See <https://build.geoserver.org/job/geoserver-java11/308/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9123] WMTS capabilities backlinks miss workspace qualification
[...truncated 1.48 MB...]
[INFO] 15 errors
[INFO] -------------------------------------------------------------
[INFO]
[INFO] Building Importer Web UI Module 2.16-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-web ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/target>
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-bdb ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-web ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-importer-web ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/src>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-bdb ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-importer-bdb ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-bdb ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-web ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-bdb ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/target/classes>
[INFO] Copying 27 resources
[INFO] Copying 20 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-web ---
[INFO] Compiling 33 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/target/classes>
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java>: Too many open files
[INFO] 4 errors
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/target/classes>
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java;> <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: Too many open files
[INFO] 2 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.537 s]
[INFO] Core Platform Module ............................... SUCCESS [ 31.285 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 25.099 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.258 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:16 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:19 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 9.586 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.148 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 30.682 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 34.173 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [05:51 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:57 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 37.209 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.600 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:42 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:43 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 22.186 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 24.513 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.377 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.132 s]
[INFO] Core UI Module ..................................... SUCCESS [02:05 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 49.553 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:11 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 21.850 s]
[INFO] Demos Module ....................................... SUCCESS [ 35.763 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 18.931 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.155 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:54 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:39 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.711 s]
[INFO] REST UI Module ..................................... SUCCESS [ 15.727 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.123 s]
[INFO] Printing Module .................................... SUCCESS [ 20.424 s]
[INFO] GeoServer Web Application .......................... FAILURE [ 7.273 s]
[INFO] Community Space .................................... SUCCESS [ 0.119 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.090 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.841 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 20.268 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.150 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.849 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.575 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.266 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.219 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 14.276 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.757 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.259 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.055 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.750 s]
[INFO] OGR WFS ............................................ SUCCESS [ 16.059 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.072 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:00 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.909 s]
[INFO] Excel Output Format ................................ SUCCESS [ 21.062 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.531 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.278 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 24.136 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.526 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 36.673 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 25.491 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.108 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.257 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 35.075 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.127 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 10.123 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.198 s]
[INFO] GeoServer CAS Security Web Module .................. FAILURE [ 0.505 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 30.266 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 48.285 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 22.146 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.167 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 16.438 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 15.645 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:00 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 14.955 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.066 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 21.577 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.703 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.064 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 25.416 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 17.285 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 14.862 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.280 s]
[INFO] Importer Core Module ............................... SUCCESS [01:19 min]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 5.026 s]
[INFO] Importer Berkley DB Persistence Module ............. FAILURE [ 0.702 s]
[INFO] Importer Web UI Module ............................. FAILURE [ 0.640 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 31.414 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 29.216 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:00 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 24.805 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 19.140 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.471 s]
[INFO] REST SLD service ................................... SUCCESS [ 31.750 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 34.968 s]
[INFO] GeoFence Server .................................... SUCCESS [01:01 min]
[INFO] BUILD FAILURE
[INFO] Total time: 31:59 min (Wall Clock)
[INFO] Finished at: 2019-02-04T17:30:16+00:00
[INFO] Final Memory: 612M/1845M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-war-plugin:2.3:war (default) on project gs-web-app: Failed to copy file for artifact [com.codahale.metrics:metrics-core:jar:3.0.2:compile]: <https://build.geoserver.org/job/geoserver-java11/ws/src/web/app/target/geoserver/WEB-INF/lib/metrics-core-3.0.2.jar> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportTaskControllerTest.java>:\[6,1\] cannot access org.geoserver.importer.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geotools/gt-grid/22-SNAPSHOT/gt-grid-22-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/converters/ImportJSONIOTest.java>:\[6,1\] cannot access org.geoserver.importer.rest.converters
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,47\] cannot find symbol
[ERROR] symbol: class ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[22,38\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.rest.ImportDataControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[29,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[36,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[42,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[51,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,52\] cannot find symbol
[ERROR] symbol: class DataTestCase
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[49,47\] cannot find symbol
[ERROR] symbol: class ParseException
[ERROR] location: class org.geoserver.importer.rest.DateFormatTransformTest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[80,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[36,28\] cannot find symbol
[ERROR] symbol: class ImportTransform
[ERROR] location: class org.geoserver.importer.rest.TransformTestSupport
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/web/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst> (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-app
