[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #267
See <https://build.geoserver.org/job/geoserver-java11/267/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9070] OpenLayers2 preview does not trigger automatically on IE8
[...truncated 1.84 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[28,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[29,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[30,39\] package org.jasig.cas.client.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[31,11\] cannot access org.springframework
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/it/geosolutions/jaiext/vectorbin/jt-vectorbin/1.1.6/jt-vectorbin-1.1.6.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[31,27\] cannot access org.springframework.security
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[31,40\] import requires canonical name for <any>.cas.ServiceProperties
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[32,36\] cannot access org.springframework.security.cas
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[32,40\] cannot access org.springframework.security.cas.web
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ogr-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java&gt;:\[5,1\] cannot access org.geoserver.wps.hz
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/com/google/guava/guava/27.0-jre/guava-27.0-jre.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[30,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[30,41\] cannot find symbol
[ERROR] symbol: class DisposableBean
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[31,26\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.wps.hz.HazelcastLoader
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[34,25\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[37,13\] cannot find symbol
[ERROR] symbol: class HazelcastInstance
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[45,28\] cannot find symbol
[ERROR] symbol: class ResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[45,56\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[67,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[77,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[86,40\] cannot find symbol
[ERROR] symbol: class Config
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;:\[118,34\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[69,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[69,42\] cannot find symbol
[ERROR] symbol: class FilterVisitor
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[119,25\] cannot find symbol
[ERROR] symbol: class ExcludeFilter
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[124,25\] cannot find symbol
[ERROR] symbol: class IncludeFilter
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[130,25\] cannot find symbol
[ERROR] symbol: class And
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[139,25\] cannot find symbol
[ERROR] symbol: class Id
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[148,25\] cannot find symbol
[ERROR] symbol: class Not
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[153,25\] cannot find symbol
[ERROR] symbol: class Or
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[162,25\] cannot find symbol
[ERROR] symbol: class PropertyIsBetween
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[169,36\] cannot find symbol
[ERROR] symbol: class Expression
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[183,25\] cannot find symbol
[ERROR] symbol: class PropertyIsEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[189,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNotEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[195,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[203,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-csw-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-css
See <https://build.geoserver.org/job/geoserver-java11/268/display/redirect?page=changes&gt;
Changes:
[alessio.fabiani] - Resource Monitor: minor refactoring to the data collection main cycle.
[...truncated 2.16 MB...]
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-taskmanager-s3 ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/external/S3FileServiceDataTest.java&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/external/S3FileServiceDataTest.java&gt; uses or overrides a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/src/test/java/org/geoserver/taskmanager/external/S3FileServiceDataTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-taskmanager-s3 ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-taskmanager-s3 ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-taskmanager-s3 ---
[debug] Using AOSP style
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-taskmanager-s3 ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/taskmanager/s3/target/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-taskmanager-s3/2.15-SNAPSHOT/gs-taskmanager-s3-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Building GeoServer Quality of Service GetCapabilities module 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-qos ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-qos ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-qos ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-qos ---
[INFO] Copying 21 resources
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-qos ---
[INFO] Compiling 89 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/util/ListUtl.java&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/util/ListUtl.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/main/java/org/geoserver/qos/util/ListUtl.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-qos ---
[INFO] Copying 0 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-qos ---
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/test/java/org/geoserver/qos/wfs/QosWFSRestTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/src/test/java/org/geoserver/qos/wfs/QosWFSRestTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-qos ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-qos ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-qos ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-qos ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-qos ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-qos ---
[INFO] Processed 100 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-qos ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-qos/2.15-SNAPSHOT/gs-qos-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-qos/2.15-SNAPSHOT/gs-qos-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-qos/2.15-SNAPSHOT/gs-qos-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-qos/2.15-SNAPSHOT/gs-qos-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/qos/target/gs-qos-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-qos/2.15-SNAPSHOT/gs-qos-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO]
[INFO] Building GeoServer notification event system 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt;: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt; uses or overrides a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/INotificationTransactionListener.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/main/java/org/geoserver/notification/NotificationPropertyAccessor.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/DefaultConfigTest.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/src/test/java/org/geoserver/notification/DefaultConfigTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-notification ---
[INFO] Processed 20 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/community/notification/target/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/./m2/org/geoserver/community/gs-notification/2.15-SNAPSHOT/gs-notification-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 11.181 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 9.829 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 3.822 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 5.030 s]
[INFO] WMS-EO ............................................. SUCCESS [ 3.504 s]
[INFO] ColorMap ........................................... SUCCESS [ 2.182 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 3.703 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 2.648 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.174 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 2.848 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 1.869 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 1.850 s]
[INFO] DownloadProcess .................................... SUCCESS [ 3.586 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.331 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 2.798 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 0.903 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 6.537 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 3.132 s]
[INFO] Solr Module ........................................ SUCCESS [ 2.101 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 2.437 s]
[INFO] Web Processing Service - Remote processes invocation FAILURE [ 3.163 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.970 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 1.997 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.971 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 1.890 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.081 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 1.491 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 1.550 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 1.915 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 1.825 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 1.209 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 4.274 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 2.172 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 1.303 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 2.011 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 2.323 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.038 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SUCCESS [ 1.275 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 1.583 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 1.345 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 1.938 s]
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SUCCESS [ 1.774 s]
[INFO] GeoServer Keycloak Security Plugin ................. SUCCESS [ 1.754 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 2.236 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.501 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 0.713 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 1.515 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 0.709 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.022 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 3.624 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 1.274 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 2.690 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 1.658 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 0.994 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.037 s]
[INFO] NSG WMTS 1.0 Profile ............................... SUCCESS [ 0.581 s]
[INFO] NSG WFS 2.0 Profile ................................ SUCCESS [ 2.293 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 3.065 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 2.584 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 1.004 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 2.462 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 0.090 s]
[INFO] GeoServer Task Manager Core ........................ SUCCESS [ 6.706 s]
[INFO] GeoServer Task Manager S3 .......................... SUCCESS [ 1.898 s]
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 3.516 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SUCCESS [ 1.731 s]
[INFO] BUILD FAILURE
[INFO] Total time: 02:36 min
[INFO] Finished at: 2019-01-14T10:48:54+00:00
[INFO] Final Memory: 280M/944M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-wps-remote: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-remote
Not sending mail to unregistered user alessio.fabiani@anonymised.com
See <https://build.geoserver.org/job/geoserver-java11/269/display/redirect?page=changes&gt;
