See <https://build.geoserver.org/job/geoserver-java11/257/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9092] Add JSON as a Legend Output format (GISP 173)
[Andrea Aime] [GEOS-9092] Complete icon export for graphic strokes, fills and text
[Andrea Aime] [GEOS-9092] Generate URLs with defaults for attribute dependent styles
[...truncated 1.62 MB...]
[ERROR] symbol: class PropertyIsGreaterThanOrEqualTo
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java>:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-csw: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-app: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/TestHomePage.java>:\[6,1\] cannot access org.geoserver.wicket.test
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/javax/media/jai_imageio/1.1/jai_imageio-1.1.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/WebXmlTest.java>:\[6,1\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/filters/GZIPResponseStreamTest.java>:\[6,1\] cannot access org.geoserver.filters
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java>:\[16,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java>:\[16,44\] cannot find symbol
[ERROR] symbol: class Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java>:\[22,31\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: interface org.geoserver.wicket.test.IComponentFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java>:\[22,5\] cannot find symbol
[ERROR] symbol: class Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java>:\[28,8\] cannot access org.geoserver.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java>:\[28,44\] cannot find symbol
[ERROR] symbol: class WebApplication
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java>:\[69,12\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] location: class org.geoserver.wicket.test.WicketTestApplication
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java>:\[69,28\] cannot find symbol
[ERROR] symbol: class Page
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java>:\[49,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java>:\[50,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.web.Start
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java>:\[180,20\] cannot find symbol
[ERROR] symbol: class SslContextFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java>:\[214,30\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java>:\[269,56\] cannot find symbol
[ERROR] symbol: class KeyStore
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
