[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #293
See <https://build.geoserver.org/job/geoserver-java11/293/display/redirect?page=changes&gt;
Changes:
[Ian Turton] Updated version to 2.16-SNAPSHOT, GeoTools to 22-SNAPSHOT and GWC to
[...truncated 1.47 MB...]
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-web-sec-cas >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-web-sec-cas ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
Jan 27, 2019 11:11:18 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
  at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
  at org.geoserver.importer.Importer.addTasks(Importer.java:472)
  at org.geoserver.importer.Importer.init(Importer.java:440)
  at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
  at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
  at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
  at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.base/java.lang.reflect.Method.invoke(Method.java:566)
  at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
  at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
  at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
  at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
  at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
  at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.589 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.78 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.520 s]
[INFO] Core Platform Module ............................... SUCCESS [ 36.975 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 29.206 s]
[INFO] Main Module ........................................ SUCCESS [02:43 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.287 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.248 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 9.913 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 9.700 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 37.744 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 38.435 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [03:03 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:03 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 40.316 s]
[INFO] gs-rest ............................................ SUCCESS [ 27.372 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 6.394 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:52 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 26.761 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 24.997 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 18.028 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [02:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 49.919 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 14.937 s]
[INFO] Demos Module ....................................... SUCCESS [ 26.300 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.074 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.139 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:54 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:43 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.341 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.590 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.173 s]
[INFO] Printing Module .................................... SUCCESS [ 15.866 s]
[INFO] Community Space .................................... SUCCESS [ 0.120 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.113 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:13 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.830 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.002 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.585 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.655 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 2.294 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.811 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.964 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.821 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.070 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.774 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.103 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.604 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.063 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.125 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:47 min]
[INFO] OGR WPS ............................................ SUCCESS [ 14.401 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.643 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.875 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.461 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.150 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 21.387 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 24.258 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 34.483 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.346 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.003 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.172 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.184 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.874 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.083 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.907 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.531 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 26.039 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.115 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.008 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.982 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 38.847 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 15.099 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.093 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.264 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 13.776 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.073 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 23.148 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 19.899 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 16.054 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.208 s]
[INFO] Importer Core Module ............................... SUCCESS [01:16 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:00 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 21.915 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 19.167 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.465 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 35.555 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 45.774 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 33.221 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 4.823 s]
[INFO] REST SLD service ................................... SUCCESS [ 28.777 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 34.000 s]
[INFO] GeoFence Server .................................... SUCCESS [ 56.956 s]
[INFO] BUILD FAILURE
[INFO] Total time: 28:07 min (Wall Clock)
[INFO] Finished at: 2019-01-27T11:11:21+00:00
[INFO] Final Memory: 449M/1514M
[ERROR] Failed to execute goal on project gs-gwc: Could not resolve dependencies for project org.geoserver:gs-gwc:jar:2.15-SNAPSHOT: The following artifacts could not be resolved: org.geowebcache:gwc-core:jar:1.16-SNAPSHOT, org.geowebcache:gwc-georss:jar:1.16-SNAPSHOT, org.geowebcache:gwc-gmaps:jar:1.16-SNAPSHOT, org.geowebcache:gwc-kml:jar:1.16-SNAPSHOT, org.geowebcache:gwc-rest:jar:1.16-SNAPSHOT, org.geowebcache:gwc-tms:jar:1.16-SNAPSHOT, org.geowebcache:gwc-ve:jar:1.16-SNAPSHOT, org.geowebcache:gwc-wms:jar:1.16-SNAPSHOT, org.geowebcache:gwc-wmts:jar:1.16-SNAPSHOT, org.geowebcache:gwc-diskquota-jdbc:jar:1.16-SNAPSHOT, org.geowebcache:gwc-core:jar:tests:1.16-SNAPSHOT: Could not find artifact org.geowebcache:gwc-core:jar:1.16-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-java11/294/display/redirect&gt;
