Jenkins
1
See <https://build.geoserver.org/job/geoserver-java11/1220/display/redirect>
[...truncated 1.36 MB...]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.pom (4.1 kB at 827 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/simple-jndi/simple-jndi/0.11.4.1/simple-jndi-0.11.4.1.jar (43 kB at 4.7 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/mysql/mysql-connector-java/5.1.17/mysql-connector-java-5.1.17.jar (788 kB at 41 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sec-jdbc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-jdbc ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sec-jdbc ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-sec-jdbc ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-jdbc ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sec-jdbc ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-jdbc ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sec-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sec-jdbc ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-jdbc ---
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 27.566 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.665 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.490 s]
[INFO] Main Module ........................................ SUCCESS [01:18 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:25 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 0.915 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.033 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.600 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.078 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.435 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 1.268 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] Web Map Service Module ............................. FAILURE [ 17.203 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 8.141 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... FAILURE [01:08 min]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.132 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... FAILURE [ 0.969 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.042 s]
[INFO] Security UI Core Module ............................ FAILURE [ 0.247 s]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.027 s]
[INFO] Printing Module .................................... SUCCESS [ 28.635 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.032 s]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 0.286 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.559 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.226 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.155 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.919 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.250 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.484 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.578 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.461 s]
[INFO] OGR WFS ............................................ FAILURE [ 0.286 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ FAILURE [ 3.137 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.650 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.659 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.914 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.968 s]
[INFO] GeoServer Layer Querying filter functions .......... FAILURE [ 0.038 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.590 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 0.259 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.034 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 1.863 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. FAILURE [ 0.033 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... FAILURE [ 22.117 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:20 min (Wall Clock)
[INFO] Finished at: 2019-09-15T07:51:28Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal on project gs-grib: Could not resolve dependencies for project org.geoserver.extension:gs-grib:jar:2.17-SNAPSHOT: Could not find artifact org.geotools:gt-netcdf:jar:23-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wfs/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sample-data-access-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/sample-data-access-test/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ogr-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/ogr-wfs/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wms: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-querylayer: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/querylayer/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-dxf-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/core/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-excel: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/excel/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wcs2_0/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-monitor: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-api: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/core/pom.xml> isn't a file. -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/pom.xml> isn't a file. -> [Help 3]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
Jenkins
2
See <https://build.geoserver.org/job/geoserver-java11/1221/display/redirect>
[...truncated 2.05 MB...]
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/sweCommon-1.0-gml32/1.0.1-1/sweCommon-1.0-gml32-1.0.1-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/geosciml-3.2/3.2.0-1/geosciml-3.2-3.2.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/sweCommon-2.0/2.0-1/sweCommon-2.0-2.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/xlink-1999/1.0.0-1/xlink-1999-1.0.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/samplingSpatial-2.0/2.0-1/samplingSpatial-2.0-2.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/wfs-2.0/2.0.0-2/wfs-2.0-2.0.0-2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/xml-1.0/1.0.0-3/xml-1.0-1.0.0-3.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/ows-1.1/1.1.0-1/ows-1.1-1.1.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/filter-2.0/2.0.0-2/filter-2.0-2.0.0-2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/samplingSpecimen-2.0/2.0.0-1/samplingSpecimen-2.0-2.0.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/sampling-2.0/2.0.0-1/sampling-2.0-2.0.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/schemas/om-2.0/2.0.0-1/om-2.0-2.0.0-1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-20190915.085356-275-tests.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-20190915.085356-275-tests.jar (22 kB at 28 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/net/sf/opencsv/opencsv/1.8/opencsv-1.8.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-2.0/2.0.2-4/geosciml-2.0-2.0.2-4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sampling-1.0/1.0.0-4/sampling-1.0-1.0.0-4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/om-1.0/1.0.0-4/om-1.0-1.0.0-4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sensorML-1.0/1.0.1-4/sensorML-1.0-1.0.1-4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ic-2.0/2.0.0-3/ic-2.0-2.0.0-3.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/om-1.0/1.0.0-4/om-1.0-1.0.0-4.jar (6.3 kB at 31 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-1.0/1.0.1-4/sweCommon-1.0-1.0.1-4.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sampling-1.0/1.0.0-4/sampling-1.0-1.0.0-4.jar (12 kB at 60 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/cgiutilities-1.0/1.0.0-4/cgiutilities-1.0-1.0.0-4.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sensorML-1.0/1.0.1-4/sensorML-1.0-1.0.1-4.jar (13 kB at 48 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/earthresourceml-1.1/1.1.0-3/earthresourceml-1.1-1.1.0-3.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-2.0/2.0.2-4/geosciml-2.0-2.0.2-4.jar (47 kB at 140 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/wfs-1.1/1.1.2-2/wfs-1.1-1.1.2-2.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/cgiutilities-1.0/1.0.0-4/cgiutilities-1.0-1.0.0-4.jar (4.6 kB at 13 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/data/refdataset-1.0/1.0.7/refdataset-1.0-1.0.7.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ic-2.0/2.0.0-3/ic-2.0-2.0.0-3.jar (7.3 kB at 21 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.0-seegrid/3.0.0-1/geosciml-3.0-seegrid-3.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-1.0/1.0.1-4/sweCommon-1.0-1.0.1-4.jar (23 kB at 56 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/iso-19156-seegrid/2.0.0-1/iso-19156-seegrid-2.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/earthresourceml-1.1/1.1.0-3/earthresourceml-1.1-1.1.0-3.jar (14 kB at 33 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-1.0-gml32/1.0.1-1/sweCommon-1.0-gml32-1.0.1-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/wfs-1.1/1.1.2-2/wfs-1.1-1.1.2-2.jar (16 kB at 35 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.2/3.2.0-1/geosciml-3.2-3.2.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/iso-19156-seegrid/2.0.0-1/iso-19156-seegrid-2.0.0-1.jar (18 kB at 34 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-2.0/2.0-1/sweCommon-2.0-2.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-1.0-gml32/1.0.1-1/sweCommon-1.0-gml32-1.0.1-1.jar (23 kB at 42 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xlink-1999/1.0.0-1/xlink-1999-1.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.2/3.2.0-1/geosciml-3.2-3.2.0-1.jar (57 kB at 93 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/samplingSpatial-2.0/2.0-1/samplingSpatial-2.0-2.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.0-seegrid/3.0.0-1/geosciml-3.0-seegrid-3.0.0-1.jar (72 kB at 116 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/wfs-2.0/2.0.0-2/wfs-2.0-2.0.0-2.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sweCommon-2.0/2.0-1/sweCommon-2.0-2.0-1.jar (16 kB at 23 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xml-1.0/1.0.0-3/xml-1.0-1.0.0-3.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xlink-1999/1.0.0-1/xlink-1999-1.0.0-1.jar (4.0 kB at 5.9 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ows-1.1/1.1.0-1/ows-1.1-1.1.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/samplingSpatial-2.0/2.0-1/samplingSpatial-2.0-2.0-1.jar (4.7 kB at 6.2 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/filter-2.0/2.0.0-2/filter-2.0-2.0.0-2.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/wfs-2.0/2.0.0-2/wfs-2.0-2.0.0-2.jar (7.0 kB at 9.2 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/samplingSpecimen-2.0/2.0.0-1/samplingSpecimen-2.0-2.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/xml-1.0/1.0.0-3/xml-1.0-1.0.0-3.jar (4.9 kB at 6.0 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sampling-2.0/2.0.0-1/sampling-2.0-2.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ows-1.1/1.1.0-1/ows-1.1-1.1.0-1.jar (30 kB at 36 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/om-2.0/2.0.0-1/om-2.0-2.0.0-1.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/filter-2.0/2.0.0-2/filter-2.0-2.0.0-2.jar (9.6 kB at 11 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/samplingSpecimen-2.0/2.0.0-1/samplingSpecimen-2.0-2.0.0-1.jar (5.5 kB at 6.1 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/sampling-2.0/2.0.0-1/sampling-2.0-2.0.0-1.jar (5.2 kB at 5.5 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/om-2.0/2.0.0-1/om-2.0-2.0.0-1.jar (8.0 kB at 8.3 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/data/refdataset-1.0/1.0.7/refdataset-1.0-1.0.7.jar (1.4 MB at 1.2 MB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/net/sf/opencsv/opencsv/1.8/opencsv-1.8.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/net/sf/opencsv/opencsv/1.8/opencsv-1.8.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/net/sf/opencsv/opencsv/1.8/opencsv-1.8.jar (8.7 kB at 2.2 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.jar (140 kB at 14 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-test ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-app-schema-test ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-app-schema-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/src/test/java’> does not exist, ignoring.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-app-schema-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-app-schema-test ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-app-schema-test ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-test ---
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 36.491 s]
[INFO] Core Platform Module ............................... SUCCESS [ 27.600 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.841 s]
[INFO] Main Module ........................................ SUCCESS [01:25 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.088 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.712 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.398 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.643 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.730 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.149 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:26 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:26 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.253 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.966 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:01 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:29 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.365 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.355 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.028 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.110 s]
[INFO] Core UI Module ..................................... SUCCESS [01:11 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 56.861 s]
[INFO] GWC UI Module ...................................... FAILURE [ 2.334 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.523 s]
[INFO] Demos Module ....................................... SUCCESS [01:10 min]
[INFO] WCS UI Module ...................................... FAILURE [ 0.242 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.034 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:08 min]
[INFO] Security UI JDBC Module ............................ FAILURE [ 42.873 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.553 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.286 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.024 s]
[INFO] Printing Module .................................... SUCCESS [ 36.359 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 9.802 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.398 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.307 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.826 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.973 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.629 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.281 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.287 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.229 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 16.575 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 5.765 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.019 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.431 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.542 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 11.025 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.934 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.311 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.620 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.867 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.317 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.723 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.658 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. FAILURE [ 1.698 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Module ...................... FAILURE [ 2.111 s]
[INFO] GeoServer Security Extension Web Modules ........... FAILURE [ 0.041 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.966 s]
[INFO] GeoServer INSPIRE Extensions ....................... FAILURE [ 0.187 s]
[INFO] GeoServer CSS Styling .............................. FAILURE [ 3.424 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.036 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.826 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.826 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 1.340 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.345 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.041 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions FAILURE [ 0.033 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.524 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.669 s]
[INFO] Importer Core Module ............................... FAILURE [ 4.033 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.934 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 50.159 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 0.710 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 21.413 s]
[INFO] Ysld GeoServer Plugin .............................. FAILURE [ 1.142 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.553 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.826 s]
[INFO] GeoFence security integration ...................... FAILURE [ 13.534 s]
[INFO] Authentication by unique url key ................... FAILURE [ 14.447 s]
[INFO] Total time: 15:36 min (Wall Clock)
[INFO] Finished at: 2019-09-15T09:06:45Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-web-sec-jdbc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/jdbc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-geofence: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wps-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0-eo-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-gwc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/gwc/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-authkey: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/authkey/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-inspire: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/inspire/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-monitor-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ysld: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ysld/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-css: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/css/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wcs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wcs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-importer-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-netcdf-out: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf-out/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-cas: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/cas/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-web-sec: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-app-schema-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/app-schema-test/pom.xml> isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-jdbc
Jenkins
3
