See <https://build.geoserver.org/job/geoserver-java11/1224/display/redirect>
[...truncated 569.97 KB...]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/jfree/jcommon/1.0.13/jcommon-1.0.13.pom (386 B at 2.8 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-charts/23-SNAPSHOT/gt-charts-23-20190911.105551-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-render/23-SNAPSHOT/gt-render-23-20190911.105545-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-cql/23-SNAPSHOT/gt-cql-23-20190911.105513-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/apache/xml/xml-commons-resolver/1.2/xml-commons-resolver-1.2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-xml/23-SNAPSHOT/gt-xml-23-20190911.105500-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-charts/23-SNAPSHOT/gt-charts-23-20190911.105551-11.jar (14 kB at 528 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/jfree/eastwood/1.1.1-20090908/eastwood-1.1.1-20090908.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/jfree/jfreechart/1.0.10/jfreechart-1.0.10.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-cql/23-SNAPSHOT/gt-cql-23-20190911.105513-11.jar (200 kB at 5.1 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/jfree/jcommon/1.0.13/jcommon-1.0.13.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-render/23-SNAPSHOT/gt-render-23-20190911.105545-11.jar (578 kB at 14 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-xml/23-SNAPSHOT/gt-xml-23-20190911.105500-11.jar (795 kB at 15 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/apache/xml/xml-commons-resolver/1.2/xml-commons-resolver-1.2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/jfree/eastwood/1.1.1-20090908/eastwood-1.1.1-20090908.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/jfree/jfreechart/1.0.10/jfreechart-1.0.10.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/jfree/jcommon/1.0.13/jcommon-1.0.13.jar
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/apache/xml/xml-commons-resolver/1.2/xml-commons-resolver-1.2.jar (84 kB at 307 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/jfree/eastwood/1.1.1-20090908/eastwood-1.1.1-20090908.jar (53 kB at 151 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/jfree/jcommon/1.0.13/jcommon-1.0.13.jar (308 kB at 497 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/jfree/jfreechart/1.0.10/jfreechart-1.0.10.jar (1.3 MB at 1.6 MB/s)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar (26 kB at 3.2 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/conversantmedia/disruptor/1.2.13/disruptor-1.2.13.jar (134 kB at 17 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-charts ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-charts ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-charts ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-charts ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-charts ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-charts ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-charts ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-charts ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-charts ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-charts ---
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 27.998 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.279 s]
[INFO] Open Web Service Module ............................ FAILURE [ 9.718 s]
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer Security Tests Module .................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.227 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.715 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.166 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.944 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... FAILURE [ 13.157 s]
[INFO] JP2K Coverage Extension ............................ FAILURE [ 8.668 s]
[INFO] OGR parent ......................................... FAILURE [ 0.014 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... FAILURE [ 0.032 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... FAILURE [ 3.066 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ FAILURE [ 1.802 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. FAILURE [ 0.011 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... FAILURE [ 0.012 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:14 min (Wall Clock)
[INFO] Finished at: 2019-09-15T13:51:22Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-ows: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/ows/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] The forked VM terminated without properly saying goodbye. VM crash or System.exit called?
[ERROR] Command was /bin/sh -c cd <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/ows> && /tmp/jenkins-dc9a1a1b/tools/hudson.model.JDK/OpenJDK_11.0.3/jdk-11.0.3+7/bin/java -Xmx512M -enableassertions -Djava.awt.headless=true -Dsun.java2d.d3d=true -DremoteOwsTests=false -DquietTests=true -Dorg.geotools.image.test.enabled=true -Dorg.geotools.image.test.interactive=false -Duser.timezone= -Dwindows.leniency=true -XX:+TieredCompilation -XX:TieredStopAtLevel=1 -XX:+IgnoreUnrecognizedVMOptions --illegal-access=debug -jar <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/ows/target/surefire/surefirebooter7960598872132184848\.jar> <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/ows/target/surefire> 2019-09-15T13-50-53_201-jvmRun1 surefire3232097513688965329tmp surefire_11439316212602967055tmp
[ERROR] Error occurred in starting fork, check output in log
[ERROR] Process Exit Code: 1
[ERROR] org.apache.maven.surefire.booter.SurefireBooterForkException: The forked VM terminated without properly saying goodbye. VM crash or System.exit called?
[ERROR] at org.apache.maven.plugin.surefire.booterclient.ForkStarter.fork(ForkStarter.java:669)
[ERROR] at org.apache.maven.plugin.surefire.booterclient.ForkStarter.run(ForkStarter.java:282)
[ERROR] at org.apache.maven.plugin.surefire.booterclient.ForkStarter.run(ForkStarter.java:245)
[ERROR] at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeProvider(AbstractSurefireMojo.java:1183)
[ERROR] at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:1011)
[ERROR] at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:857)
[ERROR] at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:137)
[ERROR] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:210)
[ERROR] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:156)
[ERROR] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:148)
[ERROR] at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:117)
[ERROR] at org.apache.maven.lifecycle.internal.builder.multithreaded.MultiThreadedBuilder$1.call(MultiThreadedBuilder.java:200)
[ERROR] at org.apache.maven.lifecycle.internal.builder.multithreaded.MultiThreadedBuilder$1.call(MultiThreadedBuilder.java:196)
[ERROR] at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
[ERROR] at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
[ERROR] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
[ERROR] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
[ERROR] at java.base/java.lang.Thread.run(Thread.java:834)
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-gdal: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/gdal/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-ogr: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-wps: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-jp2k: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/jp2k/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-imagemosaic-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/imagemosaic-jdbc/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-dxf: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-wcs2_0-eo: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/pom.xml> isn't a file. -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-charts: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/charts/pom.xml> isn't a file. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
