts.io does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[39,36\] package org.springframework.mock.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[45,15\] cannot find symbol
[ERROR] location: class org.geoserver.geofence.rest.RulesRestControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[631,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[631,50\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[8,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalUserResolverTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[10,42\] package org.apache.wicket.ajax.markup.html does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[11,37\] package org.apache.wicket.util.tester does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerPageTest.java&gt;:\[14,43\] package org.geoserver.geofence.services.dto does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[10,42\] package org.apache.wicket.ajax.markup.html does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[11,37\] package org.apache.wicket.util.tester does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceServerAdminPageTest.java&gt;:\[14,43\] package org.geoserver.geofence.services.dto does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[8,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/web/GeofenceRulesModelTest.java&gt;:\[14,43\] package org.geoserver.geofence.services.dto does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[8,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[13,34\] package org.geotools.gml3.bindings does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[14,30\] package org.geotools.gml3.v3_2 does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/MultiPolygonAdapterTest.java&gt;:\[16,33\] package org.locationtech.jts.geom does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[26,6\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/internal/InternalServicesTest.java&gt;:\[45,6\] cannot find symbol
[ERROR] symbol: class Test
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[35,6\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[42,6\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/AdminRulesRestControllerTest.java&gt;:\[121,6\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[47,6\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/src/test/java/org/geoserver/geofence/rest/RulesRestControllerTest.java&gt;:\[53,6\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ogr-wps: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/ogr-wps/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wcs2_0-eo: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/web/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wps-cluster-hazelcast: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-dxf-wps: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/wps/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-csw: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/web-csw/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wps: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/web-wps/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-rest: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-bdb: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-web: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-cas: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-app: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <https://build.geoserver.org/job/geoserver-java11/1191/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-9316] Support for vector custom dimensions (#3732)
[...truncated 2.10 MB...]
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:365)
  at org.apache.maven.surefire.junit4.JUnit4Provider.executeWithRerun(JUnit4Provider.java:273)
  at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:238)
  at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:159)
  at org.apache.maven.surefire.booter.ForkedBooter.invokeProviderInSameClassLoader(ForkedBooter.java:384)
  at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:345)
  at org.apache.maven.surefire.booter.ForkedBooter.execute(ForkedBooter.java:126)
  at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:418)
[INFO] Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.361 s - in org.geoserver.importer.rest.ImporterIntegrationTest
[INFO] Running org.geoserver.importer.rest.PostScriptTransformTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 s - in org.geoserver.importer.rest.PostScriptTransformTest
[INFO] Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO] Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 s - in org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 77, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [100/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.594 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 30.415 s]
[INFO] Core Platform Module ............................... SUCCESS [ 24.505 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.317 s]
[INFO] Main Module ........................................ SUCCESS [01:16 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.797 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.304 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.651 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.529 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.413 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:14 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:06 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 17.762 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.135 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 57.284 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.451 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.139 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.272 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.125 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 23.759 s]
[INFO] GWC UI Module ...................................... SUCCESS [05:53 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.867 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.031 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.637 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:02 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [08:17 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.997 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.920 s]
[INFO] Printing Module .................................... SUCCESS [ 26.929 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.251 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:07 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.651 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.237 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.184 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.608 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.171 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.902 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.961 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.733 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.285 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.394 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.423 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.019 s]
[INFO] Web Processing Service Module ...................... SUCCESS [04:12 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.691 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.861 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.036 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.551 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.759 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.007 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 15.126 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 17.239 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.075 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.621 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.034 s]
[INFO] Core Monitor Extension ............................. SUCCESS [04:57 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.904 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.423 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.998 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 20.646 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.877 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.525 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.030 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 51.663 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.152 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.017 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.982 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.809 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.426 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [07:53 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.200 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.978 s]
[INFO] Importer Core Module ............................... SUCCESS [ 31.534 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 29.173 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.070 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.791 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.622 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [08:25 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:50 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 16.748 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.347 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.957 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.338 s]
[INFO] GeoFence security integration ...................... SUCCESS [04:50 min]
[INFO] GeoFence Server .................................... FAILURE [08:45 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 44.266 s]
[INFO] Total time: 44:01 min (Wall Clock)
[INFO] Finished at: 2019-09-13T15:34:08Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-geofence-server: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence-server/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/1192/display/redirect?page=changes&gt;
