[tixvieira] GEOS-9051 Printing plugin upgrade version of JTS from vividsolutions to
[...truncated 1.43 MB...]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-cas ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
Jan 21, 2019 9:38:28 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:227)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at jdk.internal.reflect.GeneratedMethodAccessor292.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
[Andrea Aime] Remove workspace qualification in WFS3 when using virtual services
[...truncated 1.47 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
Jan 21, 2019 7:12:49 PM org.geoserver.importer.Importer init
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.909 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-csw >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-csw ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-csw <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-csw ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.796 s]
[INFO] Core Platform Module ............................... SUCCESS [ 31.561 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 23.278 s]
[INFO] Main Module ........................................ SUCCESS [02:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.301 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:13 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:05 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.709 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.519 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 31.610 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 33.513 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:44 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:54 min]
[INFO] Web Map Service Module ............................. FAILURE [03:26 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 22.941 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [02:09 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 25.047 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 30.743 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.198 s]
[INFO] Core UI Module ..................................... SUCCESS [02:03 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 18.925 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.190 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:13 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:30 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.226 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.574 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.133 s]
[INFO] Printing Module .................................... SUCCESS [ 16.300 s]
[INFO] Community Space .................................... SUCCESS [ 0.101 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.130 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 16.536 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.530 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 21.423 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.566 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.281 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.326 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.496 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.276 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.077 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.125 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.813 s]
[INFO] OGR WFS ............................................ SUCCESS [ 12.708 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.078 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:48 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.509 s]
[INFO] Excel Output Format ................................ SUCCESS [ 18.620 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.135 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.840 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.057 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 24.383 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 14.649 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 21.221 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.709 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.234 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.174 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.087 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.094 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.728 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 29.175 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.383 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.821 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 13.054 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 47.079 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.501 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.107 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 20.082 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.303 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.083 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 27.192 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.041 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.414 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.024 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:19 min (Wall Clock)
[INFO] Finished at: 2019-01-22T10:04:15+00:00
[INFO] Final Memory: 362M/1224M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user tixvieira@anonymised.com
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.256 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.374 s]
[INFO] Core Platform Module ............................... SUCCESS [ 29.504 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 22.380 s]
[INFO] Main Module ........................................ SUCCESS [01:57 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.138 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:42 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:07 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.071 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.419 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 34.255 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.631 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:31 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:50 min]
[INFO] Web Map Service Module ............................. FAILURE [03:28 min]
[INFO] gs-rest ............................................ SUCCESS [ 17.200 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 24.571 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 30.835 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.164 s]
[INFO] Core UI Module ..................................... SUCCESS [02:07 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 20.154 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.125 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:14 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.580 s]
[INFO] REST UI Module ..................................... SUCCESS [ 15.968 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.141 s]
[INFO] Printing Module .................................... SUCCESS [ 15.762 s]
[INFO] Community Space .................................... SUCCESS [ 0.116 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.126 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 18.200 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 16.681 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 15.810 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.166 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.041 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.331 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.488 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.720 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.099 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.081 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.665 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.942 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.056 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:02 min]
[INFO] OGR WPS ............................................ SUCCESS [ 13.947 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.145 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.918 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.518 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.939 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 24.546 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.893 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.960 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.227 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.095 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.123 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.963 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.116 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.412 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 27.202 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.156 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 14.501 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 13.825 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 58.798 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.451 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 18.585 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 12.036 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.082 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 25.607 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.126 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.883 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.743 s]
[INFO] Total time: 21:18 min (Wall Clock)
[INFO] Finished at: 2019-01-22T10:34:58+00:00
[INFO] Final Memory: 319M/1070M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
