[...truncated 155.15 KB...]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping GeoFence security integration
[INFO]
[INFO] Skipping Authentication by unique url key
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO] Skipping gs-restconfig-wcs
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 26.515 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 28.499 s (Wall Clock)
[INFO] Finished at: 2019-09-14T07:51:34Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project geoserver: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/pom.xml> isn't a file. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
