[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #1242
See <https://build.geoserver.org/job/geoserver-java11/1242/display/redirect&gt;
[...truncated 2.31 MB...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 1 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-notification ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-notification ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[debug] Using AOSP style
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/notification/target/gs-notification-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-notification/2.17-SNAPSHOT/gs-notification-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] ----------------< org.geoserver.community:gs-metadata >-----------------
[INFO] Building GeoServer Metadata Customizer 2.17-SNAPSHOT [81/82]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.pom (14 kB at 3.6 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.pom (498 B at 100 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/progressbar-parent/8.3.0/progressbar-parent-8.3.0.pom (1.3 kB at 212 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-core/8.3.0/wicketstuff-core-8.3.0.pom (44 kB at 8.7 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.pom (4.6 kB at 1.1 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/oss-parent/11/oss-parent-11.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/oss-parent/11/oss-parent-11.pom (23 kB at 12 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar (27 kB at 5.3 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/wicketstuff/wicketstuff-progressbar/8.3.0/wicketstuff-progressbar-8.3.0.jar (12 kB at 2.4 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.3.0/jackson-dataformat-yaml-2.3.0.jar (354 kB at 22 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-metadata ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-metadata ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-metadata ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-metadata ---
[INFO] Copying 5 resources
[INFO] Copying 22 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-metadata ---
[INFO] Compiling 89 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-metadata ---
[INFO] Copying 12 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-metadata ---
[INFO] Compiling 17 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-metadata ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-metadata ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-metadata ---
[INFO] Processed 100 files (0 non-complying).
[INFO] Processed 106 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-metadata ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/metadata/target/gs-metadata-2.17-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/community/gs-metadata/2.17-SNAPSHOT/gs-metadata-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for Community Space 2.17-SNAPSHOT:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 2.534 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 4.413 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 3.750 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.119 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 1.497 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 1.061 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 0.864 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.008 s]
[INFO] WMS-EO ............................................. SUCCESS [ 1.243 s]
[INFO] ColorMap ........................................... SUCCESS [ 0.929 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 1.282 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 1.134 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.410 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 0.962 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 0.837 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 0.811 s]
[INFO] DownloadProcess .................................... SUCCESS [ 3.346 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.164 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 9.358 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.652 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 6.919 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.641 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.464 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 1.028 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 19.348 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.008 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 0.877 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.671 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.455 s]
[INFO] GeoWebCache Azure blob ............................. SUCCESS [ 14.970 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 0.723 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 0.733 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 0.869 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 1.018 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.345 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.518 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 0.933 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 0.536 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 0.771 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 1.151 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 0.960 s]
[INFO] WMTS Style editing extension ....................... SUCCESS [ 0.879 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.011 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 4.342 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 0.776 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 0.770 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 0.769 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 0.794 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 8.207 s]
[INFO] GeoServer SAMLv2 SSO Module ........................ SUCCESS [ 7.457 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.219 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.336 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 0.737 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.317 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.011 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 1.437 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 0.807 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 1.233 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.036 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.503 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 1.063 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 1.033 s]
[INFO] WFS 3 prototype .................................... FAILURE [ 13.802 s]
[INFO] MapML Support for GeoServer ........................ SUCCESS [ 3.588 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 5.325 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 0.924 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 3.774 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 15.126 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 0.915 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 2.494 s]
[INFO] OGR datastore panel ................................ SUCCESS [ 0.940 s]
[INFO] gs-ogcapi .......................................... SUCCESS [ 0.011 s]
[INFO] gs-ogcapi-core ..................................... SUCCESS [ 1.058 s]
[INFO] gs-ogcapi-features ................................. SUCCESS [ 0.919 s]
[INFO] gs-ogcapi-styles ................................... SUCCESS [ 1.111 s]
[INFO] gs-ogcapi-tiles .................................... SUCCESS [ 1.067 s]
[INFO] Catalog Services for the Web ISO metadata profile module SUCCESS [ 0.820 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoStyler community module ......................... SUCCESS [ 0.784 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 24.629 s]
[INFO] GeoServer Metadata Customizer ...................... SUCCESS [ 5.134 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:02 min
[INFO] Finished at: 2019-09-16T20:38:30Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wfs3: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 50 out of bounds for length 49 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs3
See <https://build.geoserver.org/job/geoserver-java11/1243/display/redirect&gt;
